Feedreader update time is set to one hour by default.
I’d like to adjust it to some minutes. And there is no way to change it somehow.
You can modify the polling frequency of any integration via the UI. In the integrations configuration settings/optins, turn off polling. Then make an automation that uses homeassistant.update_entity
at whatever interval that you want. This is the intended way to alter polling frequencies.
