I got some Eurotronic Spirit Z-Wave thermostat. They are working with the climate component fine.
Now i like to go a step further. I’ve got also a lot of temperature sensors in different devices. I like to combine them with a template to on temperature sensor. These new template should be the current temperature for my thermostat, so that the device should set the temperature correctly.
Is this possible to setup something like this? The template sensor shouldn’t be the problem, but override the current temp for my thermostat.
I’ll hope you understand what i mean.
Cheers.
