Face and person detection with Deepstack - local and free!
I dont see anything in the 0.103 release notes which would have affected this
Funny even folder_watch does not work. I did spin another ha instance and was able to make folder_watch work in the first try. In my current ha installation it does not work, I wonder if any plugin or extensions is getting in the way…not related to this thread but just following up to my previous question.
Can anybody help how I debug that sometimes the bike is detected as a person?
You should increase the confidence threshold
It’s on 85% already and actually some time missing the person detection because of that threshold (some people detected around 75% confidence)…
Getting into trying to set this up with HACS, and getting this error:
`Platform error image_processing.deepstack_object - No module named 'homeassistant.util.pil``
What am I missing?
Update to latest release
Hi @robmarkcole, thanks for your integration!
I think I followed all the steps, tried both deepstack and deepstack:noavx (even if my cpu flags shows avx2) but I still get this error in HA logs:
Depstack error : Error from Deepstack: Detection endpoint not activated
I’m running HA on docker (not hassio) and deepstack as a docker image as well. Activated with no issues and it shows 729 days remaining.
In home assistant I defined a local_file camera, and I feed that entity into the image_processing component, but when I trigger the image_processing.scan service I get the aforementioned error.
What am I missing?
Try restarting the container. Otherwisd its a deepstack issue for their forums
Hi everyone!
I got some problem to use object recognation with my camera
It’s working with a jpg camera:
  - platform: local_file
    file_path: /tmp/image.jpg
So my problem is my real camera, setup like this:
  - platform: mjpeg
    mjpeg_url: http://192.168.0.xx:2971/camera/stream
State is always Unknown with my real camera
SO, what type of camera do i need to use in HA ?
This morning, it’s working! i don’t know what really happens!
I have just setting this up and get the following error, i have the dependencies installed.
Hassio V 0.103.6
2020-01-11 18:19:51 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for deepstack_object which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-01-11 18:19:51 ERROR (MainThread) [homeassistant.config] Platform error: image_processing
  File "/usr/src/homeassistant/homeassistant/config.py", line 761, in async_process_component_config
    platform = p_integration.get_platform(domain)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 232, in get_platform
    f"{self.pkg_path}.{platform_name}"
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/deepstack_object/image_processing.py", line 23, in <module>
    from homeassistant.util.pil import draw_box
ModuleNotFoundError: No module named 'homeassistant.util.pil'
Any help appreciated.
Update HA to latest version
All good thanks was me being a bit hesitant at updating should of been the first thing I did.
Hi
I have both face and. vision sion enabled in a single docker (using multiple -e option).
face detection works. Object and face reco does not.
I have triple checked folders whitelisting and they are.
In the logs of docker i see nothing happening (even though face detection works)
I have attempted multiple times to register faces , i call the service but no feedback and no matches.
Is there somewhere inthe docker a log i can check? i can login by connecting through portainerconsole to the deepstack container.
Tx in advance
@robmarkcole
Do I need to use the google coral HASS-Google-Coral integration for google coral device, or I can use the https://github.com/robmarkcole/HASS-Deepstack-object with it?
Thx!
use HASS-Deepstack-object
Thx, this is what I use now, but I don’t see any file saved to the folder so I thought I am not using the right integration.
I am trying to debug it …
UPDATE:
I think the reason that I don’t see any image saved, is that I see person == 0, and in that case image is not saved.
@robmarkcole
Does the integration support any target object? currently, as I understand, I need to list the targets I want and person is the default. Any way to support something like:
target: *
Is it is possible at all to define list of targets (from the code I don’t see it)? something like:
target: clock, bench, car
Thx
An image_processing.object_detected event is fired for each object, you should use that.
Previously more data was exposed via attributes but it was very messy approach an unsatisfactory so removed
