I’m not so good with templates… I submitted a topic request: link
We nee dto wait
We nee dto wait
Ok! I solved it in this way:
vacuum_clean_zone:
alias: Pulisci zona
sequence:
- service: vacuum.send_command
data_template:
command: "{{command}}"
entity_id: "{{entity_id}}"
params:
act: start
content: >
{%- set x = "" %}
{% if is_state('input_boolean.clean_kitchen_boolean', 'on') %}
{% set x = x + "0," %}
{% endif %}
{% if is_state('input_boolean.clean_living_boolean', 'on') %}
{% set x = x + "2," %}
{% endif %}
{% if is_state('input_boolean.clean_lunch_boolean', 'on') %}
{% set x = x + "10," %}
{% endif %}
{% if is_state('input_boolean.clean_disimpegno_boolean', 'on') %}
{% set x = x + "3," %}
{% endif %}
{% if is_state('input_boolean.clean_little_bathroom_boolean', 'on') %}
{% set x = x + "5," %}
{% endif %}
{% if is_state('input_boolean.clean_bathroom_boolean', 'on') %}
{% set x = x + "4," %}
{% endif %}
{% if is_state('input_boolean.clean_bedroom_boolean', 'on') %}
{% set x = x + "6," %}
{% endif %}
{% if is_state('input_boolean.clean_little_bedroom_boolean', 'on') %}
{% set x = x + "9," %}
{% endif %}
{{x[:-1]}}
count: "{{count}}"
type: "{{type}}"
- service: input_boolean.turn_off
entity_id: input_boolean.clean_kitchen_boolean
entity_id: input_boolean.clean_living_boolean
entity_id: input_boolean.clean_lunch_boolean
entity_id: input_boolean.clean_disimpegno_boolean
entity_id: input_boolean.clean_little_bathroom_boolean
entity_id: input_boolean.clean_bathroom_boolean
entity_id: input_boolean.clean_bedroom_boolean
entity_id: input_boolean.clean_little_bedroom_boolean
UI:
cards:
- color: auto
entity: null
icon: 'mdi:map-marker-radius'
styles:
card:
- font-size: 12px
tap_action:
action: call-service
service: vacuum.locate
service_data:
entity_id: vacuum.robi
type: 'custom:button-card'
- type: entity-button
icon: 'mdi:robot-vacuum-variant'
tap_action:
service: script.vacuum_clean_zone
service_data:
command: clean
count: 1
type: spotArea
- color: auto
entity: null
icon: 'mdi:robot-vacuum'
styles:
card:
- font-size: 12px
tap_action:
service: vacuum.return_to_base
service_data:
type: horizontal-stack
Firstly I select the rooms and the “Pulisci” button.
Thanks!!! I will try it…
Why do you repeat this for each room?
` - service: input_boolean.turn_off
data:`
It works now!!! Even if I don’t understand the use of input_boolean.turn_off…
I was also able to change the color of the fan/water level to indicate the selected one
- type: 'custom:config-template-card'
entities:
- sensor.deebot_water_level
variables:
- states['sensor.deebot_water_level'].state
card:
color: "${vars[0] === 'ultrahigh' ? 'yellow' : 'white'}"
entity: null
icon: 'mdi:flask-empty-plus'
styles:
card:
- font-size: 12px
- background-color: black
- color: white
tap_action:
service_data:
command: set_water
entity_id: vacuum.aspirapolvere
params:
amount: ultrahigh
My last two problems and I can consider this integration completed
Because I prefer to reset the status of all inputs after the cleeaning
For the number of cleanings you should just pass the number dynamically from the script using a spicific input to read that… for instance an input_select
Hello. is it possible to have a detailed guide do i have files to set up for your identities? I also have a 950
I fixed your script. The parameters name were wrong. I added a debug line in the code vacuum.py to check the parameters passed. Now cleanings/rooms should be ok (my error was that I inverted them
silly one…). Your error was about the name of parameters (not count/content, but they must be rooms/cleanings).
Please check if it works with 2 times cleaning… I didn’t have time for it. I saw that rooms are passed properly if I call the service from HA and then open the app (but in the app there’s no way to check the number of times it should clean…)
vacuum_clean_zone:
alias: Pulisci zona
sequence:
data_template:
command: spot_area
params:
rooms: >-
{%- set x = "" %}
{% if is_state('input_boolean.deebot_cucina', 'on') %}
{% set x = x + "1," %}
{% endif %}
{% if is_state('input_boolean.deebot_sala', 'on') %}
{% endif %}
{% if is_state('input_boolean.deebot_camera', 'on') %}
{% endif %}
{% if is_state('input_boolean.deebot_bagno_grande','on') %}
{% endif %}
{% if is_state('input_boolean.deebot_bagno_piccolo','on') %}
{% set x = x + "8," %}
{% endif %}
{% if is_state('input_boolean.deebot_corridoio', 'on') %}
{% endif %}
{% if is_state('input_boolean.deebot_aurora', 'on') %}
{% set x = x + "7," %}
{% endif %}
{% if is_state('input_boolean.deebot_giovanni', 'on') %}
{% endif %}
{{x[:-1]}}
cleanings: >-
{%- if is_state('input_boolean.deebot_times', 'on') -%}2{%- else
-%}1{%- endif -%}
entity_id: input_boolean.deebot_cucina
entity_id: input_boolean.deebot_sala
entity_id: input_boolean.deebot_camera
entity_id: input_boolean.deebot_bagno_grande
entity_id: input_boolean.deebot_bagno_piccolo
entity_id: input_boolean.deebot_corridoio
entity_id: input_boolean.deebot_aurora
entity_id: input_boolean.deebot_giovanni
entity_id: input_boolean.deebot_times
It’s not my mistake … the integration comes with that configuration and it works properly for me.
+1
Can someone please share a more detail step by step guide in using the custom component ?
Thanks.
This is the code snippet inside the custom component
if command == 'spot_area':
return self.device.SpotArea(params['rooms'], params['cleanings'])
So rooms and cleanings are the parameters he expects
I dunno why with content and count it works, but the number of cleanings was not working for me before
I wanted to inform that I installed “And3rsL / Deebot-for-hassio” via HACS and that it also works correctly with Deebot 960, thanks @Andrea_Liosi
I was able to configure everything, including zone cleaning.
At the moment, just for my ignorance, I’ve problem to load the map (last_clean_image) of the last cleaning in the right way into frontend.
I tried to make a simple image card and pass them the last_clean_image attribute or the sensor created specifically
platform: template
sensors:
vacuum_last_clean_image:
friendly_name: "Vacuum Last Clean Image"
value_template: "{{ state_attr('vacuum.robi', 'last_clean_image') }}"
entity_picture_template: "{{ state_attr('vacuum.robi', 'last_clean_image') }}"
but it probably doesn’t work because image/picture card doesn’t take the templates as URL or I don’t know the right solution.
The only way I managed to load the image (last_clean_image) was to create a camera in configuration.yaml and then create an image entity as a card.
Can anyone tell me a simpler and less invasive way to load the last_clean_image map?
Thanks.
- card:
entity: sensor.deebot_last_clean_image
image: '${states[''sensor.deebot_last_clean_image''].state}'
type: 'custom:hui-image-element'
entities:
- sensor.deebot_last_clean_image
style:
height: 5%
left: 35%
top: 45%
transform: 'translate(0%,2%)'
width: 5%
sensors:
deebot_last_clean_image:
friendly_name: "Immagine Ultima Pulizia"
unit_of_measurement: ''
value_template: "{{ state_attr('vacuum.aspirapolvere', 'last_clean_image') }}"
I lost hours and hours of testing instead I just had to write here to get the solution. Thanks a lot @StefanoGiu
Do you know if there is a way to also have the map in real time while the vacuum is cleaning?
A map where you can see the vacuum that moves through all the rooms. To understand the map in real time as seen on the official Ecovacs mobile application. Thanks.
It doesn’t come out from the plugin data. You can ask the developer on GitHub to add this feature.
Nice to know is working in the 960 too! i will add it in the custom component description
Sorry but for now there is no support for live map
Yes, work very well on Deebot Ozmo 960, thanks for your work @Andrea_Liosi and hope you can add live map feature in the future.
I only encountered a problem, probably also happens on the 950, if the command is spot_area the cleanings = 2 does not work then it does not perform 2 cleaning passes instead if the command is custom_area and I pass the coordinates of an area the cleanings = 2 works.
Cleanings should work now
I found that customizing the map, merge and split area, in the official ecovacs home app and the option of choosing 2 cleaning cycles for area cleaning is only possible with the 920/950 model, with the 930/960 models It is not possible.
So the cleanings = 2 parameter with a spot_area command does not work on 930/960 models but only on 920/950 models.
On the 930/960 model the cleanings = 2 parameter is allowed only if the custom_area command with the relative coordinates is used.
I confirm that what I said is true and has been tested by me on the 960 model.
If the problem is also confirmed on the 930, as they have said by ecovacs customer service, only owners of the 930 model can confirm it.
