If you’re not intending to solder headers in you could just go for male to female leads and get away without the headers
I use this script for the light in HA:
script:
lampada_salotto_accesa:
sequence:
- service: ifttt.trigger
data: {“event”:“ikea_on”}
lampada_salotto_spenta:
sequence:
data: {“event”:“ikea_off”}
light:
lights:
luce_salotto:
friendly_name: “Lampada Salotto”
turn_on:
service: script.lampada_salotto_accesa
turn_off:
service: script.lampada_salotto_spenta
But have a problem for syn the UI. in body section what should I write?
I see what you are saying.
I am using switch.command_line.
######switch.yaml#####
- platform: command_line
switches:
tv_plug:
command_on: “/usr/bin/curl -X GET https://maker.ifttt.com/trigger/TURN_ON_TVPlug/with/key/YOUR_IFTTT_KEY”
command_off: “/usr/bin/curl -X GET https://maker.ifttt.com/trigger/TURN_OFF_TVPlug/with/key/YOUR_IFTTT_KEY”
friendly_name: “TV Plug”
Using my script, how should I set up WebHooks to refresh the state? Thanks
I try with your switch.command_line, but not working… sonoff not switch light… if i copy the ifttt url in a browser work, if i click the switch in home assistant not working…
Why?
WIP:
Works well, it works on my WHDTS WiFi Momentary Inching Relay, although it shows up as a switch, it would be nice if I can change it to a momentary switch instead. Thanks for the post!
Unfortunately as I mentioned before is still work in progress and I cannot track all the requests in various threads. If you want a proper integration (and be wiling to test it, because you’re the only one so far with this type of device) please follow these links and submit a github issue
perhaps useful to know.
Hardware for flasing …
1 x mini USB cable.
Hello!
I qill try the flash on the S26 plugs that I bought to see if I can use it with HA. Is that valid to do so?
Thank you!
Well I have a problem, I have a number of Sonoff Devices, followed your installation. It worked for a two weeks and now it is unavailable., I have 10 people telling me to change this and that, but nothing is working. My WIFI is 100% and on the Sonoff GUI it works fine.
Any suggestions?
could the IP addresses have changed?
This is a fantastic integration. Unfortunately for me it does not work after I have upgraded to HA 0.100.1. So I had to downgrade HA.
In HA 0.100.1 I get the following error in the log:
Error loading custom_components.sonoff. Make sure all dependencies are installed
File "/usr/src/homeassistant/homeassistant/loader.py", line 346, in _load_file
module = importlib.import_module(path)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/sonoff/__init__.py", line 10, in <module>
from homeassistant.util.async_ import run_coroutine_threadsafe
ImportError: cannot import name 'run_coroutine_threadsafe' from 'homeassistant.util.async_' (/usr/src/homeassistant/homeassistant/util/async_.py)
