curl: (7) Failed to connect to supervisor port 80 after 0 ms: Couldn’t connect to server
ERROR: Something went wrong contacting the API
Required parameters username and/or password not set. Starting aborted!
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
I’m seeing the error above. It was working until I restore a full backup to a new machine.
Now I have to run the old version ‘Eufy Security Add-On’ 1.3.0 to get it working again.
Anyone here using a T8423 floodlight 360 cam, which has pan & tilt?
I’ve set mine up on a bench (not yet mounted) and got a stream working just fine using the integration.
Wondering how I can control the pan and tilt controls from my dashboard? Anyone whipped up any solutions here already?
I assigned a static lease on that ip to make sure it doesn’t change.
I have no idea why but the lock/unlock service doesn’t work unless you assign the station manually.
when a camera image is updated, the camera. sensor uses the heavily cropped thumbnail from the eufy app, rather than the full resolution image. Is this behaviour configurable somewhere?
Screenshot from my dashboard with screenshot form the eufy app overlaid.
My integration in HA isnt working anymore for a long time.
I would like to start over from 0
But i dont know what to follow, too many integration, too many info, , here or bropat…
Think most of my devices are working again, yay, curious how long =)
However only thing for now not working is streaming my doorbell video
Other devices streaming are working
Doorbell is just not starting… model T8210
RTSP addon installed
Since the alarm keypad is connected via the Homebase, the only way to use this is via the Homebase, cannot work standalone.
Once the Homebase is connected to the integration, you can control the alarm keypad entity (but not the codes, that you have to take care of yourself via Home Assistant if required), you can trigger an alarm on the alarm keypad, reset the alarm, view the battery.
The alarm modes you control via the Homebase entity in Home Assistant
I have Eufy Security camera S330 (T8423) and configured the integration based on doc:
I can see all my cameras are discovered but when I added them to the dashboard or clicked on the entity, they just show static image instead of live streaming. These cameras are mains powered means they are always on (and configured to record when motion is detected in the Eufy Security app).
Since these cameras are RTSP supported, I didn’t install/configure ‘RTSP Simple Server Add-on’ because the document says, it is only needed for P2P. But I didn’t enable RTSP Steam in my mobile app. Do you think that is the reason I cannot see Live streaming? When I checked devise entities, stream provider is showing as P2P (even if I don’t configure RTSP Simple Server Add-On’)
If I enable RTSP stream in the mobile app, where do I configure the details of live stream URLs since the document doesn’t mention anything about it? Do you think I need to install ‘WebRTC Camera’ add-on and configure it there?
