Export cards to png/jpeg
Is there a way to export a card to png/jpeg ?
Example use is notifictions to phones ( signal messager, telegram etc ) so a well as text, a plot can be sent as well.
There is no way to do this at the moment.
Don’t forget to vote for your own request.
Another use case is showing the card on the Android home screen using the camera widget. We no longer have WebView widgets but this will be close enough.
This would also be cool to use in an email notification or push message.
another use case could be displaying it on esphome device if there was an option to schedule the export (i.e. autosave at specified intervals)
I imagine the best way to do this would be with a snapshot service call to export the required image. You could easily automate this with a time trigger if you want it done automatically rather than on demand when sending a notification.
Not sure how feasible this request is but it would be really handy.
At the moment it requires an additional container to get this functionality. Having this internally in home-assistant would simplify things for me a lot. I use screenshots in morning agenda notifications and e-ink Homeplate dashboard.
would you be able to provide more info on your setup how you take that screenshot?
Sure, I followed this project
https://community.home-assistant.io/t/homeplate-e-ink-dashboard-with-inkplate-10
Basically, the only part you’ll need is that container
It will create a snapshot of any dashboard’s tab, you’ll point it to. They you can just send it using preferred notification service, supporting URL Links to png images (e.g. telegram).
Exporting cards to PNG or JPEG sounds like a handy feature, especially for messaging apps. I remember needing to send plots and charts through messages too. One thing that helped was using JPG compress to keep the file sizes manageable without sacrificing quality. It’s like finding the perfect fit for your digital messages.
card to image or card to virtual camera would be very powerful for notifications.
  • display meter/graph info in PIP apps on Apple TV or Android TV
  • Enrich mobile phone notifications
  • Maybe allow external embedding of an periodically updated image in an external website / embed
There are quite a few ways this could be used.
This would be a very handy feature. We have a weather station at a remote location that leverages homeassisstant and uses esphome as a weather sensor for windspeed, temperature, rainfall measurements. We’d like to provide a snapshot of the windrose card at regular intervals, sent to another server. This limits our bandwidth usage at the remote location, which needs LTE (ie. expensive internet)
If your bandwidth is limited and expensive you would be better off sending text data than an image. Then generate the graphs from this data.
I have created a very hacky way to achieve what I needed.
  • Created a cli tool, in golang, that uses playwright-go to webscrape home assistant
Connect to Home Assistant and take a screenshot by CSS selector
Usage:
  bin/ha_ss [options]
Options:
  -css string
    	Home assistant CSS selector
  -headless
    	Headless mode (default true)
  -password string
    	Home assistant password
  -path string
    	Output screenshot path (default "output.png")
  -restport int
    	If set, startup REST server at given port
  -url string
    	Home assistant page URL
  -username string
    	Home assistant username
Environment variables:
  $HEADLESS - Headless mode
  $HA_CSS - Home assistant CSS selector
  $HA_PATH - Output screenshot path
  $HA_USERNAME - Home assistant username
  $HA_PASSWORD - Home assistant password
  $HA_RESTPORT - If set, startup REST server at given port
  $HA_URL - Home assistant page URL
  • Created a basic addon that runs the above in home assistant as a REST server addon
I then create in configuration.yaml a REST command :
rest_command:
  screenshot:
    url: http://localhost:3500
    method: post
    headers:
      accept: "application/json, text/html"
    payload: '{"url": "{{ url }}", "css": "{{ css }}", "filename": "{{ filename }}"}'
    content_type:  'application/json; charset=utf-8'
    timeout: 120
This enables automations to take a screenshot and attach to a notification
alias: Car - next green time to charge
description: ""
triggers:
  - entity_id:
      - binary_sensor.octopus_energy_a_xxxxxxx_greenness_forecast_highlighted
    attribute: next_start
    trigger: state
conditions: []
actions:
  - action: rest_command.screenshot
      url: http://homeassistant.local:8123/lovelace/overview
      css: >-
        div.card:nth-child(4) > hui-card:nth-child(1) >
        octopus-energy-greenness-forecast-card:nth-child(1)
      filename: greenness-forecast.png
  - action: notify.gaselectricity
      message: >-
        Next octopus greenness forcast is {{
        state_attr('binary_sensor.octopus_energy_a_xxxxxxx_greenness_forecast_highlighted',
        'next_start')|as_local()|as_timestamp()|timestamp_custom('%a %b %-d,
        %I:%M %p') }} to {{
        'next_end')|as_local()|as_timestamp()|timestamp_custom('%a %b %-d, %I:%M
        %p') }} - see https://octopus.energy/smart/greener-days
          - /config/screenshots/greenness-forecast.png
mode: single
( notify.gaselectricity sends a message to a signal group )
It would be great to progress this, eg move to an integration and provide a service call instead of REST … I’ve yet to look at how to do this myself.
What I have so far is here GitHub - plord12/webscrapers: Private set of webscrapers for various tasks … at least needs more docs.
I wrote an experimental add-on that can make screenshots of any dashboard or page in the HA UI. home-assistant-addons/puppet at main · balloob/home-assistant-addons · GitHub
It’s around ~10s cold start on a HA Green (has to launch Chrome!). Same page subsequent screenshots are 0.7s, while different pages are 1.5s. Browser will be automatically closed after 30s to release memory.
I am tempted to try this out but I am a little off on the details here.
The URL returned is it returning an image?
What image type?
For example if I wanted to send an mobile notification with a static attachment and in my automation SAVE the image locally first in HA instead of exposing this URL how would I use it?
Any way to have it JUST return a card? I am guessing I could make a single card dashboard for it as a hack.
If you are also exporting HA data to be displayed by grafana you can also use their image export tool.
I know it has different visualization than HA but it is still an option for displaying data.
Ya Graphana and some other tools already do this for email alerts. and Grapfana does integrate into HA I may need to look at it again…
HA is getting so many UI updates this would be kind of a combination of a UI element and a core notification feature, I would still like to see something native to HA.
I’m trying to use this puppet add-on to display some view-only data for a neighborhood well that I maintain. However I’ve discovered that it can only be accessed from any device that it is connected to the local network.
Is there an easy way to have this available to anyone with the link outside of the local network.
It looks like we have a few addons now attempting to do this for individual cards or dashboards.
Seems like this should be a native feature that would be beneficial for both notifications and apparently ESP / low resource E-Ink displays
