I am having the following Flip Flop switch random behavior on a dual switch (Fantem brand, the same manufacturer of Aeotec)
Also notice in the video that the 2nd time I click the Light Switch 2 it turns off both lights and should only turn off the roof one.
When doing the same actions through the physical switch everything works fine (ie: the UI doesn’t flip and in the next polling it gets updated)
I already tried refresh_value: true and delay: 3 as suggested in other posts in the zwave configuration section (although those posts were for zwave).
Here https://www.hastebin.com/ikirawezeg.sql is the the zwave log in case it gives some clues.
And here you can find my zcfg configuration entry: https://www.hastebin.com/tetibeqene.xml
I am really lost with this.
Any help, really appreciated.
Thanks,
Claudio.
