I have my Hassio installed directly in Virtual Box on my Windows 10 pc and I’m getting this in the virtual box windows.
EXT4-fs (sda8): error count since last fsck: 9
EXT4-fs (sda8): initial error at time 1551781258: ext4_mb_generate_buddy:747
EXT4-fs (sda8): last error at time 1552119080: ext4_mb_generate_buddy:747
I keep seeing it it every so often in the window with the only difference being at time number.
Is this anything I should be concerned about?
It don’t seem to be having negative affect at least not that I’ve seen.
I am getting this error too and it stalls my system big time. Sometime it never comes back up.
Interestingly enough I only run into this problem if I Reboot the Host system (Hass.io - System -Host System - Reboot.
If I do a shutdown and then restart the VM, it boots up no problem.
