I see quite a few people ask about exposing Home Assistant Entities to KNX. Assuming you have a working KNX integration, this is what I have done with a few examples:
- Add the following line into your config.yaml.
knx:
expose: !include knx_expose.yaml
Create a file expose.yaml in the same directory as your config.yaml file
Use the following format.
You can test the exposure using ETS Group monitor (ETS5 in my case). For record keeping and maintenance purposes I have also added the new “expose” groups into ETS. Specify the correct KNX Data Point Types, especially for complex readings as below:
knx_expose.yaml:
#---------------Smart Meter----------------------------------
- type: 'DPT-14.056'
entity_id: sensor.smart_meter_electricity_power
address: "7/0/0"
#---------------Tesla PowerWall------------------------------
- type: 'DPT-5.001'
entity_id: sensor.home_energy_gateway_charge
address: "7/2/0"
#---------------Solar Thermal C21 Resol----------------------
- type: 'temperature'
entity_id: sensor.temperature_sensor_1_2
address: "7/1/0"
entity_id: sensor.temperature_sensor_2_2
address: "7/1/1"
entity_id: sensor.temperature_sensor_3_2
address: "7/1/2"
entity_id: sensor.temperature_sensor_4_2
address: "7/1/3"
- type: 'DPT-5.001'
entity_id: sensor.pump_speed_relay_1_2
address: "7/1/4"
- type: 'DPT-13.010'
entity_id: sensor.heat_quantity_2
address: "7/1/5"
