Is there a way to export the list of Entities from your HA to a file?
It would be nice to be able to get a list of all your entities to import into an Excel file, database, etc., so that you can organize them outside of HA.
it has to work… open Home Assistant in your browser (e.g., http://homeassistant.local:8123), go to console .. paste this full script into console..
function downloadEntitiesCSV() {
const hass = document.querySelector('home-assistant').hass;
const entities = hass.entities;
const sorted = Object.values(entities).sort((a, b) => {
const idA = a.entity_id?.toLowerCase() || '';
const idB = b.entity_id?.toLowerCase() || '';
return idA.localeCompare(idB);
let csvContent = "ENTITY ID,NAME,PLATFORM\n";
sorted.forEach(entity => {
const entity_id = entity.entity_id || '';
const name = entity.name || '';
const platform = entity.platform || '';
csvContent += `"${entity_id}","${name}","${platform}"\n`;
const blob = new Blob([csvContent], { type: "text/csv;charset=utf-8;" });
const url = URL.createObjectURL(blob);
const link = document.createElement("a");
link.setAttribute("href", url);
link.setAttribute("download", "hass_entities.csv");
document.body.appendChild(link);
link.click();
document.body.removeChild(link);
then type and run..
downloadEntitiesCSV();
file hass_entities.csv will automatically download to your system
Uh huh. So That screenshot I made is a hallucination.
No thanks.
Worked after a cache clear. Odd.
@VietNgoc is Console the same at Terminal?
No:
I’m sorry. What is a Web Browser Inspector? Can you take a snapshot of it and post it? I do not see it in my copy of HA.
check How to open DevTools in the browser and console section…
Hej @VietNgoc ;
works fine and it’s helpful… Thanks for that…
I need some more informations in the CSV-Table… I tried to add my points, but it doesn’t work.. I ask the KI as i am not famliar in coding JS.
Maybe you are so kind to check my Code made by KI? It based on your code here.
I “only” want to add and want it in this order “Entität”, “Entität-ID”, “Device”, “Area”, “Integration”, “Status”…
async function downloadEntitiesCSV() {
// Home Assistant-Objekt mit allen Entitäten holen
// Asynchrone Abfrage der Device Registry und Area Registry von Home Assistant
const devices = await hass.connection.sendMessagePromise({
type: "config/device_registry/list"
const areas = await hass.connection.sendMessagePromise({
type: "config/area_registry/list"
// Hilfsobjekte zur schnellen Zuordnung von device_id bzw. area_id zu Namen
const deviceNameById = {};
devices.forEach(device => {
deviceNameById[device.id] = device.name || device.name_by_user || '';
const areaNameById = {};
areas.forEach(area => {
areaNameById[area.area_id] = area.name || area.name_by_user || '';
// Sorted Array aller Entities nach entity_id alphabetisch sortiert
// CSV-Header mit gewĂĽnschten Spalten
let csvContent = "Entität,Entity ID,Gerät,Bereich,Integration,Status,Platform\n";
// Jede Entität zur CSV hinzufügen
// Friendly Name (menschlich lesbarer Name)
const friendlyName = entity.attributes?.friendly_name || '';
// Entity ID (eindeutige ID in HA)
const entityId = entity.entity_id || '';
// Geräte-Name aus Device Registry, basierend auf context.device_id
const deviceId = entity.context?.device_id || '';
const device = deviceNameById[deviceId] || '';
// Bereichs-Name aus Area Registry, basierend auf area_id des Geräts
const deviceAreaId = devices.find(d => d.id === deviceId)?.area_id || '';
const area = areaNameById[deviceAreaId] || '';
// Integration – benutzt platform-Zuweisung als Proxy
const integration = entity.integration || entity.platform || '';
// Status = aktueller Zustand der Entität (z.B. on, off)
const status = entity.state || '';
// Platform (mqtt, zwave, template...)
// Zeile fĂĽr CSV
csvContent += `"${friendlyName}","${entityId}","${device}","${area}","${integration}","${status}","${platform}"\n`;
// CSV-Datei als Blob erzeugen
// Download-URL erzeugen und Klick auf unsichtbaren Link simulieren
link.click();
And this is the result:
Here is a modified version with additional info…
function generateEntityItems() {
const hass = document.querySelector("home-assistant").hass;
let csvContent = "ENTITY ID,ENTITY NAME,DEVICE NAME, DEVICE ID, AREA,PLATFORM (INTEGRATION),STATE,FORMATED STATE\n";
sorted.forEach((ent) => {
const eId = ent.entity_id;
const stateObj = hass.states[eId];
const entityName = hass.formatEntityName(stateObj, "entity");
const deviceName = hass.formatEntityName(stateObj, "device");
const deviceId = ent.device_id;
const areaName = hass.formatEntityName(stateObj, "area") || '';
const platform = ent.platform || '';
const state = stateObj.state;
const formatedState = hass.formatEntityState(stateObj);
const info = [eId, entityName, deviceName, deviceId, areaName, platform, state, formatedState].join(", ");
csvContent += `${info}\n`;
link.click();
This still seems a lot easier:
Problem is that working with the browsers console is such an uncomfortable way for such a neat thing I would simply surround it by something like this.
type: custom:button-card
name: Export my Entitys as CSV
tap_action:
action: execute-a-js-function
the_js_function: |
# paste the function in here
generateEntityItems();
and you got a nice button on your dash which allows you to simply generate that list without using opening the devtools console paste the whole lot and close that view afterwards.
I do love your function as I do love that I could define tap_actions named to whatever I like. ![]()
@anon11644107 ,
thank you for your thoughts and your Code line…
But how can i expand the list with some more details for the devices, integration, status? Where do i find the keywords for those?
I tried this, but it doesn’t work?
Hej @VietNgoc ,
thank you sooo much… That works fine for me and give me so much support…
Only a question please… How did you get the right variables for the Columns? Where did you get the correct variable names for the columns to be listed? You have to tell the script which “drawers” to look in to get the values. Where can I look them up if I have further requests?
And again… You made my Day… Thanks
@justone ,
thanks for your support… I will try this to have more comfort way on creating my list…
I’m new here. Where do I “simply surround” the function with your code? Template editor? Terminal? A file somewhere?
Thanks.
The custom button card is a card to be placed in the dashboard.
You have to install it from HACS since it’s a custom card.
And the example is sort of the most raw configuration of that card without any fancy fonts , colors, fancy buttons or such like.
You simply paste the function @VietNgoc posted some posts earlier between the rectangle brackets, that’s it.
You’ll then find a small card with a title “Export my Entitys as CSV” in your dashboard and once you pressed the card (button) the file gets saved.
