Face and person detection with Deepstack - local and free!
@robmarkcole
Does the hass face component supports google coral? If not, are you familiar with component that does support it (detection / recognition)?
Thx
Not yet, possible in time
Is it possible to use the face component with a local file camera?
Yes you can use any camera supported by HA
@robmarkcole
Iā€™m having trouble with the notification couter, for example if 3 people is detected on the image, I receive the same notification 3 times, iā€™m using this:
  • id: ā€˜1580423474230ā€™
    alias: person detection front camera send pushbullet notify
    description: ā€˜ā€™
    • event_data:
      object: person
      event_type: image_processing.object_detected
      platform: event
      condition: []
    • data:
      message: Person detected on the front door
      service: notify.pushbullet
any help with this?
thanks
use this approach
Just found that the deepstack url for raspberrypi installation are broken, anyone has a copy of the deepstack.deb file (the one for raspberrypi and ncs)?
Thanks Rob, for an awesome integrationā€¦ iā€™ve been using it for a while now, and itā€™s time to clean up my config and get everything working as it is supposed toā€¦
That said, Iā€™ve got the following two lines in my config:
    save_file_folder: /tmp/detector/deepstack/
    save_timestamped_file: True
and I am getting filenames like this:
Any idea where i may have gone wrong?
Hmm the component could not produce those filenames
I am getting those too and it is because :
save_file_folder: /config/snapshots/
In windows the names look a little crazy, but if you look inside home assistant its looks normal:
Am I doing something wrong here?
How do I choose which items trigger notifications?
Itā€™s finding other items but only creating a person detected file.
Also, when I walk in the room, itā€™s not triggering the automation which should send me the image.
I donā€™t have the portion of the log below, but when I leave the room, the summary changes from person=1 to person=0
When I enter the room, it changes back to person=1 . but the automation isnā€™t emailing me anything
My current detection shows a change from
summary=
dining table=1
person=1
laptop=1
chair=2
to
summary=
dining table=2
person=1
laptop=1
chair=3
and the only file that gets created is
line of my debug log
2020-02-11 22:03:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.12334115914] Sending {ā€˜idā€™: 2, ā€˜typeā€™: ā€˜eventā€™, ā€˜eventā€™: <Event state_changed[L]: entity_id=image_processing.deepstack_detector, old_state=<state image_processing.deepstack_detector=0; last_person_detection=2020-02-11_22:02:20, summary=dining table=1, person=1, laptop=1, chair=2, unit_of_measurement=person, friendly_name=deepstack_detector @ 2020-02-11T22:02:41.917945-05:00>, new_state=<state image_processing.deepstack_detector=1; last_person_detection=2020-02-11_22:03:02, summary=dining table=2, person=1, laptop=1, chair=3, unit_of_measurement=person, friendly_name=deepstack_detector @ 2020-02-11T22:03:03.131442-05:00>>}
configuration.yaml
image_processing:
  - platform: deepstack_object
    ip_address: 10.0.0.20
    port: 5555
    api_key: < my key >
    scan_interval: 20 # Optional, in seconds
    save_file_folder: /config/www/
    source:
    - entity_id: camera.frontdoor
automations.yaml
- id: '1159403824611'
  alias: New detection alert
  - platform: event
  - service: script.send_detected_image
scripts.yaml
send_detected_image:
  sequence:
  - service: notify.gmail
    data_template:
      title: 'Something/Someone was detected'
      message: "What/Who is it?"
        file: "{{ trigger.event.data.file }}"
I think the issue with my automation not firing is the last line
How do I get the filename of the last file created by the automation?
Iā€™m getting the same over samba in Windows. Its fine in Hass/linux though
It appears that the files with funny names are all being produced on windows platforms only? @cooloo @Ekstrom @xeryax ?
@Dayve67 as per docs:
The box coordinates and the box center (centroid) can be used to determine whether an object falls within a defined region-of-interest (ROI). This can be useful to include/exclude objects by their location in the image.
Basically use the box in a condition on your automation.
@surge919 it probably is a yaml formatting error somewhere
I have not had any false notifications since 2 months but today I got one! :slight_smile: I think I just have to raise my confidence level to 85% from the standard. I do wonder however if there are any updates done the the DeepStack docker image that can increase the detection? Is it trained and final or are there regular updates? Thanks for a very good add on to my smart home!
Deepstack is using Yolo3 which is a standard model. If you want to use your own model checkout the tensorflow integration
Hi there, Iā€™m sorry if this has already been answered somewhere but I canā€™t find anything about. Currently Iā€™m running 2 Docker containers built from the same image, one for face recognition on port 5000 and the other for object recognition on custom port 5005.
So far is working well with 2 cams, but I was wondering whatā€™s the better approach, if any, regarding calculation power between the one you suggest (activating both obj and face on one instance) and mine.
Oh Iā€™m on a i5 NUC 7th gen with 16Gb RAM and M.2 SSD.
Hi, iā€™m having trouble this component to trigger an automation when person is detected, the component itself looks like to be working fine because i can see the picture created with the person enclosed in red, here is my automation:
- id: '1234'
  alias: person detection pushbullet notify
  description: ''
  - event_data:
      object: person
    platform: event
  condition: []
  - delay: '5'
  - data:
        file: images/deepstack_person_detector_front_latest_person.jpg
      - channel/mychannel
if i trigger the automation manually i receive the pushbullet message with the picture, but i canā€™t get the automation to work.
anyone has this issue?
Hey Guys,
Iā€™m thinking about using Deepstack, but need to clarify some ideas.
I have a dell 3060 (win 10 machine) running Blue Iris.
Can I install Deepstack also on this machine, and then after the image is analyzed by Deepstack to send it to Home Assistant? For notification, etc.
Is there a guide for this? My HA is on a Raspbery Pi 3 b+ hass.io.
@b.maia81 there is a guide here
Thanks Robin.
If I remember correctly this was the original topic that got me interested in Deepstack. I will give it a deeper look. But my question is more specific, just because Iā€™m completly noob on linux.
Should I make the effort to instal linux on a virtual machine on my DELL pc and instal deepstack on it or windows will also work fine?
This doesnā€™t mention Blue Iris, but it shouldnā€™t affect in performance right? the camera feed is handle by BI and then by Deepstack.
Thanks again
