Earlier, I raised the question of how to create my own custom model and I finally figured it out. And since there is no normal and simple instruction, I decided to do it. How do I create my own custom model for recognizing something? This can be recognition of what a person is doing, laughing, riding a bike, lying down, running, a courier has arrived, and so on.
Photos taken from here
What do people do?
Fighting
Running
Eating
Brief video tutorial on creating your own recognition model. It will not be easy to understand it right away, so I will do it step by step and in the screenshots
For a visual understanding, I will show by my example how I have set up a custom DeepStack model in Synology
The path to the custom model is specified by your docker/Deepstack/custom models/ /modelstore/detection
Add 4 lines and set True
VISION-FACE - face recognition
VISION-DETECTION - object recognition
VISION-SCENE - scene recognition
MODELSTORE-DETECTION - recognition of user models
Let’s check if there is a modelstore folder and a detection subfolder, if there are none, then you need to create one. Open the terminal of our DeepStack_Server container, click on “Create”, then the “bash” button will appear and enter the command in the console. That’s why I use MC and installed MC with the apt install mc command. You can simply create folders with the command
$ mkdir /modelstore/detection
This is how the modelstore folder and the detection subfolder should look like, where our custom models for recognition will be located
This is how access from samba will look like
The log should display our custom models uploaded to the folder. You need to load it when the container is turned off
This completes the configuration of the DeepStack server container.
Putting the integration HASS Deepstack object and in the config we add the line custom_model
image_processing:
- platform: deepstack_object
ip_address: #we specify the IP address of the deepstack server
port: #specifying the port of the deep stack server
custom_model: courier #here we specify the name of our custom model
confidence: 60
save_file_folder: /config/www/deepstack/snapshots/
save_timestamped_file: True
always_save_latest_file: True
source:
- entity_id: camera.eufy_camera
targets:
- target: person
confidence: 60
- target: animal
confidence: 50
- target: other
confidence: 50
This is how user model recognition looks like
Creating our own custom model
Download the labeling program from here. The labeling program instructions can be read here
We create two folders test and train, they can be anywhere, it is important that they are in one place
Open the program and select the train folder with the images that we will work with. Next, we select the objects we need and assign them names.
Before moving on to the next image, you need to save it, and then move on to the next picture
After each save, text files with exactly the same name as the graphic file will be created
After you have processed the image and everything is saved in the train folder, copy all the contents to the test folder. We will have the same files in two folders
We make an archive file of two folders and call it whatever you like, for example mask-dataset.zip
Now we need to run this whole thing either in Training on Google Colab with Free GPUS, or raise your server according to this instructions. I collected through Training on Google Colab with Free GPUS
Click on the “Folder” icon
Let’s upload our archive file mask-dataset.zip
Let’s start the installation of DeepStack Trainer by clicking on the button, then click on “Run” and wait for the installation of DeepStack Trainer to end
After successful installation of DeepStack Trainer, the deepstack-trainer folder will appear
Unzip our mask-dataset file.zip to the /content folder with the command
!unzip /content/mask-dataset.zip -d /content/mask-dataset
We start the training and wait for the full completion of the process, it may take a long time to wait
!python3 train.py --dataset-path "/content/mask-dataset"
The process was successful, we are waiting further until Epoch 299/299
This is how the completed process looks like, after which we download the finished file to ourselves and name it as you like. I called him courier.pt . After that, we stop the DeepStack container and throw this file courier.pt to the /modelstore/detection folder
We launch the container and a custom recognition model starts working for us. That’s it.
Текст на русском (Text in Russian)
Ранее поднимался мною вопрос как создать свою пользовательскую модель и я наконец-то разобрался в этом. А так как нет нормальной и простой инструкции, то я решил это сделать. Как создать свою пользовательскую модель для распознавания чего либо? Это может быть распознавание что делает человек, смеется, едет на велосипеде, лежит, бежит, пришел курьер и так далее.
Фото взяты от сюда
https://github.com/OlafenwaMoses/Action-Net
Что делают люди?
Дерутся
Бегают
Едят
Краткая видеоинструкция по созданию своей модели распознавания. Ее понять сразу будет не просто, поэтому я сделаю пошагово и на скриншотах
Для наглядного понимания я покажу на своем примере, как у меня настроена пользовательская модель DeepStack в Synology
Путь к пользовательской модели указан свой docker/Deepstack/custom models/ /modelstore/detection
Добавляем 4 строки и ставим True
VISION-FACE - распознавание лиц
VISION-DETECTION - распознавание объектов
VISION-SCENE - распознавание сцен
MODELSTORE-DETECTION - распознавание пользовательских моделей
Проверим есть ли папка modelstore и подпапка detection, если их нет, то нужно создать. Открываем терминал нашего контейнера DeepStack_Server, нажимаем на “Создать”, далее появится кнопка “bash” и в консоли вводим команду. Я использую MC поэтому и установил MC командой apt install mc. Можете просто создать папки командой
Вот так должна выглядеть папка modelstore и подпапка detection, где будут лежать наши пользовательские модели для распознавания
Так будет выглядеть доступ с samba
В журнале должны отобразиться загруженные в папку наши пользовательские модели. Загружать нужно при выключенном контейнере
На этом настройка контейнера DeepStack server закончена.
Ставим интеграцию HASS Deepstack object и в конфиге добавляем строчку custom_model
image_processing:
ip_address: #указываем IP адрес сервера deepstack
port: #указываем порт сервера deepstack
custom_model: courier #тут указываем название своей пользовательской модели
confidence: 60
source:
targets:
- target: person
confidence: 60
- target: animal
confidence: 50
- target: other
confidence: 50
Так выглядит распознавание пользовательской модели
Создаем свою пользовательскую модель
Скачиваем программу labelImg отсюда. Инструкцию по программе labelImg можно прочитать здесь
Создаем две папки test и train, они могут находиться где угодно, важно, чтобы они были в одном месте
Открываем программу и выбираем папку train с изображениями, с которыми будем работать. Далее выделяем нужные нам объекты и присваиваем им названия.
Перед тем, как перейти к следующему изображению, нужно сохранить, а после переходим к следующей картинке
После каждого сохранения будут создаваться текстовые файлики с точно таким же именем как и графический файл
После того, как вы обработали изображение и все сохранилось в папке train, скопируем все содержимое в папку test. У нас будут одинаковые файлы в двух папках
Делаем архивный файл двух папок и называем как угодно, например mask-dataset.zip
Теперь нам нужно все это дело прогнать либо в Training on Google Colab with Free GPUS, либо поднимаете свой сервер по этой инструкции. Я собирал через Training on Google Colab with Free GPUS
Нажимаем на иконку “Папка”
Загрузим наш архивный файл mask-dataset.zip
Запустим установку DeepStack Trainer, кликнув на кнопку, далее нажимаем на “Выполнить” и ждем когда закончится установка DeepStack Trainer
После успешной установки DeepStack Trainer появится папка deepstack-trainer
Разархивируем наш файлик mask-dataset.zip в папку /content командой
Запускаем обучение и ждем полного окончания процесса, ждать может придется долго
Процесс пошел успешно, ждем дальше пока не будет Epoch 299/299
Вот так выглядит завершенный процесс, после чего скачиваем готовый файлик к себе и именуем как угодно. Я назвал его courier.pt. После чего останавливаем контейнер DeepStack и закидываем этот файлик courier.pt в папку /modelstore/detection
Запускаем контейнер и у нас начинает работать пользовательская модель распознавания. На этом все.
