Eurotronics Spirit Automation only runs once
Hi there,
I’m having a problem with setting the temperature of my Eurotronic Z-wave radiator valves. I created this automation:
alias: Avondverlaging kamer Boaz 12 graden
description: ''
  - platform: time
    at: '17:00'
condition: []
  - device_id: c8668dfc393d9c205369baf891497643
    domain: zwave_js
    type: set_value
    command_class: 67
    property: setpoint
    property_key: '1'
    value: '12'
    endpoint: '0'
mode: single
When this is first trigger it does correct what it is supposed to do and lowers the temperature to 12 degrees at 17:00.
Only after that first time it stops working and gives this trace timeline
I can’t seem to find out what I’m doing wrong here.
Thanks in advance for your tips if you have them!
Frans
I don’t know the answer but you might want to know that there is someone else who has experienced the same problem recently:
thnx! Unfortunately over there there also seems to be no answer… :frowning:
