I had a crash of my home-assistant system in the past, that wouldn’t startup again.
I did an fsck of the storage-card and managed to start the system up again.
After that I think the contact to my knx-devices worked initially and stopped working.
So I decided to make a complete snapshot-backup and reinstall home-assistant.
I’m running hassio v 4.13 - 32-bit on an Raspberry Pi 3
Supervisor 245
When I restored the snapshot-data I found some issues in the log-files about UPnP and others, which is why I removed all UPnP-devices for now.
All knx-related devices are not reachable and I can only find the following message in the
config/home-assistant.log file
ERROR (MainThread) [homeassistant.components.notify] Failed to initialize notification service knx
I already tried to reload core, restart hass and reboot.
here is an excerpt of the first lines of my config.yaml
homeassistant:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
logbook:
#recorder:
# purge_keep_days: 40
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
language: 'de'
#group: !include groups.yaml
#automation: !include doorbird_automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
cover: !include cover.yaml
light: !include light.yaml
climate: !include climate.yaml
shopping_list:
discovery:
ignore:
enable:
- dlna_dmr
knx:
tunneling:
host: '192.168.x.<knx-gw-addr>'
port: 3671
local_ip: '192.168.x.<home-assistant-addr>'
# config_file: '/config/xknx.yaml'
expose:
- type: 'binary'
entity_id: 'binary_sensor.wind_above_60'
address: '0/0/5'
- type: 'binary'
entity_id: 'binary_sensor.wind_above_60_mattsee'
address: '0/0/5'
- type: 'binary'
entity_id: 'binary_sensor.taupunktalarm'
address: '3/3/25'
