Fairland heat pump to HA
Thanks Jurgen, look at that, I’m from Belgium as well.
I have the Wifi built-in and thought you could attach an extra antenna, this doesn’t seem to be the case.
I’m gonna give below solution a go. See if that works.
Controlling a Fairland Pool Heatpump eliminating Tuya - Share your Projects! - Home Assistant Community (home-assistant.io)
