Bieniu
(Maciek)
November 17, 2017, 8:48am
1
Some Z-Wave radiator thermostats like Danfoss 014G0013 don’t report the temperature to the controller and Home Assistant displays the current temperature as none. I wrote a small python script that takes the temperature value from the specified sensor and fills the thermostat state with each thermostat and temperature change.
This isn’t an elegant solution but it works. Maybe someday someone with real python skills will add this feature to the climate/zwave component.
Download script
thermostat_id = data.get('thermostat')
sensor_id = data.get('sensor')
if thermostat_id != "" and sensor_id != "":
sensor = hass.states.get(sensor_id)
temp = sensor.state
if temp is not None and temp is not "Unknown":
thermostat = hass.states.get(thermostat_id)
attributes = thermostat.attributes.copy()
attributes['current_temperature'] = temp
hass.states.set(thermostat_id, thermostat.state, attributes)
else:
logger.error("Wrong data.")
To run this script you have to use service python_script with thermostat and sensor entity_id as data.
service: python_script.thermostat_current_temp
thermostat: climate.thermostat_kuchnia_heating_1
sensor: sensor.temperature_kuchnia
In my configuration I have names of sensors and thermostats according to the pattern:
climate.thermostat_NAME_OF_THE_ROOM_heating_1
sensor.temperature_NAME_OF_THE_ROOM
that’s why I could apply quite simple automation to the script:
- id: heating_update_current_temperature
alias: 'Heating Update Current Temperature'
platform: state
entity_id:
- sensor.temperature_antek
- sensor.temperature_salon
- sensor.temperature_kuchnia
- sensor.temperature_antresola
- sensor.temperature_sypialnia
- sensor.temperature_lazienka
- climate.thermostat_antek_heating_1
- climate.thermostat_kuchnia_heating_1
- climate.thermostat_salon_heating_1
- climate.thermostat_antresola_heating_1
- climate.thermostat_sypialnia_heating_1
- climate.thermostat_lazienka_heating_1
condition:
condition: template
value_template: >-
{% if "thermostat" in trigger.entity_id and trigger.to_state.attributes.current_temperature == none %}
true
{% elif "sensor" in trigger.entity_id %}
true
{% else %}
false
{% endif %}
data_template:
thermostat: >-
{% if "thermostat" in trigger.entity_id %}
{{ trigger.entity_id }}
{% else %}
climate.thermostat_{{ trigger.entity_id | replace('sensor.temperature_', '') }}_heating_1
{% endif %}
sensor: >-
{% if "sensor" in trigger.entity_id %}
{% else %}
sensor.temperature_{{ (trigger.entity_id | replace('climate.thermostat_', '')) | replace('_heating_1', '') }}
{% endif %}
- id: heating_update_current_temperature_at_start
alias: 'Heating Update Current Temperature At Start'
platform: homeassistant
event: start
- service: python_script.thermostat_current_temp
thermostat: climate.thermostat_antek_heating_1
sensor: sensor.temperature_antek
thermostat: climate.thermostat_salon_heating_1
sensor: sensor.temperature_salon
thermostat: climate.thermostat_antresola_heating_1
sensor: sensor.temperature_antresola
thermostat: climate.thermostat_sypialnia_heating_1
sensor: sensor.temperature_sypialnia
thermostat: climate.thermostat_lazienka_heating_1
sensor: sensor.temperature_lazienka
And this is the resault:
Great work! Will this make HA control the valve of the LC-13 to reach the desired target temperature by comparing with the input from the defined external temp-sensor?
pappajohan
(Pappajohan)
November 22, 2017, 10:08pm
3
Great! I felt really stupid when I realized the temperature wasn’t reported, now a lot less so!
Pity, homebridge wasn’t fooled though…
/Johan
Bieniu
(Maciek)
November 22, 2017, 10:27pm
4
No, the script only adds a temperature value from sensor to the thermostat current_temperature attribute. The thermostat works completely alone on the basis of its own temperature measurements and HA can’t interfere with it beyond the target temperature change.
Bieniu
(Maciek)
November 22, 2017, 10:30pm
5
jan6en6tig
(jan6en6tig)
December 15, 2017, 11:23am
6
Did you already found a solution to get the current temp. in homebridge? I have the same problem.
pappajohan
(Pappajohan)
January 20, 2018, 12:22am
7
Sort of. I have a Telldus znet for my 433 devices. I moved my Danfoss there, used this https://forum.telldus.com/viewtopic.php?f=31&t=6587&sid=36ba247e7b019d9e12f3480f92df5b0a&start=15 and hass generic thermostat. Works perfect, but I believe @Bieniu idea is better still.
/Johan
Bieniu
(Maciek)
March 4, 2018, 9:26am
8
If someone prefers a script for AppDaemon then you can use this .
It also changes the thermostat status “unknown” to “heat” or “idle” depending on the target temperature.
That’s great! How can i use it? I get the following error; 2018-03-06 18:58:53.606731 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/update_thermostats.py - ignoring
I added the .py script in the config\appdaemon\apps folder and restarted appaemon?
Thank you!
Bieniu
(Maciek)
March 6, 2018, 6:33pm
10
You have to add to apps.yaml thermostats and sensors entities. The order of thermostats and sensors is important. The first thermostat takes data from the first sensor, the second thermostat from the second sensor, etc.
update_thermostats:
module: update_thermostats
class: UpdateThermostats
thermostats:
sensors:
Thanks for your help Bieniu,
I’ve changed the apps.yaml with the correct name of the LC-13 and one of my temp sensors, but get the following error;
2018-03-07 08:12:41.236338 WARNING AppDaemon: ------------------------------------------------------------
2018-03-07 08:12:41.237605 WARNING AppDaemon: Unexpected error running initialize() for update_thermostats
2018-03-07 08:12:41.238701 WARNING AppDaemon: ------------------------------------------------------------
2018-03-07 08:12:41.242663 WARNING AppDaemon: Traceback (most recent call last):
File "/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 1495, in init_object
init()
File "/config/appdaemon/apps/update_thermostats.py", line 12, in initialize
if self.check_entity(self.args['thermostats'][i]) == False:
File "/config/appdaemon/apps/update_thermostats.py", line 63, in check_entity
while not (self.entity_exists(entity) or n > 120):
AttributeError: 'UpdateThermostats' object has no attribute 'entity_exists'
2018-03-07 08:12:41.243686 WARNING AppDaemon: ------------------------------------------------------------
update_thermostats:
thermostats:
- climate.danfoss_z_thermostat_014g0013_heating_1
sensors:
- sensor.fibaro_system_fgsd002_smoke_sensor_temperature
Bieniu
(Maciek)
March 7, 2018, 7:35am
12
Very strange. Which version of AppDaemon do you use?
I’m using version 3.0, should i try 2.0?
Bieniu
(Maciek)
March 7, 2018, 8:02am
14
Honestly, I don’t know what changes were introduced in 3.0. I use 2.1.12. If you can try version 2.x.
cgtobi
(Tobi)
March 7, 2018, 8:32am
15
I use it with 3.0 and it works great. I made a few changes to fit my needs but the changes are only minor. As the lines in your errors don’t seem to match the most recent version on github, could you pastebin your version to get a better insight?
cgtobi
(Tobi)
March 7, 2018, 9:17am
16
@Bieniu great work by the way. I just “upgraded” to your most recent version from github and implemented my changes.
Bieniu
(Maciek)
March 7, 2018, 9:53am
17
@cgtobi I’m curious what changes you made?
cgtobi
(Tobi)
March 7, 2018, 10:10am
18
@Bieniu sure, no problem. I only made it work with 3.0 and slightly modified the behaviour when the thermostat displays idle or heat .
1c1
< import appdaemon.appapi as appapi
> import appdaemon.plugins.hass.hassapi as hass
27c27
< class UpdateThermostats(appapi.AppDaemon):
> class UpdateThermostats(hass.Hass):
53c53
< self.find_thermostat_state(float(target_temp))
> self.find_thermostat_state(float(target_temp), float(sensor_temp))
68c68
> self.find_thermostat_state(float(target_temp), float(current_temp))
73,74c73,74
< def find_thermostat_state(self, temperature):
< if temperature > 8:
> def find_thermostat_state(self, target_temp, current_temp):
> if round(current_temp) < round(target_temp):
87a88
Just to double check: are you talking about this ‘unknown’ state?
