Filter positive or negative value changes in a sensor entity
Template Blueprint
Filter_positive_or_negative_value_changes_in_sensor_entity.yaml
This template blueprint will add either the positive or negative value changes (increase/decrease) in a source entity to a destination entity. The destination entity will always increase.
Use it to split balancing entities like into import/export, charge/discharge, load/unload entities which always count up. Implement one template blueprint for positive changes and one for negative changes as needed.
Background
For example, energy import and export is often measured in a net entity that will increase when importing and decrease when exporting. The energy dashboard expects import and export in separate entities.
An example is the HA core Enphase_Envoy integration that provides data for the IQ Gateway a.k.a Envoy. In some setups only a net sensor is available for grid import/export or battery energy is only available in energy content changing with charge and discharge.
Prerequisite
This blueprint requires the home assistant Uptime integration to be installed with a template sensor for it configured. This uptime sensor is used to detect Home Assistant restarts and must be specified as input.
Unavailable/unknown states
This blueprint depends on change from a previous value. To handle HA outages or entity unavailable/unknown status, it caches the last good value prior to these states as an attribute of the destination entity.
It will however not differentiate if both positive and negative changes occur during those situations, only the net change over the outage is determined using the cached last good value prior and new good value received post the situation.
Blueprint Inputs
The blueprint accepts below inputs for configuration:
source_entity
Source sensor entity to monitor for value changes.
Required input
changes
Specify if positive or negative value changes (increase/decrease) should be added to the destination sensor.
Optional input, default positive changes if not specified.
Options: positive or negative.
uom
Unit of Measurement to use for the destination entity.
Required input.
uptime
Specify an Uptime integration sensor to use for HA startup detection.
Required input.
Device_class: duration sensor entity (see below in example)
uptime_delay
Delay time in seconds for the uptime trigger to fire after HA startup.
Optional input, default 10 seconds if not specified.
correction_value
One-time correction of the destination entity value.
Optional input, default 0 if not specified.
Can be used to set an initial value or apply a correction later. The correction is only applied when this setting is changed from a previous specified correction value.
For example when value 100 was specified in the template, 100 is added 1 time to the destination entity value. If later another correction of 2 is needed, just change the input to 2 and reload the template entities.
decimals
Number of decimal places to round destination value to.
Optional input, default 6 if not specified.
Templates
Filter positive value change
To filter positive or negative value changes into sensor entities add templates like below to your template configuration yaml file.
- use_blueprint:
    path: catsmanac/filter_positive_or_negative_value_changes_in_sensor_entity.yaml
    input:
      source_entity: sensor.net_grid_energy
      uptime: sensor.ha_uptime
      changes: positive
      uom: kWh
  name: grid energy import
- use_blueprint:
    input:
      changes: negative
      uom: kWh
  name: grid energy export
Uptime entity
To create an Uptime sensor entity add a template like below to your template configuration yaml file.
- sensor:
  - name: HA Uptime
    unique_id: ha_uptime
    state: >
      {{ (as_timestamp(now()) - as_timestamp(states('sensor.uptime')))|int }}
    unit_of_measurement: 's'
    device_class: duration
    state_class: measurement
FYI you can get the previous state without storing it like you do. Using this.state
I’d also recommend adding restrictions to your uptime sensor as most uptime sensors are datetime objects not counting up numbers.
Thanks for the feedback @petro.
If I’m not mistaken, this only refers to the target entity and I need the previous state of the source entity before it became unavailable or unknown
How would I do that? I’m pretty new on template blueprints.
But you have this convoluted way to get the attribute
{% set saved_previous_state = state_attr(this.entity_id, ‘previous_state’)| float(0) %}
this.attributes.previous_state and it will already be a float.
You can add filters to entity selectors.
Ah, I see. Going by the Warning in the Templating - Home Assistant sensor section It is strongly advised to use the states(), is_state(), state_attr() and is_state_attr() as much as possible, …. Is that kind of obsolete these days?
EDIT: The construct like it is, protects from the warning has no attribute 'previous_state' showing in the log file at very first run of a newly added template sensor. The attribute this.attributes.previous_state only exists after first execution.
Thanks for that pointer. Think that would make it:
    uptime:
      name: Home Assistant uptime
      description: Specify an Uptime integration sensor to use for HA startup detection
      selector:
        entity:
          domain: sensor
hi nice code, the Problem for enphase is that the value from the sensor are not always really good… :confused:
From time to time, when consumption changes rapidly,we can observe negative and positive spikes.
Enphase Envoy Battery reporting - #26 by Esmax555
You would not use this for power entity like in your link, but for energy entities.
Hello ! Is there any reason to build your own uptime sensor vs the native integration?
Any uptime sensor that provides seconds since start will work. The blueprint triggers 10 seconds (configurable) after HA start and needs an integer value, not a data-time object as was mention in one of the replies.
The sensor itself is build with the native uptime integration, if that is what you are asking?
Ok I think I got what you said. The fact that the description of the uptime input is asking for an instance of the uptime integration, which is unique, confused me.
I see what you mean, the wording does not represent what actually is going on.
Would this be more clear for description:
This blueprint requires the time in seconds since home assistant started running. This can be calculated by configuring the Uptime integration in Home Assistant and using a template sensor. This uptime sensor is used to detect Home Assistant restarts and must be specified as input.
And for:
uptime
Specify an a template sensor providing time in seconds since HA start.
Required input.
