Shared in case it’s useful to anyone wanting to see how to deal with complex XML and the REST integration.
My HP printer makes a lot of data available via XML. I use this to pull ink levels more precisely than available via the HP printer integration. Here’s a snippet of the XML with a lot of surplus sections removed:
<!-- THIS DATA SUBJECT TO DISCLAIMER(S) INCLUDED WITH THE PRODUCT OF ORIGIN. -->
<pudyn:ProductUsageDyn xmlns:dd="http://www.hp.com/schemas/imaging/con/dictionaries/1.0/" xmlns:dd2="http://www.hp.com/schemas/imaging/con/dictionaries/2008/10/10" xmlns:pudyn="http://www.hp.com/schemas/imaging/con/ledm/productusagedyn/2007/12/11" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.hp.com/schemas/imaging/con/ledm/productusagedyn/2007/12/11 ../schemas/ProductUsageDyn.xsd">
<dd:Version>
<dd:Revision>SVN-IPG-LEDM.119</dd:Revision>
<dd:Date>2010-08-31</dd:Date>
</dd:Version>
<pudyn:PrinterSubunit>
<dd:TotalImpressions PEID="5082">13647</dd:TotalImpressions>
<dd:MonochromeImpressions>5513</dd:MonochromeImpressions>
<dd:ColorImpressions>8134</dd:ColorImpressions>
*** loads of irrelevant stuff removed ***
</pudyn:PrinterSubunit>
<pudyn:ConsumableSubunit>
<pudyn:Consumable>
<dd:MarkerColor>Magenta</dd:MarkerColor>
<dd:ConsumableTypeEnum>ink</dd:ConsumableTypeEnum>
<dd2:CumulativeConsumableCount>5</dd2:CumulativeConsumableCount>
<dd:A4EquivalentImpressions>
<dd:TotalImpressions>13629.0</dd:TotalImpressions>
<dd:MonochromeImpressions>5513.0</dd:MonochromeImpressions>
<dd:ColorImpressions>8116.0</dd:ColorImpressions>
</dd:A4EquivalentImpressions>
<dd:ConsumableRawPercentageLevelRemaining>42</dd:ConsumableRawPercentageLevelRemaining>
*** lots more magenta stuff removed **
</pudyn:Consumable>
<pudyn:Consumable>
<dd:MarkerColor>Cyan</dd:MarkerColor>
... and so on
As you can see, the cartridge information is available under ['pudyn:ProductUsageDyn']['pudyn:ConsumableSubunit'] under a separate ['pudyn:Consumable'] for each cartridge: magenta first (['dd:MarkerColor']), then cyan, yellow and black.
I didn’t want to assume that the cartridge data is always in this order, so I needed to read through all the pudyn:Consumable elements to find the one I wanted. Luckily, value_json['foo'] returns a list of foo elements if more than one is available.
Most of the REST examples in the documentation create a lot of attributes on a single sensor, whereas I wanted separate sensors for each measurement — whilst only reading the XML from the printer once.
Here is my REST sensor configuration (via a rest: !include in configuration.yaml) that pulls out page counts, ink usage (not visible in the XML above) and cartridge level and how many the printer has used (cyan only shown, other colours are the same config with the colour name replaced):
- resource: http://192.168.1.9/DevMgmt/ProductUsageDyn.xml
scan_interval: 86400
- name: "Printer total page count"
value_template: "{{ value_json['pudyn:ProductUsageDyn']['pudyn:PrinterSubunit']['dd:TotalImpressions']['#text'] }}"
unit_of_measurement: "pages"
- name: "Printer colour page count"
value_template: "{{ value_json['pudyn:ProductUsageDyn']['pudyn:PrinterSubunit']['dd:ColorImpressions'] }}"
- name: "Printer monochrome page count"
value_template: "{{ value_json['pudyn:ProductUsageDyn']['pudyn:PrinterSubunit']['dd:MonochromeImpressions'] }}"
- name: "Lifetime ink usage"
value_template: "{{ value_json['pudyn:ProductUsageDyn']['pudyn:PrinterSubunit']['pudyn:UsageByMarkingAgent']['dd2:CumulativeMarkingAgentUsed']['dd:ValueFloat'] }}"
unit_of_measurement: "ml"
- name: "Cyan cartridge level"
value_template: "{{ ((value_json['pudyn:ProductUsageDyn']['pudyn:ConsumableSubunit']['pudyn:Consumable'])|selectattr('dd:MarkerColor','eq','Cyan')|first)['dd:ConsumableRawPercentageLevelRemaining'] }}"
unit_of_measurement: '%'
- name: "Cyan cartridge count"
value_template: "{{ ((value_json['pudyn:ProductUsageDyn']['pudyn:ConsumableSubunit']['pudyn:Consumable'])|selectattr('dd:MarkerColor','eq','Cyan')|first)['dd2:CumulativeConsumableCount'] }}"
I refresh this once per day in the sensor config, but I also have a pretty good idea of when it’s printing as it shares a UPS with my NAS, and causes a spike in UPS load which I use to trigger an update via this automation:
- alias: "Printer - update sensors"
description: >
Updates printer REST data when UPS load suggests printing
or when page count increases (ongoing job).
- platform: numeric_state
entity_id: sensor.ups_load
above: '10'
- platform: state
entity_id: sensor.printer_total_page_count
- delay: 60
- service: homeassistant.update_entity
