The server is running as follows:
Available HCI devices found:
hci0
Trying hci0
hci0 is busy, shutting down and retrying…
Successfully bound HCI socket
Flic server is now up and running!
Initialization of Bluetooth controller done!
Accepted new client
But i cannot add any Flic button though am pressing the flic for 7 seconds.
tried pairing it with android app and it is working great.
So i assume its home assistant issue.
Please advise ? Anyone successfully paired Flic2 to HASSIO ?
Not an answer to your query but an alternative - Have you tried using the usual bluetooth buttons - like the ones below? They can be connected through Keyboard Remote integration of HA and are pretty reliable also super cheap. If you search you could get 3 of these in $9. IMHO flic is just an overpriced and complicated bluetooth solution
While others with Flic respond, you might want to try adding them as a Keyboard Remote. If Flic behaves like a regular bluetooth, it would work. Then you wouldn’t need the Flic server.
So, just to get this straight.
You have bought a flic hub? (Bluetooth to ethernet)
You have several Bluetooth buttons?
You have paired these buttons with your phone?
I only have original flics, but have some suggestions
make sure you have un-paired flics from any phone app - they can only have one server at a time (at least my ver 1 ones were like that) - at least have the flic app closed on your phone
once the service is up and running on your hassio system, you might need to restart hass.
once flic is up and hass has restarted, then you can add the buttons using the 7 second press - they should stop flashing when you do a normal press after associating, indicating they are linked with the hassio service.
Any lights at all on the button when pressed? I assume you get 3 or 4 flashes when you press indicating not assigned to anything, or cant find the server it is liked to.
I find the batteries can go flat quite quickly
I also use a pi as a hub, like your usecase.
The binary sensors for flic buttons don’t actually show anything apart from whether the button is “online”
I’m experiencing the exact same issue. Not getting any entities when trying to pair Flic2 buttons.
RPI4 (or 3B+ for that matter)
Flic 2 buttons (never paired with other devices)
Flicd add-on installed
Flicd log:
hci0
Trying hci0
Accepted new client
@Emill this actually works on Linux systems with home assistant installed on. We are looking for HASSIO addon, if you can update us with an ADDON that would be great.
I am also using pschmitt’s addon, and I’m also unable to pair my flics in Home Assistant (previously Hass.io). Every flic owner in the Danish Home Assistant community is having the same issue.
Same here. Freshly install fliclib but only Flic Gen 1 discovered. Flic 2 didn’t show up.
Have someone been successful with Flic2? Please kindly share.
