Anyone know if there is a way to export all the entity names as a list?
To get a list of all your entities.
Create this notification integration:
- platform: file
filename: /config/www/entity_log.txt
timestamp: false
and this script:
print_entities_to_file:
alias: 'Print Entities To File'
sequence:
- service: notify.entity_log
data_template:
message: >
{% for state in states %}
- {{- state.entity_id -}}
{% endfor %}
If you don’t have a config/www directory. Create one.
Restart.
Then run the script from the Developer tools / Services menu.
The script will create a text file containing all your entities in a format that can later be cut and pasted into your Recorder, Logbook, and History integrations. You can find the file here /config/www/entity_log.txt.
Open the file in your preferred text editor. You should see something like this:
Home Assistant notifications (Log started: 2020-06-15T16:25:14.430437+00:00)
-alarm_control_panel.house
-automation.7pm_abc_news_on_tv
-automation.abb_usage_alert
-automation.acrc_reboot
-automation.addon_update_available
-automation.alarm_away_mode_armed
-automation.alarm_away_mode_arming
-automation.alarm_disarmed
-automation.alarm_triggered
-automation.alarm_warning
-automation.allways_on_device_alert
...etc
Ok, I did that. Something went wrong though. Now I can’t access HA through 8123. I can access Node Red directly through 1880 and appdaemon through 5050. But when I try to access HA through 8123 I just get:
This site can’t be reached
192.168.1.44 refused to connect.
Can you see the logs ?
I couldn’t see anything. The only way I know how to see them would be through the Lovelace UI. I wanted to move the Pi anyway so I just killed it and plugged it back in. Before I did that, I used the FTP addon to edit configuration.yaml to comment out your lines. I realised that might have been my mistake. I just saw that and assumed it went into configuration.yaml.
So, I guess that’s my next question
How do I create a notification integration?
In configuration.yaml :
notify:
- name: notifier_hangouts
platform: hangouts
default_conversations:
- id: UgzeEijx9wzdysrrfx14AaABAagBgbmCCw
- platform: file
timestamp: false
Cool. I’ll try that. Before I do… if it goes FUBAR, is there a way to restart HASS without just pulling the plug on the Pi if I don’t have access to the UI? SSH seems to be disabled.
Perfect! That’s done the trick, thank you!
I would also like a list of entities. Where do I place that information?
edit: I figure it out - it goes under notify: in the configuration.yaml as per File - Home Assistant
So I had it set as
notify:
- platform: file
timestamp: false
This has stopped working for me, anyone else?
I’m getting this when tying to call the service…
Failed to call service notify/entity_log. required key not provided @ data['message']
This script will work without the error.
alias: Print Entities To File
sequence:
message: "{% for state in states %}\n - {{- state.entity_id -}}\n{% endfor\
\ %}\n"
mode: single
That worked, thanks!
I’m trying to export the info that you can find when clicking under “entities” in configuration.
In other words, a table file with
Name, Entity_id, Integration, Area, Status
Sadly that web page is not exportable, or selectable, not even printable.
Is that possible?
I cannot find how to call the “integration” info such as “Deconz”, “Tuya”, etc.
{{ state.domain, state.entity_id, state.object_id, state.name, }}
{%- endfor -%}
Edit: after discussing on Discord, it seems this is simply not possible using tempaltes as the data is not available there.
I solved my issue with the next trail below
I’m almost scared to explain how I did this in 30 seconds (since I didn’t use code but brute forced it somehow)… but
- Open the file \config.storage\core.entity_registry (I’m on rpi4 / Hassio supervised - did this via Samba)
- Copy all the text and pasted in this random json to table converter…
VoilĂ . A beautiful table with everything posiible
Edit: This is the list of data field available in this file:
entity_id
config_entry_id
device_id
area_id
unique_id
platform
name
icon
disabled_by
supported_features
device_class
unit_of_measurement
original_name
original_icon
capabilities/hvac_modes/0
capabilities/hvac_modes/1
capabilities/max_temp
capabilities/min_temp
capabilities/preset_modes/0
capabilities/preset_modes/1
capabilities/preset_modes/2
capabilities/preset_modes/3
capabilities/preset_modes/4
capabilities/source_list/0
capabilities/source_list/1
capabilities/min_mireds
capabilities/max_mireds
capabilities/effect_list/0
capabilities
This is fantastic, just what I was looking for. Thanks so much!
This worked so good, I want to do the same for devices rather than entities. I tried changing this around like so:
In the config:
notify:
- platform: file
filename: /config/www/device_log.txt
timestamp: false
script:
print_devices_to_file:
alias: '2.) Print Devices To File'
sequence:
- service: notify.device_log
data_template:
message: >
- {{- state.device_id -}}
{% endfor %}
put all I received was a list of dashes. I am assuming this section:
{% endfor %}
is incorrect but not sure what to use instead? Can anyone assist?
There is a much simpler solution.
Simply navigate to Dev tools>> Template and paste below
^ {{- state.name -}}
{% endfor %}
The resukt will be shown at right side. You can copy paste into excel and use text to columns to split using ^ symbol for ID and Name and find replace to remove leading - on the entity. Boom - you will have a neat excel in less than a minute
Another option…
With ssh set up its straightforward to access the entities from a terminal on your PC, at home I’m using Linux (Fedora) - any Linux would do. For example:
kiat@fedora:~ ?} ssh ha "cat /config/.storage/core.entity_registry | awk '\$1 ~ /entity_id/ {print \$2}' | sed 's/\(\"\|,\)//g' | sort | egrep ^switch" | tail
switch.wled_island_sync_send
switch.wled_porch_nightlight
switch.wled_porch_reverse
switch.wled_porch_sync_receive
switch.wled_porch_sync_send
switch.wled_utility_nightlight
switch.wled_utility_reverse
switch.wled_utility_sync_receive
switch.wled_utility_sync_send
switch.zbbridge
and
{kiat@fedora:~ ?} ssh ha "cat /config/.storage/core.entity_registry | awk '\$1 ~ /entity_id/ {print \$2}' | sed 's/\(\"\|,\)//g' | sort | egrep ^binary_sensor" | tail
binary_sensor.watersensor_wc_water_leak
binary_sensor.wled_bench_firmware
binary_sensor.wled_hall_firmware
binary_sensor.wled_island_firmware
binary_sensor.wled_porch_firmware
binary_sensor.wled_utility_firmware
binary_sensor.yard_all_occupancy
binary_sensor.yard_person_occupancy
binary_sensor.zigbee2mqtt_running
binary_sensor.zigbee2mqtt_update_available
where I’m using “tail” to truncate, but any prefered output of data is available by tweaking the “awk” and “sed” commands.
