EventBus error 'Publish/mqttMessage': Cannot read properties of undefined (reading 'includes')
I updated some things on my HA.
One device stopped working.
This is my external converter for this device:
const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
const tz = require('zigbee-herdsman-converters/converters/toZigbee');
const exposes = require('zigbee-herdsman-converters/lib/exposes');
const reporting = require('zigbee-herdsman-converters/lib/reporting');
const modernExtend = require('zigbee-herdsman-converters/lib/modernExtend');
const e = exposes.presets;
const ea = exposes.access;
const tuya = require('zigbee-herdsman-converters/lib/tuya');
const definition = {
    // Since a lot of TuYa devices use the same modelID, but use different datapoints
    // it's necessary to provide a fingerprint instead of a zigbeeModel
    fingerprint: [
            // The model ID from: Device with modelID 'TS0601' is not supported
            // You may need to add \u0000 at the end of the name in some cases
            modelID: 'TS0601',
            // The manufacturer name from: Device with modelID 'TS0601' is not supported.
            manufacturerName: '_TZE200_7a5ob7xq',
    zigbeeModel: ['TS0601'],
    model: 'TS0601_new',
    vendor: 'Tuya',
    description: 'Uri Curtain Switch plus Lights', // Description of the device, copy from vendor site. (only used for documentation and startup logging)
    extend: [],
    fromZigbee: [tuya.fz.datapoints], // We will add this later
    toZigbee: [tuya.fz.datapoints], // Should be empty, unless device can be controlled (e.g. lights, switches).
	meta: {multiEndpoint: true},
    exposes: [e.switch().withEndpoint('l1').setAccess('state', ea.STATE_SET),
            e.switch().withEndpoint('l2').setAccess('state', ea.STATE_SET),
            e.switch().withEndpoint('l3').setAccess('state', ea.STATE_SET),
            e.switch().withEndpoint('l4').setAccess('state', ea.STATE_SET)], // Defines what this device exposes, used for e.g. Home Assistant discovery and in the frontend
	endpoint: (device) => {
            // Endpoint selection is made in tuya_switch_state
            return {'l1': 1, 'l2': 1, 'l3': 1, 'l4': 1};
module.exports = definition;
Please help. Thanks
Any idea? Thanks
Please advise. Thanks
See if you can find an answer in this thread:
NO.
Still stuck.
It is so frustrating.
Anyone knows someone who knows Zigbee2MQTT ?
