Expose /dev entries on ODROID for Rockchip ffmpeg acceleration
I run the Scrypted Add-On on an ODROID M1S, which has a Rockchip chipset. Scrypted provides a Rockchip Essentials plug-in that enables hardware accelerated ffmpeg. According to this blog, you need access to several /dev entries that HAOS does not expose. (The blog is for a different board but similar chipset.) We can see which entries need to be present in the Docker configuration section. It says to map the following entries:
"/dev/dri:/dev/dri",
"/dev/dma_heap:/dev/dma_heap",
"/dev/rga:/dev/rga",
"/dev/mpp_service:/dev/mpp_service",
3 of those are not exposed by HAOS. They’re not in the /dev tree at all.
If HAOS were to expose those /dev entries at the Linux level, we should be able to pass them through to Scrypted and setup Rockchip ffmpeg hardware acceleration in the plugin.
Hi gregatron,
Welcome to the HA Forum!
Reminder for you.
