Hi, so this is how you do it:
Open file on HA …\config\custom_components\localtuya\climate.py
In climate.py you can find HVAC_MODE_SETS (line 59 or around) and
add new set:
"manual (m) / automatic (p)": {
HVAC_MODE_HEAT: "m",
HVAC_MODE_AUTO: "p",
in the same file find PRESET_SETS (line 94 or around)
and add
"low/mid/high/off": {
PRESET_NONE: "low",
PRESET_AWAY: "mid",
PRESET_HOME: "high",
Now you can set the device:
Protocol version 3.3
You will get device with every option.
Preset is not corresponding to real values but you will find what is what. I do control heaters from the AppDaemon so I do not care. It may be possible to fix that as well.
