Zigbee buyer's guide
This topic is part of the community-driven cookbook where you can find other topics you might be interested in or might like to contribute to.
Summary
This post is aimed at newcomers to Zigbee - and possibly to Home Assistant - who have stumbled into the wild west of Zigbee devices and manufacturers. It does not recommend particular products; instead it advocates a cautious approach to buying. When it comes to cheap devices from China it really is a case of “buyer beware”. If you only take one thing away from reading this, it should be do your research.
Zigbee
Zigbee is a low-bandwidth communication protocol that relies on using small low-power digital radios to connect compatible devices to local Zigbee wireless private area networks. ZHA will create a single Zigbee network to which you can then pair/join most Zigbee-based devices that are made for home automation and lighting. In hardware terms of the hardware equipment needed usually consists of a USB radio adapter (the Zigbee Coordinator) plugged directly into the machine running HA.
You have a Zigbee Gateway application running that uses the Zigbee Coordinator as a radio and controller to create a Zigbee network as a local PAN (Private Area Network) it will automatically create a Zigbee network and you will be able to join/pair any Zigbee Router devices (normally mains-powered devices which each act as repeaters/extenders) and Zigbee End Devices (usually battery powered-devices that do not act as repeaters/extender).
Zigbee devices use low-power radios and therefore rely heavily on mesh networking to overcome the limitations of short range and poor radio propagation (i.e. very bad signal penetration of building materials). All of your Zigbee Router devices will relay messages to and from other Zigbee Router as well as battery-powered sensors and other non-router devices. Since every Zigbee router device (the mains-powered ones) can connect with every other one it makes a Zigbee network mesh very resilient as there are usually many possible paths for messages to take, and although the signal is weak it can find its way round walls and other obstructions.
(This is a generalisation, of course. In practice not all mains-powered devices act as routers and some routers are more effective than others - plugs and wall switches tend to have a more powerful signal than lightbulbs, for example. Still, you get the idea.)
Although Zigbee is respectable standard, maintained by the Connectivity Standards Alliance, it is also an open standard, which means that any manufacturer can put the name on the box. (In contrast, Zwave devices require certification from the Zwave Alliance, for which there is a fee.) In recent months there has been an explosion of inexpensive devices from China. The simpler ones (contact sensors, buttons) usually work as expected; more complicated devices (thermostats, TRVs) may not.
Zigbee Gateway integrations
You need a Zigbee Gateway. Home Assistant’s own built-in ZHA integration and Zigbee2MQTT which are two most popular open-source and hardware-independent Zigbee Gateway implementationsfor Home Assistant integration will allow you do use almost any Zigbee device with Home Assistant, and with either one of those you will be able to mix devices from different manufacturers. Which one of those you choose use in the end is a matter of personal preference (some people even use both of them, but they then need to use two separate Zigbee Coordinator adapters and device can not be on both networks at the same time). Both are equally stable. Whichever one you choose, the Zigbee protocol is the same.
Zigbee Home Automation (or “ZHA” for short) is the name of Home Assistant’s native Zigbee Gateway integration (built-in open-source component that is part of Home Assistant Core) . If you buy the official Home Assistant SkyConnect / Home Assistant Connect ZBT-1 Zigbee Coordinator adapter, then it will be installed by default; with a different brand/type of Zigbee Coordinator the installation and device discovery is still very simple through the GUI. If a device follow the standard Zigbee specification then will work with out-of-the-box with the ZHA integration. In practice icompliance with the standard Zigbee specification is less common than you might think and many devices need custom device handlers (also known as quirks) for the ZHA integration. In most cases such ZHA Device handlers (quirks) will be included for most common/popular devices in the latest release of the integration, but very new or odder types of devices may have missing features initially so you will need to submit a device support request and help provide information needed to develop new/additional ZHA Device handlers or extend existing zha quirks. More details here.
Zigbee2MQTT is an open source gateway application for controlling Zigbee networks - in other words, it performs the same function as (say) a Philips Hue bridge but it is not restricted to any particular manufacurer’s devices. It works well with HA and with other smart home systems. If you wish you can run it on a machine separate from your HA server - which means your lights will still work while HA is being restarted. As the name suggests, it needs a MQTT broker, which makes it more complicated to set up and maintain than ZHA, however Z2M supports more non-compliant devices. More details here.
Propriatory and commercial closed-source Zigbee Gateways/Bridges/Hubs/Controllers
A lot of manufacturers will suggest that you use their proprietary gateway/bridge/hub/controller. There are pros and cons with doing so. You will be restricted to using one manufacturer’s devices, but on the other hand you can resonably expect them to work with their brand of devices (or at least you will know who to complain to). This can be a good starting point with Zigbee if you only bug a few devices as you can always move all Zigbee devices you bought to either that built-in native ZHA or Zigbee2MQTT later. But see comments below. It’s certainly not a good idea to use more than one hub - things can get very messy and the best practice is always to consolidate all Zigbee devices to a single Zigbee gateway/coordinator if possible.
Do your research
There is a list of recommended Zigbee radio adapters in the HA docs, but do not just go out and buy the first radio adapter you see on that list. Generally you do not want to buy a radio adapter that is based on an old chip and is no longer getting firmware updates or one that uses a radio type/manufacturer that is not specificlly recommend for the Zigbee integration that you will use.
The Zigbee Device Compatibility Repository is a good starting point for devices of all kinds. It will give you an idea of whether a gadget works with ZHA or Z2M, but it’s user compiled so further checks are a good idea.
If you’re using Z2M, their webpage has a database of supported devices (with pictures - very useful).
If you’re using ZHA, have a look at the GitHub device handler issues page. This will tell you what devices other people have requested support for - and whether support has been added. It will also give you a good idea of which devices are problematic.
Above all, before you part with your credit card number, search this forum and ask questions. There may be a few ranters :roll_eyes: but someone somewhere will probably already have tried out the device you’re considering.
In January 2024 about half the problem devices forum members posted about were Tuya. Just saying.
A final thought
End devices - switches, contact sensors, movement sensors etc. - are the exciting part of a Zigbee network but they won’t work properly without plenty of routers. Build the backbone of your network first - lights, plugs, wall sockets, mains-powered devices generally - then add the fun stuff.
Other Zigbee guides
Not many people know that... A random collection of Zigbee trivia
The Home Assistant Cookbook - Index
Best Overall Zigbee Stick
Convert from ZHA to Zigbee2MTTQ
Xiaomi Temperature Sensor not working anymore
Zha disable device router for one device
Home Assistant Cookbook - Discussion Thread
I want to start over, useful tips? Which hardware to support Zigbee2MQTT
New zigbee coordinator, adjust configuration
Connect Zigbee devices
Bosch Thermostat 2
What am I missing out on when I add aqara devices to my zigbee Network whithout using the aqara hub?
1% Failure Rate - Help!
New setup on new device
Zigbee range extension over ethernet? Multiple coordinators?
Building a new house looking to use HA
Zigbee network optimization: a how-to guide for avoiding radio frequency interference + adding Zigbee Router devices (repeaters/extenders) to get a stable Zigbee network mesh with best possible range and coverage by fully utilizing Zigbee mesh networking
Noob - zigbee ZHA vs zigbee2mqtt
Total newbie, fundamental concept
Issues with HA Yellow & ZHA / Philips Hue after a long period - Help a noob
ZHA Zigbee deconz warnings
Added USB device to my device and ZigBee stopped working
ZHA and devices not reliable issues
How to configure Yellow built-in Zigbee to use external antenna?
ZigBee/Thread/Matter sensors
Skyconnect multiprotocol versus zigbee only
Is a second Zigbee network the right approach?
Zigbee Utilization 90%, normal for 130 devices?
Move from EZSP to EMBER
Zigbee2mqtt + skyconnect, cant get it to work
Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
Integrating hue bulbs without hue bridge + possible switches
Struggling to get an open / close sensor to be reliable
Zigbee router/repeater range
MOES Tuya Zigbee RF433 + HomeAssistant + Alexa working?
Home Assistant Yellow use built in Zigbee or keep Sonoff Dongle
How to make SkyConnect find my lamps?
Zigbee Home Assistant controlling Hue Gradient
Hue fried, planning to move to dedicated dongle
Zigbee repeater
ZBDongle-E - flash or not?
Are any adapters fully supported out of the box without flashing?
Skyconnect: device paired successfully, next day lost, now does not connect-pair anymore
Zigbee Connectivity in my house sucks 😢
Connecting Zigbee devices over the internet
Nortek and mesh Zigbee
Philips Hue Multi Sensor hasn't worked properly since I connected it via ZHA
If you had to start from scratch would you go skyconnect or sonoff?
Cannot Connect new Devices to conbee II Stick
Hue Integration Fails - "This entity is not available"
Zigbee (migrate from ZHA to Zigbee2MQTT)
ZHA vs Zigbee2Mqtt - which is the most stable?
Zigbee Stuck on uploading file
Conbee II TXStatus
Zigbee network utilization - options
Migrating from a Philips Hue Bridge to the ZHA (Zigbee Home Automation) integration
Multiple Zigbee errors - no hardware/ software change
Zigbee Stick - state of the art
LocalTuya/tuya-local vs ZHA/Z2M for Tuya Zigbee devices
Connect ZigBee remote directly to coordinator instead of router?
Integration Battle: stock ConBee II vs. deCONz
Mains powered Zigbee devices that aren't routers
Make sure a device is not used as router
Best way to configure WiFi Tuya sensors?
IKEA Trådfri & Rodret with HA?
Can add IKEA RODRET Wireless dimmer to Zigbee ZHA, but cannot see button press in logbook?
HA 11.5 sensor showing 4 entities as Unavailable?
Zigbee / Homeassist Options
Zigbee #1: where can I find a list of supported devices?
Zigbee smart relay/switch like Shelly Mini Gen 3
ConBee III (ConBee 3) from Dresden-Elektronik based on Silicon Labs EFR32MG21 +20dBm radio SoC/MCU
Starting advice for a Zigbee newbie
Newbee in IoT
SmartThings SmartSense Multi (2013) works on zigbee, but then hours later vanishes
Home Assistant + Aqara + Tuya
ITead’s “Sonoff Zigbee 3.0 USB Dongle Plus V2” (model "ZBDongle-E") based on Silicon Labs EFR32MG21 radio SoC/MCU
The best Zigbee Coordinator hardware radio adapter to buy (updated in December 2024)
Zigbee Coordinator product purchase recommendation summary:
If you today want a plug-and-play Zigbee Coordinator USB radio adapter that will work great out-of-the-box with either Home Assistant’s ZHA integration (built-in Zigbee gateway implementation) or Zigbee2MQTT (third-party Zigbee gateway application that can run stand-alone) then currently the best purchase recommendation is to buy a Texas Instrument CC2652P based USB radio adapter dongle with external antenna, (like for example ITead’s Sonoff ZBDongle-P , flashed with the latest stable community build of TI's Z-Stack Zigbee Coordinator NCP firmware). (The only downside with using CC2652-based USB radio adapters is that there are currently no built-in features to upgrade Z-Stack Zigbee Coordinator firmware so that has to be done using third-party add-ons and external tools).
Update: Zigbee2MQTT now also have has full support for Silcon Labs EFR32MG2x (EFR32MG21, EFR32MG24, EFR32MG26) based adapters using Silabs EmberZNet Zigbee stack via Z2M's ”ember” adapter driver which is now enabled by default and very stable today as long as the Zigbee Coordinator adapter is updated to EmberZNet 7.4.x.x Zigbee NCP firmware or later.
If you are however sure that you will only be using Home Assistant’s ZHA integration (built-in Zigbee gateway implementation) (and not Zigbee2MQTT) then the better option is to instead buy the official Home Assistant SkyConnect / Home Assistant Connect ZBT-1 (USB radio dongle from Nabu Casa) o get an excellent user experience and super easy lifecycle maintenance. Most other Silicon Labs EFR32MG2x (EFR32MG21 or newer) based radio USB dongle with Silabs EmberZNet Zigbee NCP firmware (not RCP firmware) will also give you a similar ease-of-use user experince when sticking to the Home Assistant’s ZHA integration (built-in Zigbee gateway implementation) (and not Zigbee2MQTT).
Obviously if if instead plan on using deCONZ/Phoscon then your only real choice today is the new ConBee III / ConBee 3 USB adapter from Dresden-Elektronik, (which does also work with the ZHA integration and Zigbee2MQTT but is not recommended as it does not quite have full feature paritry or the same support as the modern Texas Instruments and Silicon Labs based adapters, which has backup and migration support that is not available for deCONZ based adapters).
The reasons for buying those specific Zigbee Coordinator hardware radio adapters are:
If you’re using Home Assistant Operating System (HASS), Supervised, or Container, it’s recommended to use an external USB radio dongle (i.e. USB stick format) rather than an internal GPIO module, because not only do you get better reception with an external USB radio dongle, but passing a serial module through Docker can sometimes be more complicated than passing a USB adapter through, (at least if not using the Silicon Labs based EFR32MG21 radio module that if built-into the Home Assistant Yellow appliance).
Tip; in a few edge cases it might be worth looking at a network-attached Zigbee Coordinator adapter (also referred to as Zigbee LAN adapters) like the Zigbee-to-Ethernet/USB Serial Coordinator solutions from TubeZB, and similar products from ZigStar, SMLIGHT, or cod.m as another alternative way to workaround the problem of relocating a Zigbee Coordinator radio adapter to a remote location for better reception, but please understand and respect that I personally think that using a such network-attached Zigbee Coordinator adapter should a solution should only ever be the exception when there is no other solutions and not the go-to rule, as please note that all those are proxy-servers uses Serial-over-IP tunneling which adds a little more complexity than simply using a very long USB extension cable (which I personally recommend using instead). I therefore personally believe that in most use bases it will be both easier and better to just use a very long shielded USB extension cable and a tip there is that you can easily achieve up to around 30 meters by using inexpensive “USB Ethernet RJ45 Extender Adapter” converters which easily and practically convert any single CAT5e/CAT6 shielded Ethernet cable with RJ-45 connectors into a very long passive USB extension cable (as it does not use LAN or IP but only converts an RJ45 Ethernet cable to a dumb USB extension cable). With such a solution you can use any Zigbee Coordinator USB dongle and easily replace the USB dongle later too (which should make for a less expensive solution in the long run). See example -> https://www.amazon.com/Male-RJ45-Female-Extension-Adapter/dp/B083W3D65G Note! An additional caution warning about using Zigbee Coordinator network adapters over Wi-Fi/WAN/VPN. Be aware that using a Zigbee Coordinator via a Serial-Proxy-Server (also known as Serial-to-IP bridge or Ser2Net remote adapter) over a Wi-Fi, WAN, or VPN connection is not recommended. Serial protocols used by the Zigbee Coordinator do not have enough robustness, resilience, or fault tolerance to handle packet loss and latency delays that can occur over unstable connections. A Zigbee Coordinator requires a stable local connection to its serial port interface with no drops in communication between it and the Zigbee gateway application running on the host computer.
While most Zigbee Coordinator adapter hardware of different radio types should work great if using Home Assistant’s ZHA integration (and setup according to best practises), it should be noted that currently only Texas Instruments CC2652 and CC1352 based Zigbee Coordinator adapter hardware radio types are commended if using Zigbee2MQTT (which is due to the adapter code for other radio types in Zigbee2MQTT not yet offering feature parity with the adapter code for Texas Instruments based adapters, and most notable full backup + restore functionality is not available in Zigbee2MQTT and therefore it list support for other adapters as "experimental").
Also note that support for commissioning Zigbee 3.0 devices via “Install Code” or “QR Code” via has so far only been implemented for ‘ezsp’ (Silicon Labs EmberZNet) or ‘znp’ (Texas Instruments Z-Stack) radio type in Home Assistant’s ZHA integration and Zigbee2MQTT. Other radio types like deconz (ConBee/RaspBee) and ZiGate are still missing “InstallCode” support in their respective radio libraries and manufacturer’s firmware commands/APIs or their serial interface documentation (i.e. ConBee/RaspBee and ZiGate have not added support for it to their firmware and/or not published API documentation).
The best dedicated Zigbee Router (repeaters/extender) devices to buy
Zigbee Router (repeaters/extender) product purchase recommendation summary:
To get the “best-of-the” Zigbee Router devices today it is recommended to buy a few Silicon Labs EFR32MG21 based USB radio dongles with an external antenna (like for example ITead’s Sonoff ZBDongle-E (based on Silicon Labs EFR32MG21 radio SoC) and convert/repurpose them by flashing over USB with a Zigbee Router firmware image, after than you can simply power them via USB-changers and pair to have them work as stand-alone dedicated Zigbee Router devices. An alternative is ITead’s Sonoff ZBDongle-P (based on Texas Instruments CC2652P radio SoC) which also can be reflashed with Zigbee Router firmware and repurposed as a stand-alone dedicated Zigbee signal repeater and range extender devices.
For all-in-one dedicated Zigbee Router products that work very well out-of-the-box, it is recommended to buy a few of IKEA’s Trådfri Signal Repeater devices and/or Aeotec’s Range Extender Zi products. Both of those devices are based on Silicon Labs EFR32MG21 radio SoC, and many people have reported that Silabs EFR32MG21 based products with slightly better as dedicated Zigbee Router devices than TI CC2652 based producs.
The reasons for buying and using those specific products as Zigbee Router devices are:
Having a few “great” Zigbee Routers (a.k.a. Zigbee signal repeaters / Zigbee range extenders) with better radios and antennas for better reception can affect in Zigbee network mesh range and coverage performance positively as communication signals in Zigbee do not have to be resent. Acting as a stable backbone in your Zigbee network mesh. Also, adding at least a few "know good"dedicated Zigbee Router devices between the Zigbee Coordinator and any devices having issues will normally make a huge difference.
You have to understand and remember that each Zigbee device by itself has very limited coverage, short range and their weak signals have poor wall penetration, so to workaround this a Zigbee network relies on mesh networking (a type of network topology/technology/architecture), which means that a Zigbee network heavily depends on having a swarm of mains-powered devices are a “Zigbee Router” that are always-on so they can act as a signal repeater and range extended by transmitting data over long distances by passing data messages through the Zigbee network mesh of intermediate devices to reach more distant Zigbee devices.
So while having a Zigbee Coordinator with good radio and antenna away from any EMF sources can have similar benefits, Zigbee signals have such poor range and bad wall penetration power so having many good Zigbee Router devices is a must.
I strongly disagree with most of what is in that statement. Because of the way Zigbee architecture works users should really try hard to put all their Zigbee products on a single Zigbee gateway (with a single Zigbee Coordinator). In short, because each Zigbee device can only belong to a single Zigbee network it means that if your Zigbee devices risk getting crappy reception if you do not have many Zigbee Router products on that same Zigbee gateway, as chances are that if the user has several Zigbee hub/gateway/bridge/controller/coordinator appliances then they will not have many Zigbee Router devices on each (or at least not a big chance they have those spread out throughout their home for best range and coverage in each network). Without many Zigbee Router devices in each Zigbee network a user is very likely to a bad experience with slow response and latency because of dropped messages and connection issues with devices dropping off the Zigbee network due to bad reception.
Therefore, I advise against buying any proprietary hub/gateway/bridge/controller/coordinator appliances as not only do most such commercial appliances only support their own branded devices and a few of their partner’s devices, but it is also very important to understand that Zigbee radios have poor range, bad wall penetration + are extremely sensitive to EMF interference, and because of that communication within a Zigbee network heavily relies on its mesh networking technology and depends on having many Zigbee Router devices (Zigbee extender/repeater products) on the same Zigbee network. Plus the fact that proprietary hub/gateway/bridge/controller/coordinator encourages vendor lock-in and steering users to their ecosystem, complicates setup by having to have several different hubs with separate apps and accounts (most of them requiring a cloud account even if they can be controlled locally).
In my humble opinion, the only benefits proprietary hub/gateway/bridge/controller/coordinator appliances offer other than official firmware updates and user-friendly startup user interface for beginners are that they almost always have full compatibility for their own brand-new devices from the first day they are released on the market, while with Home Assistant’s built-in ZHA integration and later migrating to Zigbee2MQTT you might have to wait for a developer to write some custom device handler (quirk/converter/translator code) to expose non-standard entities if the product is using manufacturer specific Zigbee clusters and attributes that enable the manufacturer to extend the Zigbee feature set (which the Zigbee specification allows in order to be flexible but unfortunately means that not all features and functions can be predicted and added in advance).
Having more than one integration and different phone apps for adding Zigbee devices quickly becomes a mess and more finicky to maintain than it is worth. As such, I argue that it is much better to do the reverse; thus recommend starting with Home Assistant’s built-in ZHA integration and later migrating to Zigbee2MQTT (or proprietary hubs) if Home Assistant’s built-in ZHA integration does not meet your requirements.
As such, I want to generally recommend always starting by buying separate USB radio adapters for each wireless IoT protocol and using Home Assistant’s built-in integration with native support for those, (there are normally a dedicated integration for each standard IoT communication protocol), that way you can make a single installation of the Home Assistant Operating System itself into a central all-in-one hub/gateway/bridge/controller/coordinator system, with just a single computer to rule them all :wink:
or
  • Zigbee2MQTT (Z2M) third-party Zigbee gateway application that can run stand-alone or as an add-on in Home Assistant (always communicating via MQTT with Home Assistant) → https://www.zigbee2mqtt.io
From a pure end-user experience point-of-view things might have worked difference in the past if go back a few years before Home Assistant’s built-in ZHA integration and Zigbee2MQTT became as relatively mature are they are today. Personally I feel that the only two major things left to become more mature is the UI presentation for each individual device and support for more OTA firmware updates sourced directly from official manufacturers, both of which can hopefully partially be achieved in the future through formal partnerships like the “Works with Home Assistant” program for partners → https://partner.home-assistant.io/
Again, I suggest starting by buying ITead’s TI CC2652P based “Sonoff Zigbee 3.0 USB Dongle Plus” (which is now renamed to “ZBDongle-P”) as a dedicated Zigbee Coordinator radio adapter → ITead's "Sonoff Zigbee 3.0 USB Dongle Plus" (model "ZBDongle-P") based on Texas Instruments CC2652P +20dBm radio SoC/MCU
Alternatively, get the Home Assistant SkyConnect USB dongle which support Zigbee and Thread, though personally I really suggest getting separate dedicated USB radio adapters for each protocol (so an option there is to get two Home Assistant SkyConnect USB dongles).
Another related alternative option is to get the Home Assistant Yellow for running Home Assistant on as that like a Raspberry Pi with an embedded Home Assistant SkyConnect radio adapter module on the board:
Btw, there are of course also USB radio adapters + integrations for other popular wireless IoT protocols:
There are even some less common and older wireless IoT protocols (if you already own such devices as I’m not recommending such devices for new purchases), like:
FYI, several third-party alternative solutions support using USB radio adapters directly as well but better to research those on a protocol-by-protocol basis by looking at specific device compatibility, (again like for example Zigbee2MQTT for Zigbee instead of the built-in ZHA integration), overall I generally recommend starting with the natively built-in integration as they are more often than not easier to get started with, and you can later always migrate your devices to third-party alternative solutions per protocol if you feel that the built-in integration for that protocol does not meet for needs for the devices that you bought.
Generally, I say that Zigbee has the most amount of different devices on the market but can be finicky and higher maintenance to maintain, while Z-Wave devices are more expensive but more or less just works. And as for Matter there are so few Matter over Thread devices on the market and the standard is not mature (with BETA stage in Home Assistant) so I think it is not worth bothering with until a few years from now.
Note! Zigbee, Z-Wave, and Thread all depend on mesh networking technology which in essence means that they practically rely on having many mains-powered devices on the same network mesh that act as routers/repeaters/extenders, so it is not a good idea to start with only a few battery-operated devices on any such wireless IoT protocol networks. While for Bluetooth Low Energy (BLE) devices you really also need have a few ESPHome Bluetooth Proxy devices for good connection if spread out them out in a large home. For Zigbee read and follow tips here → Zigbee networks: how to guide for avoiding interference and optimize for getting better range + coverage
PPS: You can also do similar for some wired IoT protocols, such as the KNX integration, but for some wired IoT protocols it can be better to use an external converter device that is based on ESPHome or an external bridge that convert to a universal IoT communication protocol like MQTT.
One thing to note on the coordinators is that you also can get network based ones, like the ones mentioned here.
The advantage with these is that you are not bound to a single host / server / device (ideal when running clustered hypervisors for example) to run the coordinator and you can place it where ever you want as long as you have network and power.
A warning is to never connect a Silicon Labs based network-attached Zigbee Coordinator over a WiFi. Any network-attached Zigbee Coordinator should use a wired LAN (Ethernet) connection, but especially those with Silabs radios absolutely need to use a wired LAN connection because the EZSP (EmberZNet Serial Protocol) requires a stable connection for communication as Silabs have not been designed to be robust so it does not handle dopped message packages well, (serial protocols are usually not built to not enough fault-tolerance to handle packet loss or latency delays that can normally occur over WiFi connections). Tunnelling serial communication not designed to run via IP over a network is not optimal regardless of the serial protocol used. See ZHA and Z2M documentation:
https://www.home-assistant.io/integrations/zha#warning-about-wi-fi-based-zigbee-to-serial-bridgesgateways
https://www.zigbee2mqtt.io/advanced/remote-adapter/connect_to_a_remote_adapter.html
https://www.zigbee2mqtt.io/advanced/remote-adapter/connect_to_a_remote_sonoff_zbbridge.html
If you are not running your Zigbee gateway application in a clustered hypervisors then it is generally a better idea to just use a long USB extension cable, and a tip there is that while a normal USB extension cable can only be about 5 meters long you as an alternative can buy inexpensive a USB to RJ45 extender adapter kit that will convert any shielded Ethernet (STP like CAT6) cable into a very long USB extension cable. See example::
Yes absolutely, a good practice is to use wired connectivity on all devices that supports it
:slight_smile:
I can’t emphasise this enough ! Unreliable network / devices being unavailable is the single most common issue people have with zigbee … and it can generally be attributed to (a) not enough routers, and/or (b) not planning your wi-fi & zigbee network to reduce interference.
I know from my own experience of adding devices that sounded interesting, then a couple of routers when I noticed unavailable devices. It did not improve the situation. My devices remained paired with my controller, leaving the routers doing nothing. Some people suggest that moving to Z2M is the answer - but I believe it is rebuilding the network that actually is the fix.
But before rebuilding your zigbee network, consider what wi-fi channels you and your neighbours are using, and what zigbee channel will fit best. I can’t change my neighbours wi-fi … but I changed the wi-fi channels I use for my 2 WAPs and zigbee to minimise interference.
You don’t directly mention it in your experience. I would recommend that before pairing your first device in Zigbee (with Zigbee system that support the function), you understand how to ‘add via’ a device via a router. And then observe the results over a period of time using the ping/map function of the Zigbee system.
Many thanks for this manual - and two questions:
  1. Is there a manual on how to check / optimize the Zigbee channel?
  2. Do the USB-Connected Zigbee sticks benefit from USB 3.0 or is it ok to use USB 2.0 especially when it comes to cable length around 5m and the decision between normal extension cables and those with a repeater Chip at the female end of the cable?
You should only connect to USB 2.0 sockets - USB 3.0 creates a lot of interference. USB 3.0 extension cables are OK, though - in fact they may be better because they have more shielding. If you only have a USB 3.0 socket you can connect it to a USB 2.0 powered hub and connect the Zigbee dongle to that.
All this is covered by:
There’s a great post here:
Avoid IKEA white spectrum LED2003G10 and LED2004G8 like the plague.
The come with old 20201111 firmware, no updates. They act as routers but will throw away battery powered devices after some minutes. Thus battery powered will have to spend many seconds and lots of power reconnecting to the network. They made my battery powered wall switches useless. And are lots of battery.
I’m starting to build my Zigbee network with HA and Zigbee2MQTT.
I’ve already installed a Sonoff DONGLE-E and upgraded the coordinator firmware to version 7.3.2.0 build 212.
I’m now looking to buy several smart plugs that will double as routers to form the backbone of my Zigbee network.
I’m having trouble identifying good options for these smart plugs and would love some advice (I’m based in Europe).
I’d like the smart plug to provide basic on/off capability, as well as measure of power & energy consumption.
It seems that most Zigbee smart plugs (for example: NOUS A1Z) are based on the TS011F chipset, which seems to frequently suffer from disconnection issues, leading the plug to turn off attached devices.
I also looked into the Aqara SP-EUC01, but the 2022 firmware update seems to be causing lots of trouble. See Xiaomi Aqara Plug (SP-EUC01/lumi.plug.maeu01) Toggles without reason
So what would you suggest?
Other options that don’t fit my requirements:
  • IKEA TRADFRI: a bit bulky, and doesn’t measure power / energy.
  • AEOTEC Zigbee range extender: doesn’t provide a socket, nor measure power / energy.
Thanks in advance for your help.
These you can plug in to USB or straight into the wall. TRÅDFRI Signal repeater, Width: 47 mm - IKEA
I have a single SP-EUC01 with the 2023 firmware, it has never toggled off or on unwanted.
I am bit little confused.
SMLIGHT SLZB-06 is recommended when using Z2M
SMLIGHT SLZB-06 M is recommended to use with ZHA
But smlight website says that EFR32MG21 can work with Z2M and In practice, these chips show more stable operation than CC26* in Zigbee coordinator mode.
Is it future-proof today to get SMLIGHT SLZB-06 M with EFR32MG21 when planning to use Z2M ?
And also i can connect this to my router and it’s not needed HA pc usb connecting?
Read my recommendation and explanation in the post above → Zigbee buyer's guide - #2 by Hedda
Summery; Silabs adapters are not yet recommended → https://www.zigbee2mqtt.io/guide/adapters/
As well as note this warning:
WARNING! WiFi-based Serial-to-IP bridges are not recommended as the serial protocol does not have enough fault-tolerance to handle packet loss or latency delays that can normally occur over WiFi connections. See these references that same recommendation applies to both Zigbee2MQTT and ZHA:
In short, if want a more stable Zigbee setup then do not use Serial-to-IP remote adapters over Wi-iFi.
Also see:
I don’t see TRÅDFRI Signal Repeaters on IKEA’s US website. Have they been discontinued?
Anyone have any SLZB-06? I have had 2 thus far and both get power but I can never get them to connect to my network.
Tried POE and USB power with no difference. The light on the LAN port never blinks
FYI: I have a UZG-01, and that connects just fine with POE.
I have two and had no problem connecting them.
Thanks, seems to be random so not sure the quality of these things, maybe a bad batch, I have a thread here Smlight slzb-06 and seems like I am not the only one with the issue.
