[03:26:13][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:14][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:15][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:16][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:17][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:18][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:19][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:20][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:21][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:22][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:23][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:24][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:25][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:26][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:27][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:28][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:29][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:30][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:31][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:32][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:33][D][sensor:093]: 'Mains Voltage': Sending state 2.00000 V with 0 decimals of accuracy
[03:26:34][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:35][D][sensor:093]: 'Mains Voltage': Sending state 3.00000 V with 0 decimals of accuracy
[03:26:36][D][sensor:093]: 'Mains Voltage': Sending state 1.00000 V with 0 decimals of accuracy
the next step would be to understand how to connect all this to ADS1115. To measure on three vases using Wemos d1
I also found an article, maybe using this example it will be possible to achieve greater accuracy (but this is if it is not possible to achieve a positive result here) : ESP32 + ESPHome Open Source Energy Monitor
but to be honest I experimented a week ago, the ideal option is a transformer, a diode bridge and a divider on resistors with a small capacitor and INA226 , I managed to achieve an accuracy of ±0.3 V, I took the transformer from some old power supply, but the downside is the dimensions ((
If you look at both code files, you will see that they are both doing essentially the same thing (calculating the RMS voltage) in pretty much the identical way.
Have you tried the Arduino example with your hardware and gotten better results?
Did you follow the instructions to adjust the trimpot?
Note that the ADC in a standard Arduino is generally an order of magnitude better than the one in the esp32. This page has some good data on how to make it better: ESP32 Analog To Digital Conversion Accuracy - IoT Kits
Those techniques would work if you were measuring DC voltages, since they clearly say you need to do averaging to get good results. Doing averaging of a varying input will likely give you worse results.
You haven’t really stated what you are trying to do. If you just want to know there is voltage there, this will work. If you want to measure energy and or get an accurate (how accurate?) measurent you really should use something else.
It has the same issue of the esp32 ADC really isn’t that good, so you have to do a lot of work to get something reasonable out of it. It is likely good enough for many scenarios.
@neel-m linked my post, if you look at my code in there (I put it on github now) you will see I take 1 minute’s worth of sample average with ESPhome. For my purpose I am trying to determine if Washer/Dryer are on. Since they go through cycles (motors/pumps/heaters) the reading will jump up/down, so need to smooth it out and take an average.
Here is a snippet:
update_interval: 7s
filters:
- sliding_window_moving_average:
window_size: 9 #keep roughly 1 min average
send_every: 1
If you need smoother more rapid changes you can lower the average to last 3, update more often. Or switch to exponential_moving_average which can give more weight to more recent values, only using older ones to smooth out the curve.
From my experience using ESP32 Wroom board, it has enough precision to be within 0.1A accurate of real readings. It gets less accurate closer you get to 0. So unless you are working with pulling 0.1A or less, it should be accurate enough. Otherwise you may need an ADS1115 which has much higher precision (its an addon board you can use with your ESP32).
Thank you for the clarifications, I read your post too. I will experiment with current transformers, but a little later, but I will use separate coils and maybe I will also try ZMCT103C. But a week earlier (I mentioned this a little higher here) I made what seemed to me a very accurate voltmeter, and the essence of this article lies precisely in the pairing of esp and ZMPT101B.
And earlier, a successful experiment consisted of such a simple solution: 1) transformer (220/12 V), 2) diode bridge, 3) capacitor, 4) resistive divider, 5) INA226 (simply because it is the best). As a result, the accuracy is ± 0.3 V. In theory, this is the same as yours … only voltage and not current)))
And here is part of the code:
As a result, I need to make a device for precise measurements on three phases and in a DIN rail housing, in an electrical panel, to implement various possibilities in the future, for example, if in the summer the mains voltage drops significantly, turn off the inverter split system until the mains voltage is normalized (as one of the options), or notify about this in the audio speaker, and then decide for yourself what to do with this information
I have several ZMPT101B, and I had an idea: maybe try to remake one of them, namely: use an isolating transformer and unsolder the operational amplifier with the strapping, and assemble a step-down divider instead, then also rectify the voltage, put in an SMD capacitor and connect to the ADS1115 (why ADS1115 x2 - I need to read voltage from three phases and current from three phases with one wemos, that is, I need 6 inputs)
I have seen these solutions and there is support for tuya, here the question is to solve this so-called problem. And if my buy ready-made solutions at the first difficulties, then why do you need ESP.
Unless you have orders of magnitude more time than money, I would suggest one of the choices I listed above. They are the Easy Button where very knowledgeable people have done the work to figure out to do the job well and made it easy to follow. I have 2 IotaWatts and they work great. For about a decade I had a pack of power measurement ICs in a drawer that I was going to use to measure energy. I still have them, but it will still be a lot of work to get them to a point where they will be usable.
If your goal is learning, go read the open energy monitor site. They also have a forum with people that know all about measuring power. I know enough to say you are choosing a very difficult path with low chance of success for your main goal, but might provide lots of opportunities for learning (and bashing your head against the wall, when things don’t make sense).
This part of the question can be said to be completely closed. I found two solutions:
A separate transformer ZMPT101B. You can achieve accurate readings in the range of 150-260 V. You need to very carefully select components such as a current-limiting resistor, diodes in the rectifier, a bipolar capacitor and a smoothing capacitor with load resistors. And make sure that the transformer does not go into saturation. And the accuracy is ±0.4 V.
A more obvious solution for obtaining relatively accurate values with a small delay (acceptable if you do not need to catch voltage drops from starting currents). Accuracy ± 1.5 V
Code:
Apologies for hijacking the thread, but since the latest ESPHome update, you can not use the custom platform any more
The "custom" component has been removed. Consider conversion to an external component.
https://esphome.io/guides/contributing#a-note-about-custom-components.
So none of this works any more, and unfortunately I have zero clue as to where it is now supposed to go or the format
I did give it an attempt on ChatGPT, but eventually it was just sending me around in circles, so this node has missed a Good couple of udates due to this.
Is there anyone that can guide me through the process of how this needs to be correctly amended in ESPHome?
I’m new to Home Assistant and I’m trying to use the ZMPT101B voltage sensor with my setup. However, I’m not sure how to integrate it properly.
Could anyone provide guidance or share the necessary steps, configurations, or code to get the ZMPT101B working with Home Assistant? Any help or resources would be greatly appreciated!
