Factory Reset for a CM5 HA Yellow?
Hi folks, the Yellow factory reset guidance says the CM5 version doesn’t allow the red button for factory reset. Is there any other way to do a factory reset short of taking it apart and reflashing it all via USB…
You should be able to use the ha os datadisk wipe command from the serial command line (see on how to access the serial console from Windows, Linux/macOS).
