Face and person detection with Deepstack - local and free!
It is a WIP, but basically we will own it and can therefore get a tight integration with HA. I haven’t started a thread for this yet
random question as i imagine those doing this may be on this thread.
Anyone used an external GPU via thunderbolt on a NUC? wonder if that would be usable for this scenario with GPU
Finding a USB to mpcie Adapter seems not be an easy task. I mostly found USB to msata Adapters that probably won’t work.
Any suggestions for a suitable USB Adapter?
Robin, any chance deepstack_face would fire face_recognized event anytime soon?
I have a child on the way, and only limited time and too many projects. If there are feature requests I will proritise those where I am receiving sponsorship to cover those projects. My link is below, thanks:
Hi all
Before I bury myself in documentation and learning. Just checking, will my requirements be met?
  1. I have ring cameras. I can get video out (dont think images)
  2. I would like to detect and recognize faces. No requirement for this to be immediate
  3. Would like to keep videos that are not recognized, and delete videos that are
Reasonable?
I thought you couldnt get RTSP stream from Ring cameras. Is that possible now?
@ArnoNel face recognition is supported, but handling videos is not performed by this integration
Rob! Fantastic news… Congratulations with the little one :+1:
Thanks Robin for all your excellent work! No more false alerts from security camera!!
Anyone know if there is a stand alone IP camera that has option to send command line like MQTT message when motion is detected and when motion event ends? I am currently using MotionEye with web camera but I would like to replace it with a IP camera that will also work as a motion sensor to trigger HA automation. I think ONVIF profile T supports that function but I don’t know which camera is compatible.
Checkout my article for links https://www.hackster.io/robin-cole/add-ai-brains-to-your-home-camera-system-5195b0
I am running deepstack docker container on a laptop with ubuntu OS. Can I use Intel Neural Compute Stick to speed detection so I can run multiple image processing with more cameras or does the stick only work with Pi?
I think its for the pi only. I would say try the deepstack forums
Anyone else seeing this after the latest Hassio update 0.103.4?
Platform error image_processing.deepstack_object - cannot import name ‘draw_box’ from ‘homeassistant.components.image_processing’ (/usr/src/homeassistant/homeassistant/components/image_processing/init.py)
They did some changes about image processing in the last update, you can see it in change log
I just released v2.5 which fixes the error introduced in HA 0.103. This will require users to be on HA >= 0.103
As usual Rob… Always a pleasure!
Thanks for the quick reply.
Just updated and no errors :slight_smile:
Thank You!
Works with HA docker container v 103.4 now.
I’m trying the automation below but I get “Error while executing automation automation.new_person_alert. Invalid data for call_service at pos 1: extra keys not allowed @ data[‘file’]”
Any idea why? I basically copied the example from https://github.com/robmarkcole/HASS-Deepstack-object
- id: "1120092824611"
    - data_template:
        file: "{{ trigger.event.data.file }}"
        message: "Captured {{ trigger.event.data.file }}"
      service: notify.pushbullet
  alias: "New person alert"
  condition: []
    - platform: event
      event_type: image_processing.file_saved
I was able to fix it changing to
    - data_template:
        message: "Captured Motion"
  condition: []
    - platform: event
Funny thing is that the image (“entity”_latest_person.jpg) is created but the event image_processing.file_saved does not trigger. In the developers tool I keep listening to that event and nothing shows up…
Ideas? I’m using 103.4 and the last deepstack version.
