Feedreader: variables in Notification Message
Hi Guys,
I have read the docs about the feedreader but I couldn´t figure out/understand the “logic” behind the variables in the example.
I am starting with the AS IS - State:
I have configured a Feedreader in my configuration.yaml
feedreader:
  urls:
    - https://logbuch-netzpolitik.de/feed/m4a
  scan_interval:
    minutes: 30
  max_entries: 5
  1. I have successfully configured a very very basic automation which notifies me via Telegram:
alias: Auto_Feedreader_LNP_Notification
description: ""
  - platform: event
    event_type: feedreader
    event_data:
      feed_url: https://logbuch-netzpolitik.de/feed/m4a
condition: []
  - service: telegram_bot.send_message
      message: lnp
mode: single
and it is working very solid (but not very elegant).
My Problem:
The Docs say
Any field under the <entry> tag in the feed can be used for example trigger.event.data.content will get the body of the feed entry.
What do they mean with “entry tag”?
I looked in the feed_url of the example Home Assistant Podcast but I could not find anything with “entry” I also looked for something like data.content, still having no clue.
I simply cannot figure out to how to get the link for example from Logbuch:Netzpolitik
grafik
How should the variable in my message look like, especially in my case and especially how can you find it out?
ATOM feeds use <entry> tags, while RSS feeds use <item> tags.
In general, the RSS structure is transformed into a data structure that you can access.
Title: {{ trigger.event.data.title }}
Link: {{ trigger.event.data.link }}
Now, that does not work for all tags in the RSS, for example pubDate is actually transformed into published. The only reason I know this is because I worked with the underlying Python library in the past - and there is some more documentation available.
To understand what’s actually in the event data you could just log the raw data in your automation:
  - service: system_log.write
      level: error
      message: "{{ trigger.event.data.content }}"
Thanks for the very structured solution and your time. Gonna test it out…
Thanks!
Update: Didnt work out for now, but I think it was my Problem… will test again and provide the logs because there was an error but I lost the errorlog.
I just created 3 testautomations to find out which trigger should work out.
It is hard to debug this whole thing, because I need to wait for the feedreader event and I just simply cannot rerun the automation because it looks like the automation can just fetch the variables when it has legitimately been triggered. When running it manually via “run”-Button there do not seem to be any Data available… grafik
for further testing I also added the system_log.write service in another automation.
That’s correct - running an automation manually basically just skips the defined trigger, and there is no way to define sample trigger event data.
Update:
It took half an eternity. :slight_smile:
  1. I have received some notifications:
  message: lnp 1 {{trigger.event.data.title}}
  message: lnp 2 {{trigger.event.data.link}}
Following message didnt work though:
  message: lnp 3  {{trigger.event.data.content}}
So this is a great success!
grafik
Nevertheless I still dont get it how to get the variable on my own, or is it really a “written rule” that data.title and data.link always work with rss feeds? If yes: are there any docs where I can get other vars?
  1. system_log.write gives me infos I cannot start with, but it gives me following:
    (uploaded on pastebin to prevent spam)
    lnp_log - Pastebin.com
Unfortunately this is not well documented. I had a look into the source code of the feedparser Python library to understand how the transformation of RSS/Atom feeds works and how information is then presented in this integration.
Comparing the log output with the actual feed, it looks like you get an array with 2 entries - the first entry is the item’s description, and the second entry is the the item’s content:encoded.
I try also to send news by telegram.
But I have issue with this automation :
- id: news
  alias: News
  description: News
  - platform: event
    event_data:
      feed_url: https://www.lemonde.fr/rss/une.xml
  condition: []
  - service: input_text.set_value
      value: "{{ trigger.event.data.title }}"
      entity_id: input_text.news_title
    enabled: true
      value: "{{ trigger.event.data.description }}"
    enabled: true
      value: "{{ trigger.event.data.link }}"
      entity_id: input_text.news_link
    enabled: true
  - service: input_datetime.set_datetime
      value: "{{ trigger.event.data.date }}"
      entity_id: input_datetime.news_date
    enabled: true
  - service: notify.lilp_bot
      title: Batterie faible
      message: News "{{ trigger.event.data.title }}"
I have this message in Step details :
Error: Error rendering data template: UndefinedError: ‘dict object’ has no attribute ‘event’
And in Trace TimeLine :
Triggered manually at 2 novembre 2023 à 10:44:28
Appeler le service “Saisie de texte: Définir” sur News Title
Stopped because an error was encountered at 2 novembre 2023 à 10:44:28 (runtime: 0.02 seconds)
Thanks for your help.
When you manually trigger this automation, there is no event fed into the actions, and thus the templates fail.
You always need to wait until the Feed comes “on its own”.
@lilp69
No possibility of manually triggering the sending of news at a specific time
Like i said: You always need to wait until the Feed comes “on its own”
This thread already says it multiple times.
Therefore you have 2 options:
  • Create your own feed and simulate a manual trigger.
  • or Wait.
Is there a way to test this locally, as my feed from Biblegateway is once a way and that is a very long wait. I have been trying to get the description but am successful only with the verse.
Only the title and the notification works all other input_text helpers have value of unknown.
alias: Send notification of RSS feed title when updated Bible
description: "Bible Gateway "
triggers:
  - trigger: event
    event_data:
      feed_url: https://www.biblegateway.com/votd/get/?format=atom
actions:
  - action: persistent_notification.create
      title: New Bible verse available
      message: >-
        New Bible Verse available - {{ as_timestamp(now()) |
        timestamp_custom('%I:%M:%S %p %d%b%Y', true) }}
      notification_id: "{{ trigger.event.data.title }}"
  - action: input_text.set_value
    metadata: {}
      entity_id: input_text.bibleverse_verse
    metadata: {}
      value: "{{ trigger.event.data }}"
      entity_id: input_text.bibleverse_verse_2
    metadata: {}
      value: "{{ trigger.event.data.summary }}"
      entity_id: input_text.bibleverse_summary
  - action: notify.persistent_notification
      message: Notification message RSS  "{{ trigger.event.data.content }}"
      title: Bible event data
It changed in the meantime you need to do this via UI as far as i know. Feedreader - Home Assistant
And after adding it via the UI you get a sensor:
Maybe this helps
This is my Automation which works @vgerald
description: ""
mode: single
triggers:
  - entity_id:
      - event.logbuch_netzpolitik
    attribute: title
    for:
      hours: 0
      minutes: 0
      seconds: 5
    trigger: state
conditions: []
actions:
  - action: telegram_bot.send_message
    metadata: {}
      message: >-
        LNP {{ state_attr('event.logbuch_netzpolitik', 'title') }}   {{
        state_attr('event.logbuch_netzpolitik', 'link') }}
@The-May Thank you!
I will review the event. Thanks for sharing your Automation code.
@The-May Thanks again!
I used the event to build by Markdown card to show the Bible verse.
just be careful with the home assistant feed descriptions…
I mean: yeah you are right, but it depends on whether I want a wall of text or not.
Gerald def. wants a wall of text, so I guess it depends on context :stuck_out_tongue:
