Face and person detection with Deepstack - local and free!
Getting ModuleNotFoundError: No module named ‘deepstack’ after restart. Running Hass.io w/ Docker. Tried rebooting host, recreating homeassistant docker container, downgrading to 2020.12, upgrading to latest.
Is there any way to troubleshoot why would the dependency did not install?
@Alex_Pupkin can you share your fork? most of those are features or feature requests on either deepstack face or object.
Someone else reported an issue with hassio, and this has come up before, when someone had versions of deepstack face or object with different version dependencies
@robmarkcole I have opened an issue on Deepstack GitHub (https://github.com/johnolafenwa/DeepStack/issues/70) because the Nvidia Jetson Nano 2GB seems not working for face recognition.
No other have found Memory problem on those Nvidia board? There is a way to solve it?
Contrary in the fast run of the docker container (when it work) is just good fast to recognize the faces.
Thank so much for the help.
Component that will perform object detection and identification via deepstack.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/image_processing.deepstack_object
from collections import namedtuple
import datetime
import io
import logging
import os
import re
from datetime import timedelta
from typing import Tuple
from pathlib import Path
from PIL import Image, ImageDraw
import deepstack.core as ds
import homeassistant.helpers.config_validation as cv
import homeassistant.util.dt as dt_util
import voluptuous as vol
from homeassistant.util.pil import draw_box
from homeassistant.components.image_processing import (
    ATTR_CONFIDENCE,
    CONF_ENTITY_ID,
    CONF_NAME,
    CONF_SOURCE,
    DOMAIN,
    PLATFORM_SCHEMA,
    ImageProcessingEntity,
from homeassistant.const import (
    ATTR_ENTITY_ID,
    ATTR_LAST_TRIP_TIME,
    ATTR_NAME,
    CONF_IP_ADDRESS,
    CONF_PORT,
    CONF_COUNT,
    HTTP_BAD_REQUEST,
    HTTP_OK,
    HTTP_UNAUTHORIZED,
from homeassistant.core import split_entity_id
_LOGGER = logging.getLogger(__name__)
CONF_API_KEY = "api_key"
CONF_TARGETS = "targets"
CONF_TIMEOUT = "timeout"
CONF_SAVE_FILE_FOLDER = "save_file_folder"
CONF_SAVE_TIMESTAMPTED_FILE = "save_timestamped_file"
CONF_SAVE_CROPPED_FILE = "save_cropped_file"
CONF_SAVE_LABEL_DATA = "save_label_data"
CONF_SAVE_BLANKS = "save_blanks"
CONF_FACE_DETECT = "face_detect"
CONF_FACE_RECOGNIZE = "face_recognize"
CONF_SHOW_BOXES = "show_boxes"
CONF_ROI_Y_MIN = "roi_y_min"
CONF_ROI_X_MIN = "roi_x_min"
CONF_ROI_Y_MAX = "roi_y_max"
CONF_ROI_X_MAX = "roi_x_max"
DATETIME_FORMAT = "%Y-%m-%d_%H-%M-%S"
DEFAULT_API_KEY = ""
DEFAULT_TARGETS = ["person"]
DEFAULT_TIMEOUT = 10
DEFAULT_ROI_Y_MIN = 0.0
DEFAULT_ROI_Y_MAX = 1.0
DEFAULT_ROI_X_MIN = 0.0
DEFAULT_ROI_X_MAX = 1.0
DEFAULT_ROI = (
    DEFAULT_ROI_Y_MIN,
    DEFAULT_ROI_X_MIN,
    DEFAULT_ROI_Y_MAX,
    DEFAULT_ROI_X_MAX,
BOX = "box"
FILE = "file"
OBJECT = "object"
CLASSIFIER = "deepstack_face"
DATA_DEEPSTACK = "deepstack_classifiers"
FILE_PATH = "file_path"
SERVICE_TEACH_FACE = "deepstack_teach_face"
# rgb(red, green, blue)
RED = (255, 0, 0)  # For objects within the ROI
GREEN = (0, 255, 0)  # For ROI box
YELLOW = (255, 255, 0)  # For objects outside the ROI
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
        vol.Required(CONF_IP_ADDRESS): cv.string,
        vol.Required(CONF_PORT): cv.port,
        vol.Optional(CONF_API_KEY, default=DEFAULT_API_KEY): cv.string,
        vol.Optional(CONF_TIMEOUT, default=DEFAULT_TIMEOUT): cv.positive_int,
        vol.Optional(CONF_TARGETS, default=DEFAULT_TARGETS): vol.All(
            cv.ensure_list, [cv.string]
        vol.Optional(CONF_ROI_Y_MIN, default=DEFAULT_ROI_Y_MIN): cv.small_float,
        vol.Optional(CONF_ROI_X_MIN, default=DEFAULT_ROI_X_MIN): cv.small_float,
        vol.Optional(CONF_ROI_Y_MAX, default=DEFAULT_ROI_Y_MAX): cv.small_float,
        vol.Optional(CONF_ROI_X_MAX, default=DEFAULT_ROI_X_MAX): cv.small_float,
        vol.Optional(CONF_SAVE_FILE_FOLDER): cv.isdir,
        vol.Optional(CONF_SAVE_TIMESTAMPTED_FILE, default=False): cv.boolean,
        vol.Optional(CONF_SAVE_CROPPED_FILE, default=False): cv.boolean,
        vol.Optional(CONF_SAVE_LABEL_DATA, default=False): cv.boolean,
        vol.Optional(CONF_SAVE_BLANKS, default=False): cv.boolean,
        vol.Optional(CONF_FACE_DETECT, default=False): cv.boolean,
        vol.Optional(CONF_FACE_RECOGNIZE, default=False): cv.boolean,
        vol.Optional(CONF_SHOW_BOXES, default=True): cv.boolean,
SERVICE_TEACH_SCHEMA = vol.Schema(
        vol.Optional(ATTR_ENTITY_ID): cv.entity_ids,
        vol.Required(ATTR_NAME): cv.string,
        vol.Required(FILE_PATH): cv.string,
Box = namedtuple("Box", "y_min x_min y_max x_max")
Point = namedtuple("Point", "y x")
def point_in_box(box: Box, point: Point) -> bool:
    """Return true if point lies in box"""
    if (box.x_min <= point.x <= box.x_max) and (box.y_min <= point.y <= box.y_max):
        return True
    return False
def object_in_roi(roi: dict, centroid: dict) -> bool:
    """Convenience to convert dicts to the Point and Box."""
    target_center_point = Point(centroid["y"], centroid["x"])
    roi_box = Box(roi["y_min"], roi["x_min"], roi["y_max"], roi["x_max"])
    return point_in_box(roi_box, target_center_point)
def get_valid_filename(name: str) -> str:
    return re.sub(r"(?u)[^-\w.]", "", str(name).strip().replace(" ", "_"))
def get_objects(predictions: list, prediction_type: str, img_width: int, img_height: int):
    """Return objects with formatting and extra info."""
    objects = []
    decimal_places = 3
    for pred in predictions:
        box_width = pred["x_max"] - pred["x_min"]
        box_height = pred["y_max"] - pred["y_min"]
        box = {
            "height": round(box_height / img_height, decimal_places),
            "width": round(box_width / img_width, decimal_places),
            "y_min": round(pred["y_min"] / img_height, decimal_places),
            "x_min": round(pred["x_min"] / img_width, decimal_places),
            "y_max": round(pred["y_max"] / img_height, decimal_places),
            "x_max": round(pred["x_max"] / img_width, decimal_places),
        box_area = round(box["height"] * box["width"], decimal_places)
        centroid = {
            "x": round(box["x_min"] + (box["width"] / 2), decimal_places),
            "y": round(box["y_min"] + (box["height"] / 2), decimal_places),
        if not "label" in pred.keys():
            if not "userid" in pred.keys():
                name = "face_unknown"
            else:
                name = "face_{}".format(pred["userid"])
        else:
            name = pred["label"]
        confidence = round(pred["confidence"] * 100, decimal_places)
        objects.append(
                "bounding_box": box,
                "box_area": box_area,
                "centroid": centroid,
                "name": name,
                "prediction_type": prediction_type,
                "confidence": confidence,
    return objects
def setup_platform(hass, config, add_devices, discovery_info=None):
    """Set up the classifier."""
    save_file_folder = config.get(CONF_SAVE_FILE_FOLDER)
    if save_file_folder:
        save_file_folder = Path(save_file_folder)
    if DATA_DEEPSTACK not in hass.data:
        hass.data[DATA_DEEPSTACK] = []
    targets = [t.lower() for t in config[CONF_TARGETS]]  # ensure lower case
    entities = []
    for camera in config[CONF_SOURCE]:
        object_entity = ObjectClassifyEntity(
            config.get(CONF_IP_ADDRESS),
            config.get(CONF_PORT),
            config.get(CONF_API_KEY),
            config.get(CONF_TIMEOUT),
            targets,
            config.get(ATTR_CONFIDENCE),
            config[CONF_ROI_Y_MIN],
            config[CONF_ROI_X_MIN],
            config[CONF_ROI_Y_MAX],
            config[CONF_ROI_X_MAX],
            config[CONF_SHOW_BOXES],
            save_file_folder,
            config.get(CONF_SAVE_TIMESTAMPTED_FILE),
            config.get(CONF_SAVE_CROPPED_FILE),
            config.get(CONF_SAVE_LABEL_DATA),
            config.get(CONF_SAVE_BLANKS),
            config.get(CONF_FACE_DETECT),
            config.get(CONF_FACE_RECOGNIZE),
            camera.get(CONF_ENTITY_ID),
            camera.get(CONF_NAME),
        entities.append(object_entity)
        hass.data[DATA_DEEPSTACK].append(object_entity)
    add_devices(entities)
    def service_handle(service):
        """Handle for services."""
        _LOGGER.debug("Deepstack handling teaching")
        entity_ids = service.data.get("entity_id")
        classifiers = hass.data[DATA_DEEPSTACK]
        if entity_ids:
            classifiers = [c for c in classifiers if c.entity_id in entity_ids]
        for classifier in classifiers:
            name = service.data.get(ATTR_NAME)
            file_path = service.data.get(FILE_PATH)
            classifier.teach(name, file_path)
            break
    hass.services.register(
        DOMAIN, SERVICE_TEACH_FACE, service_handle, schema=SERVICE_TEACH_SCHEMA
class ObjectClassifyEntity(ImageProcessingEntity):
    """Perform a face classification."""
    def __init__(
        self,
        ip_address,
        port,
        api_key,
        timeout,
        targets,
        confidence,
        roi_y_min,
        roi_x_min,
        roi_y_max,
        roi_x_max,
        show_boxes,
        save_file_folder,
        save_timestamped_file,
        save_cropped_file,
        save_label_data,
        save_blanks,
        face_detect,
        face_recognize,
        camera_entity,
        name=None,
        """Init with the API key and model id."""
        super().__init__()
        self._dsobject = ds.DeepstackObject(ip_address, port, api_key, timeout)
        self._dsface = ds.DeepstackFace(ip_address, port, api_key, timeout)
        self._targets = targets
        self._confidence = confidence
        self._camera = camera_entity
        if name:
            self._name = name
        else:
            camera_name = split_entity_id(camera_entity)[1]
            self._name = "deepstack_object_{}".format(camera_name)
        _LOGGER.debug("Deepstack object camera initializing as {}".format(camera_name))
        self._state = None
        self._objects = []  # The parsed raw data
        self._targets_found = []
        self._summary = {}
        self._matched = {}
        self._faces = []
        self._total_faces = None
        self._roi_dict = {
            "y_min": roi_y_min,
            "x_min": roi_x_min,
            "y_max": roi_y_max,
            "x_max": roi_x_max,
        self._show_boxes = show_boxes
        self._last_detection = None
        self._image_width = None
        self._image_height = None
        self._save_file_folder = save_file_folder
        self._save_timestamped_file = save_timestamped_file
        self._save_cropped_file = save_cropped_file
        self._save_label_data = save_label_data
        self._save_blanks = save_blanks
        self._face_detect = face_detect
        self._face_recognize = face_recognize
    def process_image(self, image):
        """Process an image."""
        self._image_width, self._image_height = Image.open(
            io.BytesIO(bytearray(image))
        ).size
        self._state = None
        self._summary = {}
        _LOGGER.debug("Deepstack detection triggering on ")
        try:
            self._dsobject.detect(image)
        except ds.DeepstackException as exc:
            _LOGGER.critical("Deepstack error : %s", exc)
            return
        predictions = self._dsobject.predictions.copy()
        if predictions:
            _LOGGER.info("Deepstack object detection complete on {} with results {}".format(self._name, predictions))
        else:
            _LOGGER.debug("Deepstack object detection complete on {} with no results".format(self._name))
        self._summary = ds.get_objects_summary(predictions)
        self._objects = get_objects(predictions, "object", self._image_width, self._image_height)
            obj
            for obj in self._objects
            if (obj["name"] in self._targets)
            and (obj["confidence"] > self._confidence)
            and (object_in_roi(self._roi_dict, obj["centroid"]))
        self._state = len(self._targets_found)
        detection_time = dt_util.now().strftime(DATETIME_FORMAT)
        if (self._state > 0):
            self._last_detection = detection_time
        if (self._face_recognize or self._face_detect):
            try:
                if self._face_recognize:
                    self._dsface.recognise(image)
                else:
                    self._dsface.detect(image)
                _LOGGER.error("Depstack error : %s", exc)
                return
            face_predictions = self._dsface.predictions.copy()
            if len(face_predictions) > 0:
                face_objects = get_objects(face_predictions, "face", self._image_width, self._image_height)
                # filter out 0% probability
                for obj in face_objects:
                    if (obj["confidence"] > 0):
                        self._faces.append(obj)
                if len(self._faces) > 0:
                    _LOGGER.info("Deepstack face detection complete on {} with results {}".format(self._name, self._faces))
                else:
                    _LOGGER.debug("Deepstack face detection complete on {} with no results".format(self._name))
                self._total_faces = len(self._faces)
                self._matched = ds.get_recognised_faces(face_predictions)
                if len(self._matched) > 0:
                    _LOGGER.info("Deepstack recognized faces {}".format(self._matched))
            else:
                self._matched = {}
        if self._save_file_folder:
            _LOGGER.debug("Saving images")
            self.save_image(
                image, self._objects + self._faces, self._targets, self._save_file_folder, detection_time,
        # Fire events
        objnum=0
        #for target in self._targets_found:
        for obj in self._objects + self._faces:
            objnum=objnum+1
            if (len(self._targets) and (obj["name"] not in self._targets) and not obj["name"].startswith("face_")) or (obj["confidence"] < self._confidence) or (not object_in_roi(self._roi_dict, obj["centroid"])):
                continue
            target_event_data = obj.copy()
            target_event_data[ATTR_ENTITY_ID] = self.entity_id
            target_event_data[ATTR_LAST_TRIP_TIME] = detection_time
            target_event_data[CONF_COUNT] = objnum
            if ("face" in target_event_data["prediction_type"]):
                target_event_data["recognized"] = self._matched
                target_event_data["recognized_count"] = len(self._matched)
            target_event_type = "deepstack.{}_detected".format(target_event_data["prediction_type"])
            self.hass.bus.fire(target_event_type, target_event_data)
            _LOGGER.debug("Deepstack event fired {}".format(target_event_data))
        _LOGGER.debug("Deepstack events fired")
    def teach(self, name: str, file_path: str):
        """Teach classifier a face name."""
        _LOGGER.debug("Deepstack teaching")
        if not self.hass.config.is_allowed_path(file_path):
            return
        with open(file_path, "rb") as image:
            self._dsface.register_face(name, image)
            _LOGGER.info("Depstack face taught name : %s", name)
    @property
    def camera_entity(self):
        """Return camera entity id from process pictures."""
        return self._camera
    @property
    def state(self):
        """Return the state of the entity."""
        return self._state
    @property
    def name(self):
        """Return the name of the sensor."""
        return self._name
    @property
    def unit_of_measurement(self):
        """Return the unit of measurement."""
        return "targets"
    @property
    def should_poll(self):
        """Return the polling state."""
        return False
    @property
    def device_state_attributes(self):
        """Return device specific state attributes."""
        attr = {}
        for target in self._targets:
            attr[f"ROI {target} count"] = len(
                [t for t in self._targets_found if t["name"] == target]
            attr[f"ALL {target} count"] = len(
                [t for t in self._objects if t["name"] == target]
        if self._last_detection:
            attr["last_target_detection"] = self._last_detection
        attr["summary"] = self._summary
        attr["objects"] = self._objects
        if self._face_detect:
            attr[CONF_FACE_DETECT] = self._face_detect
            attr[CONF_FACE_RECOGNIZE] = self._face_recognize
            attr["total_matched_faces"] = len(self._matched)
            attr["matched_faces"] = self._matched
        return attr
    def save_image(self, image, crops, targets, directory, stamp):
        """Draws the actual bounding box of the detected objects."""
        try:
            img = Image.open(io.BytesIO(bytearray(image))).convert("RGB")
            imgo = Image.open(io.BytesIO(bytearray(image))).convert("RGB")
            imgc = Image.open(io.BytesIO(bytearray(image))).convert("RGB")
        except UnidentifiedImageError:
            _LOGGER.warning("Deepstack unable to process image, bad data")
            return
        draw = ImageDraw.Draw(img)
        roi_tuple = tuple(self._roi_dict.values())
        if roi_tuple != DEFAULT_ROI and self._show_boxes:
            draw_box(
                draw, roi_tuple, img.width, img.height, text="ROI", color=GREEN,
        objnum=1
        for obj in crops:
            name = obj["name"]
            confidence = obj["confidence"]
            box = obj["bounding_box"]
            prediction_type = obj["prediction_type"]
            centroid = obj["centroid"]
            box_label = f"{name}: {confidence:.1f}%"
            if self._save_cropped_file:
                _LOGGER.debug("Box {}".format(box))
                imc = imgc.crop((box["x_min"] * img.width, box["y_min"] * img.height, box["x_max"] * img.width, box["y_max"] * img.height))
                if self._save_timestamped_file:
                    crop_save_path = directory / f"{self._name}_{stamp}_{prediction_type}_{name}_{objnum}.jpg"
                    imc.save(crop_save_path)
                crop_save_path = directory / f"{self._name}_latest_{prediction_type}_{name}.jpg"
            objnum=objnum+1
            if self._save_label_data:
                label_path = directory / f"labels.csv"
                with open(label_path,"a+") as f:
                    timestamp_save_path = directory / f"{self._name}_{stamp}_nobox.jpg"
                    f.write("{},{},{},{},{},{},{}\n".format(timestamp_save_path,int(box["x_min"] * img.width), int(box["y_min"] * img.height), int(box["x_max"] * img.width), int (box["y_max"] * img.height),name, confidence))
            if not self._show_boxes:
                continue
            if object_in_roi(self._roi_dict, centroid):
                box_colour = RED
            else:
                box_colour = YELLOW
            draw_box(
                draw,
                (box["y_min"], box["x_min"], box["y_max"], box["x_max"]),
                img.width,
                img.height,
                text=box_label,
                color=box_colour,
            # draw bullseye
            draw.text(
                (centroid["x"] * img.width, centroid["y"] * img.height),
                text="X",
                fill=box_colour,
        if (len(crops) > 0 or self._save_blanks):
            suffix = ""
            if (self._save_blanks and not len(crops) > 0):
                suffix="_blank"
            if self._show_boxes:
                latest_save_path = (
                    directory / f"{get_valid_filename(self._name).lower()}_latest_box{suffix}.jpg"
                img.save(latest_save_path)
            latest_save_path = directory / f"{get_valid_filename(self._name).lower()}_latest_nobox{suffix}.jpg"
            imgo.save(latest_save_path)
                    timestamp_save_path = directory / f"{self._name}_{stamp}_box{suffix}.jpg"
                    img.save(timestamp_save_path)
                timestamp_save_path = directory / f"{self._name}_{stamp}_nobox{suffix}.jpg"
                imgo.save(timestamp_save_path)
@robmarkcole - fixed module loading issue. basically i copied your deepstack_object as a separate custom_component to deepstack_object_crop but did not modify manifest domain to match. does not work this way anymore - dont know why it worked in 2020 versions.
i posted cropping above - it’s quite useful - i send crops from security camera to my apple watch via home assistant app when people or cars arrive.
Need some help figuring out why my Deep Stack is detecting the car as a person??
yaml looks like this were I set the target as a person, but as you can see it detects the car… This one happens to have “feet” in the background that caused the motion but even where there is just light causing the motion, it detects my car.
Any suggestions?
- platform: deepstack_object
  ip_address: 192.168.20.69
  port: 80
  api_key: 3032d851-35f3-49b7-be84-a7e9f8c13bac
  save_file_folder: /config/www/Images/FromCam/
  confidence: 80
  targets:
    - person
  source:
    - entity_id: camera.blueiris_front_door
  roi_x_min: 0.3
  roi_x_max: 1
  roi_y_min: 0.08
  roi_y_max: .9
I’m still learning - but wonder if the “–gpus all” arg is wrong/irrelevant? I’m still trying to work out if it is oboslete, or tied to the gpu docker image, or causes issues when “–runtime nvidia” is used … have you tried it without?
@robmarkcole I have opened an issue on Deepstack GitHub (https://github.com/johnolafenwa/DeepStack/issues/70 ) because the Nvidia Jetson Nano 2GB seems not working for face recognition.
For me working with 83% but working.If i you having detection + face on then not working nothing…
Hi All
I just released v4.0 of deepstack-object which allows setting a confidence per object. Check it out here.. Basically you can now do:
    targets:
      - target: vehicle
        confidence: 60
      - target: car
        confidence: 40
@maximosm I commented on the issue on the deepstack repo, lets keep that dicussion there
@sleeepy2 there was a small bug fixed recently, update to latest release
@Alex_Pupkin is your code on Github? reading code in a chat thread is not ideal
From my test the option “–gpus all” is not so useful, probably but i’m not sure is the option “–runtime nvidia”.
The problem of Deepstack and Face recognition is related to the amount of Jetson RAM only to 2GB, i’m 100% sure on that :slight_smile:
Exactly Face detection is working well with the option “MODE=High”, the problem is coming when i try to “Recognize a face”, work for some runs but after that the Jetson going in stale… Kernel dump on memory usage full.
Hi @robmarkcole,
Thanks for your exelent job.
After last update, I got these error:
Logger: homeassistant.config
Source: config.py:415
First occurred: 1:37:03 PM (5 occurrences)
Last logged: 1:37:03 PM
Invalid config for [image_processing.deepstack_object]: expected a dictionary @ data['targets'][0]. Got 'person' expected a dictionary @ data['targets'][1]. Got 'car' expected a dictionary @ data['targets'][2]. Got 'truck' expected a dictionary @ data['targets'][3]. Got 'bicycle' expected a dictionary @ data['targets'][4]. Got 'motorcycle' expected a dictionary @ data['targets'][5]. Got 'cat' expected a dictionary @ data['targets'][6]. Got 'dog'. (See /config/configuration.yaml, line 140). Please check the docs at https://github.com/robmarkcole/HASS-Deepstack-object
Invalid config for [image_processing.deepstack_object]: expected a dictionary @ data['targets'][0]. Got 'person' expected a dictionary @ data['targets'][1]. Got 'car' expected a dictionary @ data['targets'][2]. Got 'truck' expected a dictionary @ data['targets'][3]. Got 'bicycle' expected a dictionary @ data['targets'][4]. Got 'motorcycle' expected a dictionary @ data['targets'][5]. Got 'cat' expected a dictionary @ data['targets'][6]. Got 'dog'. (See /config/configuration.yaml, line 160). Please check the docs at https://github.com/robmarkcole/HASS-Deepstack-object
Invalid config for [image_processing.deepstack_object]: expected a dictionary @ data['targets'][0]. Got 'person' expected a dictionary @ data['targets'][1]. Got 'car' expected a dictionary @ data['targets'][2]. Got 'truck' expected a dictionary @ data['targets'][3]. Got 'bicycle' expected a dictionary @ data['targets'][4]. Got 'motorcycle' expected a dictionary @ data['targets'][5]. Got 'cat' expected a dictionary @ data['targets'][6]. Got 'dog'. (See /config/configuration.yaml, line 180). Please check the docs at https://github.com/robmarkcole/HASS-Deepstack-object
Invalid config for [image_processing.deepstack_object]: expected a dictionary @ data['targets'][0]. Got 'person' expected a dictionary @ data['targets'][1]. Got 'car' expected a dictionary @ data['targets'][2]. Got 'truck' expected a dictionary @ data['targets'][3]. Got 'bicycle' expected a dictionary @ data['targets'][4]. Got 'motorcycle' expected a dictionary @ data['targets'][5]. Got 'cat' expected a dictionary @ data['targets'][6]. Got 'dog'. (See /config/configuration.yaml, line 200). Please check the docs at https://github.com/robmarkcole/HASS-Deepstack-object
Invalid config for [image_processing.deepstack_object]: expected a dictionary @ data['targets'][0]. Got 'person' expected a dictionary @ data['targets'][1]. Got 'car' expected a dictionary @ data['targets'][2]. Got 'truck' expected a dictionary @ data['targets'][3]. Got 'bicycle' expected a dictionary @ data['targets'][4]. Got 'motorcycle' expected a dictionary @ data['targets'][5]. Got 'cat' expected a dictionary @ data['targets'][6]. Got 'dog'. (See /config/configuration.yaml, line 220). Please check the docs at https://github.com/robmarkcole/HASS-Deepstack-object
Can you help please?
BR
Joca
I also have problems with the Jetson 2GB for face detection. When running with the docker container with
environment variable VISION-FACE=True, the service is started, but the device becomes inresponsive. The object detection doesn’t have any problems
Solved!
Just change the config from:
    targets:
      - person
      - vehicle
      - car
To:
    targets:
      - target: person
      - target: vehicle
      - target: car
Thanks for the update and all your work. I’ll give it a go.
it’s a shame that it does not work (face recognition)… i hope in a possible fix because I would like to use it as automation trigger :slight_smile:
If the deepstack team need more debug log, i’m here to help them.
Having troubles getting objects to show in a entity card…
This is what I get when using entity and attributes…
Whats wrong?
I just upgraded to 4.0 but having issues and can’t make the component to work anymore, even the “verify configuration” fails (spin forever, if i removed deepstack entry from my configuration.yaml all is fine).
this is my entry:
image_processing:
    ip_address: 192.168.1.7
    port: 5000
    #save_file_folder: /config/www/deepstack_save
    #save_timestamped_file: True
    targets:
      - target: person
        confidence: 80
      # - car
      # - truck
    source:
      - entity_id: camera.netatmo_corte
I use coral-rest server from robmarkcole on and RPI3 (HA running on a mini-pc).
All was fine before the upgrade I just changed the target entry as per breaking change.
can someone provide a hint about what is wrong in my setup?
EDIT: so I solved it, not sure how as I ended with the same code above…I think there was something in my cyberduck FTP client not saving the yaml file into my HA PC
Just on this … I’ve done a few installs etc, including 100% headless setup via USB. I’ve noticed that after the latest updates on the Nano, my lightdm “unity-greeter” process uses 100% CPU. I didn’t change anything apart from running apt update/upgrades. I’ve since totally disablled lightdm (sudo systemctl disable lightdm & sudo systemctl set-default multi-user.target) and that seems to stop ligthdm processes starting up again when headless …
Just a maybe not so stupid question, could the integration publish detections with binary sensor / sensor with the number of objects ?
It would be a lot easier to manipulate in automations…
Or can you guys share your template sensors if any ? I can’t find the correct template… (I.e. : sensor.entree_person / sensor.entree_car // binary_sensor.entree_person_detected…
Thanks in advance !
