First time install Raspberry Pi 4
This is my first time installing home assistant. I performed a fresh install of home assistant using Raspberry Pi Imager.
My hardware is a Raspberry Pi 4 with a 32 GB SD card.
After home assistant boots up I continually get this error. Full logs are below.
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
I have been digging through the community posts and haven’t found a resolution yet.
I’m guessing this is some type of DNS issue but I’m not sure what?
I have checked the DNS of my router and it is set to 8.8.8.8.
I tried setting the DNS via Home Assistant command line interface with the command
dns options --servers dns://8.8.8.8
and that didn’t fix the issue either.
On my PC if I try to access https://ghcr.io/home-assistant/ I get a 404 page not found.
On my PC if I try to access the URL listed in the error
https://ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.11.3
its gets redirected to
https://github.com/home-assistant/core/pkgs/container/raspberrypi4-64-homeassistant
Any help you can provide on this would be greatly appreciated.
Full log is below.
Home Assistant logo
Error installing Home Assistant
An error occured while installing Home Assistant, check the logs below for more information.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
[__main__] Initializing Supervisor setup
[supervisor.docker.network] Can't find Supervisor network, creating a new network
[supervisor.bootstrap] Setting up coresys for machine: raspberrypi4-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.10.2
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.09.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.09.0 - 172.30.32.5
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.04.0 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi4-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant found.
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Using preinstalled landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 13.2 / BootSlot A
[supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
[supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
[supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
[supervisor.store.git] Cloning add-on https://github.com/music-assistant/home-assistant-addon repository
[supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
[supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
[supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
[supervisor.supervisor] Update Supervisor to version 2024.11.4
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2024.11.4.
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.11.4: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.4&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/aarch64-hassio-supervisor/manifests/2024.11.4": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Faarch64-hassio-supervisor%3Apull&service=ghcr.io": context deadline exceeded")
[supervisor.resolution.module] Create new issue update_failed - supervisor / None
[supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.11.4: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.4&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/aarch64-hassio-supervisor/manifests/2024.11.4": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Faarch64-hassio-supervisor%3Apull&service=ghcr.io": context deadline exceeded")
[supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.11.3
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2024.11.3.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
[supervisor.host.manager] Host information reload completed
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded (Client.Timeout exceeded while awaiting headers)")
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi4-64-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
Do you have anything else on your network that could be blocking access to github?
Pi-hole, Adguard, etc…?
No. I have a default configuration on my router. I can access github from all of my other computers on the network without any issue.
I was able to get this working with some help from this post.
First I had to get home assistant to work with my TV by editing config.txt had to set values for my configuration.
hdmi_group=2
hdmi_mode=16
Then on the command line I had to run the following commands.
login which it appears takes you to the underlying operating system command shell.
Then I had to enter nmcli con edit “Supervisor end0”
Then print ivp4
I noticed there were no ip addresses listed for ipv4.dns.
I then entered remove ipv4.dns
Then I entered set ipv4.dns 8.8.8.8.
Then print ipv4 again to verify the DNS ip address was set.
Then enter save
Finally enter quit. Quit takes you back to the Home Assistant (HA) command line interface (CLI)
From the HA CLI I entered host restart to restart the device.
Everything started working after that.
I don’t know exactly what “Supervisor end0” is exactly. I’m guessing its a configuration file for either the docker container or the supervisor itself and those tools appear to have a separate DNS configuration? I’m not sure but the commands above got me started.
Thank you a lot for this solution.
However the network connection (end0 in your case) may not be correct depending on what host you are using and maybe you could include the steps necessary to check it.
  1. log into the host by typing “login” at the Ha> prompt
  2. query the current connections “nmcli connection”. In my case, I got “Supervisor enp1s0” so I used enp1s0 instead of end0 in your script above
  3. continue from “nmvli con exit [...]”
Thank you for this solution, it also worked for me. Spent 2 days banging my head, searching the posts, and researching router, dns and ip configs, etc. then found this fix. I have 21 tabs open on my browser with different solutions. Tried this one and it immediately worked. Finally got the “Create my smart home “ button! Thanks again to the wizards out there.
