Usage on all your channels seems very high (the second number is a percentage). Here’s mine. ZHA is on channel 20, Z2M on 15:
"energy_scan": {
"11": 80.38447947821754,
"12": 84.164247274957,
"13": 88.70042934643088,
"14": 65.26028270288712,
"15": 31.01324838787301,
"16": 4.15070068297423,
"17": 12.244260188723507,
"18": 12.244260188723507,
"19": 70.89933442360993,
"20": 59.15797905332195,
"21": 6.011489450827149,
"22": 6.011489450827149,
"23": 8.631361812931262,
"24": 6.011489450827149,
"25": 1.1664179210724432,
"26": 62.257682586134884
This may indicate interference. I see you are using a USB extension cable - is it the one that came with SkyConnect? I replaced that with a 2m one. What wi-fi channels are your neighbours using? If they have their router on auto it may change from time to time.
I’ve noticed no difference after recent updates.
Edit: And I know this is a bit of a cracked record, but three routers is not going to get you very far. Zigbee doesn’t depend on signal strength (always weak); it needs many, many connections so that messages can take alternate routes. Here’s my map:
Another edit: I expect you’ve looked at all the guides:
