but got this error when I checked the configration
Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See /config/configuration.yaml, line 194).
which is strange bcz this code start at line 256 .
Decided to do something a bit different using Node Red and had a lot of inspiration from this thread. If anyone here is a NR user and wants a plug + play way to get planes overhead data from their FR24 setup, I posted about it here.
Thanks for this scraper, is there anyway we can grab the distance from the plane that’s the furthest from my station… this is becoming a game with antenna battles ! lol and personally would love to just track the distance
That information you use to display the sensors does not contain details about individual flights tracked.
To get the distance you would need to look at every single tracked flight’s lat/lon values, calculate the distance to your current location and then find the maximum. The data is available from http://<hostname>:8754/flights.json - the JSON returned is an array and each entry of the array represents a flight. The second value is latitude, the third value is longitude. You could iterate over that array, extract lat/lon and use the distance function.
awesome, thanks for the insight “xadea8d”:[“ADEA8D”,42.3572,-82.9719,336,10075,287,“7024”,0,"","",1638138769,"","","",0,0,“N996SR”] so now i just have to figure out the other side of that now… thanks ! wish someone had a blueprint of this …anyone ?
OK, I see. If that’s an important feature, then I believe there is currently no integration that can do that for you.
As mentioned this Flightradar24 integration is just using the data that a local installation has and that is really just whatever the airplane itself transmits via ADS-B, and does not include departure or arrival times.
Hi…
Just installed this add on and trying to connect it to my rpi running pi24 (Flight Radar 24 rpi image).
However, having a hard time to read from my pi to my HA addon.
The rpi24 is running and tracking is good…
What values do I have to change in order to let the add-on read from the rpi?
