F1 Marshal Panel for F1 Sensor for Home Assistant
I built a small project that simulates an F1 marshal LED panel using an ESP8266 (ESP-01) and a WS2812B 8×8 LED panel . The panel is connected to Home Assistant and automatically displays the current track status from the entity sensor.f1_session_track_status .
The goal of the project was to create a decorative but also functional panel that reacts to the track status during a race, similar to the real panels used in Formula One.
Panel functions
  • CLEAR – green light (automatically turns off after 10 seconds)
  • YELLOW – yellow warning pattern
  • RED – red flashing
  • SC (Safety Car) – white SC letters with a rotating amber beacon cone around the panel border
  • VSC (Virtual Safety Car) – alternating V and SC letters with an amber frame
The panel also includes several additional features:
  • a boot animation when the device starts
  • a brightness slider in Home Assistant (10–70%)
  • automatic shutdown if no data is received from Home Assistant for 30 seconds
  • test buttons in Home Assistant for manually triggering all effects
Hardware
  • ESP8266 ESP-01
  • WS2812B 8×8 LED panel (64 LEDs)
  • 5V power supply
The LED matrix is addressed as a serpentine 8×8 panel .
Software
The firmware is written in ESPHome , and the track status is received directly from Home Assistant through the sensor:
All visual effects are implemented using the addressable_lambda feature to control each LED individually.
Project idea
While watching races, I wanted a small panel that visually shows the current track status in real time, similar to the marshal panels used around the circuit during Formula 1 events.
The result is a small F1 marshal panel simulator that integrates nicely into a smart-home setup.
If anyone is interested in the project, code here:
https://github.com/SimovicTV/F1-Marshal-Panel/tree/main
Many thanks to Stimo Niklas for the Formula 1 Racing Sensor .
That sounds amazing! Could you share some pictures or a short GIF showing how it looks?
youtube.com/watch?v=b7yZkRVkAVU&list=PLcgkxnzxYX_oOi6DiXRhTfannxMqxtdbX&index=3
It’s a bit hard to see; I wasn’t sure how to make it better.
New YAML code. Corrected error in the text sensor, that it takes data from HA, and other minor changes and optimizations
Nice!!!
Would be nice to have these animations included in the blueprint to send to existing wled panels.
I do have a wled panel, but don’t want to reflash the esp just for this :slight_smile:
:vertical_traffic_light: F1 Marshal Panel – Version 2.0 :chequered_flag:
After a lot of testing, tweaking, and feedback, I’m happy to share Version 2.0 of my DIY F1 Marshal Panel project.
This version is a major upgrade over the original — both visually and functionally.
:wrench: Hardware
  • 16×16 WS2812 LED matrix
  • ESP8266 (Wemos D1 Mini)
  • Powered and controlled via ESPHome + Home Assistant
:rocket: What’s new in Version 2.0
  • :chequered_flag: New FINISHED mode
    Clean 4×4 checkered flag animation with smooth fade transitions, optimized for low-resolution panels.
  • :police_car_light: Improved Safety Car (SC)
    Static white “SC” with 4 independent moving “snakes” around the border (extended length for smoother motion).
  • :yellow_circle: Virtual Safety Car (VSC)
    Constant yellow border + blinking white “VSC” text.
  • :green_circle: CLEAR logic fixed
    Green signal now turns off correctly after 5 seconds (no more stuck state).
  • :red_circle: RED & YELLOW refined
    Better timing and visual clarity.
  • :light_bulb: Brightness control
    Adjustable directly from Home Assistant.
  • :video_game: Built-in TEST buttons
    Trigger every state manually (CLEAR / YELLOW / RED / SC / VSC / FINISHED).
  • :brain: Smart HA integration
    • sensor.f1_track_status
    • sensor.f1_session_session_status
    • Automatic reaction to session finish
:gear: Behavior
  • Panel automatically reacts to live F1 data from Home Assistant
  • FINISHED mode overrides all other states (30 seconds runtime)
  • System is stable, responsive, and designed for real-time use
:bullseye: Goal
The main idea was to create a portable, standalone F1 marshal-style panel that:
  • works reliably
  • looks clean even on a 16×16 matrix
  • can be easily integrated or taken anywhere
If anyone is building something similar or has ideas for further improvements, I’d love to hear feedback!
:chequered_flag: Version 2.0 is just the beginning.
YAML file HERE
f1master (3)
That is cool!
Awesome mate, is it possible to setup flashing lights within HA just so they are displayed on the HA screen? Would be cool to have these as a banner within a F1 HA dashboard.
