Facebook graphics do not work for known_devices.yaml picture
Hello, facebook has a mechanism to retrieve the url for the image of a user’s profile picture based on their facebook ID
example
However, the image does not seem to be working in HASS
Works fine on dev.
000000000001:
  mac: 00:00:00:00:00:01
  picture: http://graph.facebook.com/9269711759/picture?type=normal
  track: yes
  hide_if_away: no
Thank you Fabian
I think my issue was a failure in RTFM. I also added a gravatar email address for each user and, if I’m reading this correctly, it looks like the gravatar invalidates the picture tag.
I also found it beneficial to have the user’s email address assigned to the user, perhaps additional contact information or a URL can be added to the users?
In any case, I haven’t tested removing the gravatar tag yet but I’m sure that’s my issue.
If you think it makes sense, then perhaps this should be a feature request instead of a bug report?
Thanks for the support and assist!
I do have the problem with hass 0.35.2 with the graph facebook API.
The picture showing up in the frontend is blank. Here’s my known_devices:
348a7bxxxxxx:
hide_if_away: false
mac: 34:8A:7B:xx:xx:xx
picture: http://graph.facebook.com/xxxxxxxxx/picture?type=normal
track: true
Any hint on what could cause the problem?
Thanks!
dose this still work ?
https://graph.facebook.com/618424843/picture?type=normal
i only get a plane picture
No, because :
Querying a User ID (UID) now requires an access token. Refer to the requirements table to determine which token type to include in UID-based requests.
from Graph API Reference v19.0: User Picture - Documentation - Meta for Developers
Maybe someone can make a API request , and get data ?
Check this topic : Use Facebook Profile Image for Persons with new API
