I have 2 zwave temperature values which are sent on KNX and which is used afterwards for the heating controllers KNX MDT AKH 0800.03.
I use the expose feature to send them on KNX but they are sent only once even if the zwave temperature is changing.
I am using the following configuration:
Main HA in a docker where I have the KNX configuration of the entire home
I use a Raspberry where I connect the 2 Zwave sensors.
In the docker I see the temperature coming the RPI changing every 5 minutes.
But on KNX, I see it only once. The issue is that the MDT Heating controller go in emergency after several minutes because it doesn’t get a temperature value. It’s confirmed because as soon as I update the YAML configuration from the docker, the temperature value is sent once on KNX and then the heating controller is no more in emergency.
Any idea where it’s coming from ?
Here is the expose configuration:
type: temperature
entity_id: sensor.zwave_trisensor_air_temperature
address: “4/1/15”
cooldown: 2
Thanks for the answer. Yes the value is updated on the Raspberry where the zwave sensor is connected and also in the Docker where I get back the the zwave sensor value through the remote-assistant function.
How can I send through the automation a value from a sensor coming either from zwave or knx every x minute to KNX ?
Sorry I never used the automation and the KNX services.
