Logger: sucks
Source: /usr/local/lib/python3.8/site-packages/sucks/__init__.py:371
First occurred: 19:12:31 (8 occurrences)
Last logged: 19:16:01
Ping did not reach VacBot. Will retry.
I put the deboot directory in custom_components as written by @ fishgrind and updated my configuration.yaml with
country: mx
continent: eu
Curiosly, I read that for *mx*, the continent should be *eu*
I tried too with mx and na
The latest HA Core update (2021.06) has broken this somehow. I tried adding a version to the manifest.json file (required on all integrations now), but that didn’t work.
Hey everyone. Thanks for the plugin - I’ve got it working with the T8 AIVI and bumper running on the network. It’s awesome. I’ve even managed to get custom area clean using a script that injects the area number into the spot_area command. However, I’ve been searching for something more. Wonder if anyone can help?
The basic idea is that I’ve created 4 input_booleans that represent each zone I’d like to clean. Each of those are assigned to a button in the UI, which can be set to ‘on’ or ‘off’. With the help of Discord, I’ve made a script that triggers a clean, but weirdly, the vacuum moves about 1m away from the dock and goes nowhere.
I wonder, do you know what kind of params the spot_area command expects?
I had the same issue with my Deebot 901/900 (non-ozmo). Turns out there’s a new-ish requirement for custom components in Home Assistant to have a version tag in the manifest.json file. Make sure you have the latest version of files from Ligio’s Github. Add them to the config > custom_components > deebot folder, replacing what you already have there. Then remove the deebot entry from your configuration.yaml and restart HA. Add the deebot entry back to configuration.yaml then run the check config process agian. You shouldn’t have errors anymore and once you restart again you should be good to go!
Hello I’m having trouble with displaying sensor values on this custom card. I’ve installed this component via HACS and have enabled all the sensors of the vacuum. When I open the developer tools I see that they have values
hi, good afternoon.
I’m pretty new to Home Assistant, and home automation in general.
I have got a deebot t8 integrated and running fine, everything works.
I have the live map all the sensors appear to work.
everything works except for maybe two things.
i cant seem to get a camera feed on home assistant
its not creating the livemappath file at config /www/’
This might be misunderstanding on my part, but I am under the assumption that we can stream a camera feed to homeassistant.
also can someone explain to me the difference between:
(in lovelace) ------------ Deebot_live_map &
(in config.yaml) -------- deebot_liveMap
I get two error logs:
–Logger: homeassistant.components.generic.camera
Source: components/generic/camera.py:155
Integration: generic (documentation, issues)
First occurred: 12:41:25 PM (1 occurrences)
Last logged: 12:41:25 PM
Error getting new camera image from Deebot_live_map: [SSL:
WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1129)
–Logger: homeassistant.helpers.template
Source: helpers/template.py:1210
First occurred: 12:12:00 PM (4 occurrences)
Last logged: 12:12:00 PM
Template warning: ‘as_timestamp’ got invalid input ‘unavailable’ when rendering
template ‘{{sensor == ‘none’ or as_timestamp(states(sensor)) != None}}’ but no
default was specified. Currently ‘as_timestamp’ will return ‘None’, however this
template will fail to render in Home Assistant core 2021.12
That last log, I think is unrelated.
Thanks in advance for any help.
Hi, you can show the map in homeassistant. I dont have a specific camera setup in my config.yaml. I use a simple picture-entity card and use the sensor from the vacuum:
Or you can add it through the lovelace ui. If you want to add the live map beneath the vacuum status etc, you can create a vertical stack card with. I use the 950 Ozmo
Hello guys!
I just wanted to share how I was able to integrate my DEEBOT 900 to Home Assistant on Nov. 21.
At first I tried of course the official Ecovacs Integration. I followed their instruction and i was able to add my Deebot to Home Assistant, but i couldnt connect to it neither controll it. I just got errors.
Next I tried this Deebot Integration “GitHub - And3rsL/Deebot-for-Home-Assistant: Vacuum component for Ecovacs Deebot Vacuums”. So i followed the instruction as well, my Deebot was added to HA, but i couldnt connect to it - this time even without an error message.
So next i tried the Integration from Ligio: GitHub - Ligio/hacc-ozmo: Home Assistant Custom Component for Ecovacs Deebot Ozmo 900 But it wasnt working - i couldnt even see the entity.
I tried several things like other configs, other init_.py files, etc…
But in the forums everyone was saying that Ligio’s Integration was working fine for them.
So last try: I deinstalled the Deebot Integration from And3rsL in Hacs, I deleted the Deebot and Ecovacs entries from the config Files and I deleted the Deebot folder in custom components.
I even deleted the whole vaccuum entity.
Next I just installed Ligios’s Integration, restared HA and IT WAS FINALLY WORKING.
So you just have the hacc-ozmo Integration to be installed and nothing else otherwise it isnt working.
Important:
Your deebot entry in the config file needs to look like this if you want to have all the features:
Maybe someone has some insight to the problem I am having. I have gotten my Ozmo 930 installed and can control it via Homeassistant. The issue that I am having is that if I instruct it to start cleaning, the status changes to cleaning. If I instruct it to return to dock, it will and the status will briefly change, but then it always goes back to cleaning status. I am using Ligio’s addon as it is the only one which seems to work for me.
