With the large number of EV’s on the streets I think it is time for the HA Energy Dashboard to be redesigned.
I also do not see any way to see water cost og heating cost if it is something other than gas.
It would be nice if it was possible to remove ones that are not used and add other that are used.
I live in a house that is 100% powered by electricity from the Grid. I have a heat pump for heating and hot water, and I charge my EV. This means that I have a rather high grid usage but I have no easy way of showing the cost of heating the house or charging the car.
For now I have added a virtual custom sensor as Gas to be able to show the cost of charging the car.
Why is there no Water section in the Energy dashboard?
I haven’t tested it yet so I don’t know if it will actually show the actual charging cost, but later this week I will need to charge the car so I will have to want and see.
I just think it is quite misleading that it will show up as an energy source in the dashboard, but for now this is what seems possible.
I think it would nice if it was possible to place have an EV section that visually is placed in the correct position.
IMHO, this cannot be correct. Assuming the yield of your solar system is high enough to supply all consumers, you will have no electricity costs. If only 50% comes from your solar system, you only have 50% electricity costs. So you have to differentiate from where the power comes.
