Hi all, I’ve managed to brick my HA Yellow CM5, 4Gb + 32Gb eMMC and wanted to add a 128Gb NVMe as additional storage.
With HA I used the move data disk process although the pop-ups are somewhat different to the tutorials, an extra UI appears requesting to use either the eMMC or NVMe as the main data disk. I selected eMMC thinking that the NVMe would then be additional storage, didn’t realise eMMC + NVMe can’t be used together.
The device then never recovered after a reboot and doesn’t load the GUI. I’ve tried removing and re-adding the NVMe, using rpi boot process again (it starts and closes immediately), the red button and red + blue button factory reset processes to no avail.
I’ve connected via Putty to perform a ha os datadisk wipe although this doesn’t seem to do anything.
Interesting entries in the boot process:
[ TIME ] Timed out waiting for device /dev/disk/by-label/hassos-data.
[DEPEND] Dependency failed for Home Assistant OS data partition migration.
[DEPEND] Dependency failed for HassOS data partition.
[DEPEND] Dependency failed for HassOS AppArmor.
[DEPEND] Dependency failed for HAOS swap file.
[DEPEND] Dependency failed for Docker persistent data.
[DEPEND] Dependency failed for Docker Application Container Engine.
[DEPEND] Dependency failed for HassOS supervisor.
[DEPEND] Dependency failed for Systemd persistent logging.
[DEPEND] Dependency failed for Flush Journal to Persistent Storage.
[DEPEND] Dependency failed for HAOS swap.
[DEPEND] Dependency failed for Ensure rauc.db contains version information.
[DEPEND] Dependency failed for Remove adopted rauc.db on first boot.
[DEPEND] Dependency failed for Grow File System on /mnt/data.
[DEPEND] Dependency failed for HAOS data disk detach.
[DEPEND] Dependency failed for HassOS data resizing.
[DEPEND] Dependency failed for File System … on /dev/disk/by-label/hassos-data.
[FAILED] Failed to start containerd container runtime.
See ‘systemctl status containerd.service’ for details.
Any advice is much appreciated.
Resources used:
Factory Reset for a CM5 HA Yellow?
https://yellow.home-assistant.io/guides/factory-reset/
