@freshcoast again, thanks for the reply and help. Hopefully my experience/logs below will help what you are debugging on your own network.
Those are definitely the correct logs. What you said got me to pay closer attention while I went to physically toggle the switch. This is what I experienced (and logs)
- Light is off (or at least looks off)
- Hit “on” on the switch - nothing happened
- Hit “on” again - nothing happened
- I realize it may just be dimmed all the way, so I hold the “on” and it “snapped” on to full brightness. What I mean is that there was no slow stepping that normally happens when controlled locally. Also confirmed after that it is definitely slow stepping locally, so not sure how it could have snapped to full brightness.
- Hit “off” - light turns off
- Hit “on” - light turns on
So the odd part is how it could have been “on” but just dimmed all the way. The way I got it into that state was by just hitting the on/off toggle in the lovelace UI, never touched the brightness setting. You can even see in the log and the screenshot that HA thought the brightness was at 99, which it should have been.
OZW_Log.txt:
2019-05-31 18:28:40.815 Detail, Node006, Received: 0x01, 0x17, 0x00, 0x49, 0x84, 0x06, 0x11, 0x04, 0x11, 0x01, 0x5e, 0x56, 0x86, 0x72, 0x5a, 0x85, 0x59, 0x73, 0x26, 0x27, 0x70, 0x2c, 0x2b, 0x7a, 0x23
2019-05-31 18:28:40.816 Detail,
2019-05-31 18:28:40.816 Info, Node006, UPDATE_STATE_NODE_INFO_RECEIVED from node 6
2019-05-31 18:28:40.816 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2019-05-31 18:28:40.816 Detail, Node006, QueryStage_Dynamic
2019-05-31 18:28:40.816 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x90, 0x70
2019-05-31 18:28:40.816 Detail, Node006, Queuing (Query) Query Stage Complete (Dynamic)
2019-05-31 18:28:40.816 Info, Node006, Sending (Send) message (Callback ID=0x90, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x90, 0x70
2019-05-31 18:28:40.825 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:28:40.825 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:28:40.833 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:40.834 Detail,
2019-05-31 18:28:40.834 Info, Node006, Response RTT 17 Average Response RTT 31
2019-05-31 18:28:40.834 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:40.834 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:40.834 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:40.834 Detail, Node006, Notification: ValueChanged
2019-05-31 18:28:40.851 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x90, 0x00, 0x00, 0x03, 0x78
2019-05-31 18:28:40.851 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x90 received (expected 0x90)
2019-05-31 18:28:40.851 Info, Node006, Request RTT 34 Average Request RTT 36
2019-05-31 18:28:40.852 Detail, Expected callbackId was received
2019-05-31 18:28:40.862 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:40.862 Info, Node006, Response RTT 45 Average Response RTT 38
2019-05-31 18:28:40.862 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:40.862 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:40.862 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:40.862 Detail, Node006, Expected reply and command class was received
2019-05-31 18:28:40.862 Detail, Node006, Message transaction complete
2019-05-31 18:28:40.862 Detail, Node006, Removing current message
2019-05-31 18:28:40.863 Detail, Node006, Notification: ValueChanged
2019-05-31 18:28:40.878 Detail, Node006, Query Stage Complete (Dynamic)
2019-05-31 18:28:40.878 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2019-05-31 18:28:40.878 Detail, Node006, QueryStage_Configuration
2019-05-31 18:28:40.879 Detail, Node006, QueryStage_Complete
2019-05-31 18:28:40.879 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2019-05-31 18:28:40.879 Detail, Node006, Notification: NodeQueriesComplete
2019-05-31 18:28:45.717 Detail, Node006, Received: 0x01, 0x17, 0x00, 0x49, 0x84, 0x06, 0x11, 0x04, 0x11, 0x01, 0x5e, 0x56, 0x86, 0x72, 0x5a, 0x85, 0x59, 0x73, 0x26, 0x27, 0x70, 0x2c, 0x2b, 0x7a, 0x23
2019-05-31 18:28:45.718 Detail,
2019-05-31 18:28:45.718 Info, Node006, UPDATE_STATE_NODE_INFO_RECEIVED from node 6
2019-05-31 18:28:45.718 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2019-05-31 18:28:45.718 Detail, Node006, QueryStage_Dynamic
2019-05-31 18:28:45.718 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x91, 0x71
2019-05-31 18:28:45.718 Detail, Node006, Queuing (Query) Query Stage Complete (Dynamic)
2019-05-31 18:28:45.719 Info, Node006, Sending (Send) message (Callback ID=0x91, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x91, 0x71
2019-05-31 18:28:45.728 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:28:45.728 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:28:45.735 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:45.736 Detail,
2019-05-31 18:28:45.736 Info, Node006, Response RTT 16 Average Response RTT 27
2019-05-31 18:28:45.736 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:45.736 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:45.736 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:45.736 Detail, Node006, Notification: ValueChanged
2019-05-31 18:28:45.753 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x91, 0x00, 0x00, 0x03, 0x79
2019-05-31 18:28:45.753 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x91 received (expected 0x91)
2019-05-31 18:28:45.753 Info, Node006, Request RTT 34 Average Request RTT 35
2019-05-31 18:28:45.753 Detail, Expected callbackId was received
2019-05-31 18:28:45.765 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:45.765 Info, Node006, Response RTT 46 Average Response RTT 36
2019-05-31 18:28:45.765 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:45.765 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:45.765 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:45.765 Detail, Node006, Expected reply and command class was received
2019-05-31 18:28:45.765 Detail, Node006, Message transaction complete
2019-05-31 18:28:45.765 Detail, Node006, Removing current message
2019-05-31 18:28:45.766 Detail, Node006, Notification: ValueChanged
2019-05-31 18:28:45.775 Detail, Node006, Query Stage Complete (Dynamic)
2019-05-31 18:28:45.775 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2019-05-31 18:28:45.775 Detail, Node006, QueryStage_Configuration
2019-05-31 18:28:45.775 Detail, Node006, QueryStage_Complete
2019-05-31 18:28:45.775 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2019-05-31 18:28:45.775 Detail, Node006, Notification: NodeQueriesComplete
2019-05-31 18:28:47.978 Detail, Node006, Received: 0x01, 0x17, 0x00, 0x49, 0x84, 0x06, 0x11, 0x04, 0x11, 0x01, 0x5e, 0x56, 0x86, 0x72, 0x5a, 0x85, 0x59, 0x73, 0x26, 0x27, 0x70, 0x2c, 0x2b, 0x7a, 0x23
2019-05-31 18:28:47.978 Info, Node006, UPDATE_STATE_NODE_INFO_RECEIVED from node 6
2019-05-31 18:28:47.978 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2019-05-31 18:28:47.978 Detail, Node006, QueryStage_Dynamic
2019-05-31 18:28:47.978 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x92, 0x72
2019-05-31 18:28:47.978 Detail, Node006, Queuing (Query) Query Stage Complete (Dynamic)
2019-05-31 18:28:47.979 Info, Node006, Sending (Send) message (Callback ID=0x92, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x92, 0x72
2019-05-31 18:28:47.987 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:28:47.987 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:28:47.995 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:47.995 Info, Node006, Response RTT 16 Average Response RTT 26
2019-05-31 18:28:47.995 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:47.995 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:47.995 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:47.995 Detail, Node006, Notification: ValueChanged
2019-05-31 18:28:48.013 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x92, 0x00, 0x00, 0x03, 0x7a
2019-05-31 18:28:48.013 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x92 received (expected 0x92)
2019-05-31 18:28:48.013 Info, Node006, Request RTT 35 Average Request RTT 35
2019-05-31 18:28:48.013 Detail, Expected callbackId was received
2019-05-31 18:28:48.024 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:48.024 Info, Node006, Response RTT 46 Average Response RTT 36
2019-05-31 18:28:48.024 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:48.024 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:48.024 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:48.025 Detail, Node006, Expected reply and command class was received
2019-05-31 18:28:48.025 Detail, Node006, Message transaction complete
2019-05-31 18:28:48.025 Detail, Node006, Removing current message
2019-05-31 18:28:48.025 Detail, Node006, Notification: ValueChanged
2019-05-31 18:28:48.035 Detail, Node006, Query Stage Complete (Dynamic)
2019-05-31 18:28:48.035 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2019-05-31 18:28:48.035 Detail, Node006, QueryStage_Configuration
2019-05-31 18:28:48.035 Detail, Node006, QueryStage_Complete
2019-05-31 18:28:48.035 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2019-05-31 18:28:48.035 Detail, Node006, Notification: NodeQueriesComplete
2019-05-31 18:28:53.034 Info, mgr, Refreshing node 6: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2019-05-31 18:28:53.034 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x93, 0x73
2019-05-31 18:28:53.034 Info, Node006, Sending (Send) message (Callback ID=0x93, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x93, 0x73
2019-05-31 18:28:53.043 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:28:53.043 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:28:53.059 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x93, 0x00, 0x00, 0x02, 0x7a
2019-05-31 18:28:53.059 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x93 received (expected 0x93)
2019-05-31 18:28:53.060 Info, Node006, Request RTT 24 Average Request RTT 29
2019-05-31 18:28:53.060 Detail, Expected callbackId was received
2019-05-31 18:28:53.070 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:53.070 Info, Node006, Response RTT 35 Average Response RTT 35
2019-05-31 18:28:53.070 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:53.070 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:53.070 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:53.070 Detail, Node006, Expected reply and command class was received
2019-05-31 18:28:53.070 Detail, Node006, Message transaction complete
2019-05-31 18:28:53.071 Detail, Node006, Removing current message
2019-05-31 18:28:53.071 Detail, Node006, Notification: ValueChanged
2019-05-31 18:28:53.479 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:53.479 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:53.479 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:53.480 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:53.480 Detail, Node006, Notification: ValueChanged
2019-05-31 18:28:58.489 Info, mgr, Refreshing node 6: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2019-05-31 18:28:58.489 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x94, 0x74
2019-05-31 18:28:58.490 Info, Node006, Sending (Send) message (Callback ID=0x94, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x94, 0x74
2019-05-31 18:28:58.498 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:28:58.498 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:28:58.513 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x94, 0x00, 0x00, 0x02, 0x7d
2019-05-31 18:28:58.514 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x94 received (expected 0x94)
2019-05-31 18:28:58.514 Info, Node006, Request RTT 23 Average Request RTT 26
2019-05-31 18:28:58.514 Detail, Expected callbackId was received
2019-05-31 18:28:58.525 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:28:58.525 Info, Node006, Response RTT 35 Average Response RTT 35
2019-05-31 18:28:58.525 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:28:58.525 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:28:58.526 Detail, Node006, Changes to this value are not verified
2019-05-31 18:28:58.526 Detail, Node006, Expected reply and command class was received
2019-05-31 18:28:58.526 Detail, Node006, Message transaction complete
2019-05-31 18:28:58.526 Detail, Node006, Removing current message
2019-05-31 18:28:58.526 Detail, Node006, Notification: ValueChanged
2019-05-31 18:29:07.926 Detail, Node006, Received: 0x01, 0x17, 0x00, 0x49, 0x84, 0x06, 0x11, 0x04, 0x11, 0x01, 0x5e, 0x56, 0x86, 0x72, 0x5a, 0x85, 0x59, 0x73, 0x26, 0x27, 0x70, 0x2c, 0x2b, 0x7a, 0x23
2019-05-31 18:29:07.927 Detail,
2019-05-31 18:29:07.927 Info, Node006, UPDATE_STATE_NODE_INFO_RECEIVED from node 6
2019-05-31 18:29:07.927 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2019-05-31 18:29:07.927 Detail, Node006, QueryStage_Dynamic
2019-05-31 18:29:07.927 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x95, 0x75
2019-05-31 18:29:07.927 Detail, Node006, Queuing (Query) Query Stage Complete (Dynamic)
2019-05-31 18:29:07.927 Info, Node006, Sending (Send) message (Callback ID=0x95, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x95, 0x75
2019-05-31 18:29:07.936 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:29:07.936 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:29:07.952 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x95, 0x00, 0x00, 0x02, 0x7c
2019-05-31 18:29:07.952 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x95 received (expected 0x95)
2019-05-31 18:29:07.952 Info, Node006, Request RTT 24 Average Request RTT 25
2019-05-31 18:29:07.952 Detail, Expected callbackId was received
2019-05-31 18:29:07.963 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x5d, 0x8f
2019-05-31 18:29:07.964 Detail,
2019-05-31 18:29:07.964 Info, Node006, Response RTT 35 Average Response RTT 35
2019-05-31 18:29:07.964 Info, Node006, Received SwitchMultiLevel report: level=93
2019-05-31 18:29:07.964 Detail, Node006, Refreshed Value: old value=99, new value=93, type=byte
2019-05-31 18:29:07.964 Detail, Node006, Changes to this value are not verified
2019-05-31 18:29:07.964 Detail, Node006, Expected reply and command class was received
2019-05-31 18:29:07.964 Detail, Node006, Message transaction complete
2019-05-31 18:29:07.964 Detail, Node006, Removing current message
2019-05-31 18:29:07.964 Detail, Node006, Notification: ValueChanged
2019-05-31 18:29:07.974 Detail, Node006, Query Stage Complete (Dynamic)
2019-05-31 18:29:07.975 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2019-05-31 18:29:07.975 Detail, Node006, QueryStage_Configuration
2019-05-31 18:29:07.975 Detail, Node006, QueryStage_Complete
2019-05-31 18:29:07.975 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2019-05-31 18:29:07.975 Detail, Node006, Notification: NodeQueriesComplete
2019-05-31 18:29:08.888 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x00, 0xd2
2019-05-31 18:29:08.888 Info, Node006, Received SwitchMultiLevel report: level=0
2019-05-31 18:29:08.888 Detail, Node006, Refreshed Value: old value=93, new value=0, type=byte
2019-05-31 18:29:08.888 Detail, Node006, Changes to this value are not verified
2019-05-31 18:29:08.888 Detail, Node006, Notification: ValueChanged
2019-05-31 18:29:13.904 Info, mgr, Refreshing node 6: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2019-05-31 18:29:13.905 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x96, 0x76
2019-05-31 18:29:13.905 Info, Node006, Sending (Send) message (Callback ID=0x96, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x96, 0x76
2019-05-31 18:29:13.914 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:29:13.914 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:29:13.929 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x96, 0x00, 0x00, 0x02, 0x7f
2019-05-31 18:29:13.929 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x96 received (expected 0x96)
2019-05-31 18:29:13.929 Info, Node006, Request RTT 24 Average Request RTT 24
2019-05-31 18:29:13.929 Detail, Expected callbackId was received
2019-05-31 18:29:13.940 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x00, 0xd2
2019-05-31 18:29:13.941 Detail,
2019-05-31 18:29:13.941 Info, Node006, Response RTT 35 Average Response RTT 35
2019-05-31 18:29:13.941 Info, Node006, Received SwitchMultiLevel report: level=0
2019-05-31 18:29:13.941 Detail, Node006, Refreshed Value: old value=0, new value=0, type=byte
2019-05-31 18:29:13.941 Detail, Node006, Changes to this value are not verified
2019-05-31 18:29:13.941 Detail, Node006, Expected reply and command class was received
2019-05-31 18:29:13.941 Detail, Node006, Message transaction complete
2019-05-31 18:29:13.941 Detail, Node006, Removing current message
2019-05-31 18:29:13.941 Detail, Node006, Notification: ValueChanged
2019-05-31 18:29:15.760 Detail, Node006, Received: 0x01, 0x17, 0x00, 0x49, 0x84, 0x06, 0x11, 0x04, 0x11, 0x01, 0x5e, 0x56, 0x86, 0x72, 0x5a, 0x85, 0x59, 0x73, 0x26, 0x27, 0x70, 0x2c, 0x2b, 0x7a, 0x23
2019-05-31 18:29:15.760 Info, Node006, UPDATE_STATE_NODE_INFO_RECEIVED from node 6
2019-05-31 18:29:15.760 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2019-05-31 18:29:15.760 Detail, Node006, QueryStage_Dynamic
2019-05-31 18:29:15.760 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x97, 0x77
2019-05-31 18:29:15.760 Detail, Node006, Queuing (Query) Query Stage Complete (Dynamic)
2019-05-31 18:29:15.761 Detail,
2019-05-31 18:29:15.761 Info, Node006, Sending (Send) message (Callback ID=0x97, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x97, 0x77
2019-05-31 18:29:15.769 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:29:15.769 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:29:15.785 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x97, 0x00, 0x00, 0x02, 0x7e
2019-05-31 18:29:15.785 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x97 received (expected 0x97)
2019-05-31 18:29:15.785 Info, Node006, Request RTT 24 Average Request RTT 24
2019-05-31 18:29:15.785 Detail, Expected callbackId was received
2019-05-31 18:29:15.796 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x07, 0xd5
2019-05-31 18:29:15.797 Detail,
2019-05-31 18:29:15.797 Info, Node006, Response RTT 35 Average Response RTT 35
2019-05-31 18:29:15.797 Info, Node006, Received SwitchMultiLevel report: level=7
2019-05-31 18:29:15.797 Detail, Node006, Refreshed Value: old value=0, new value=7, type=byte
2019-05-31 18:29:15.797 Detail, Node006, Changes to this value are not verified
2019-05-31 18:29:15.797 Detail, Node006, Expected reply and command class was received
2019-05-31 18:29:15.797 Detail, Node006, Message transaction complete
2019-05-31 18:29:15.797 Detail, Node006, Removing current message
2019-05-31 18:29:15.797 Detail, Node006, Notification: ValueChanged
2019-05-31 18:29:15.807 Detail, Node006, Query Stage Complete (Dynamic)
2019-05-31 18:29:15.807 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2019-05-31 18:29:15.808 Detail, Node006, QueryStage_Configuration
2019-05-31 18:29:15.808 Detail, Node006, QueryStage_Complete
2019-05-31 18:29:15.808 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2019-05-31 18:29:15.808 Detail, Node006, Notification: NodeQueriesComplete
2019-05-31 18:29:16.713 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:29:16.713 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:29:16.713 Detail, Node006, Refreshed Value: old value=7, new value=99, type=byte
2019-05-31 18:29:16.713 Detail, Node006, Changes to this value are not verified
2019-05-31 18:29:16.714 Detail, Node006, Notification: ValueChanged
2019-05-31 18:29:21.724 Info, mgr, Refreshing node 6: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2019-05-31 18:29:21.724 Detail, Node006, Queuing (Send) SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x98, 0x78
2019-05-31 18:29:21.724 Info, Node006, Sending (Send) message (Callback ID=0x98, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x26, 0x02, 0x25, 0x98, 0x78
2019-05-31 18:29:21.733 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-31 18:29:21.733 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-31 18:29:21.749 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x98, 0x00, 0x00, 0x02, 0x71
2019-05-31 18:29:21.750 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x98 received (expected 0x98)
2019-05-31 18:29:21.750 Info, Node006, Request RTT 24 Average Request RTT 24
2019-05-31 18:29:21.750 Detail, Expected callbackId was received
2019-05-31 18:29:21.760 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x26, 0x03, 0x63, 0xb1
2019-05-31 18:29:21.760 Info, Node006, Response RTT 35 Average Response RTT 35
2019-05-31 18:29:21.760 Info, Node006, Received SwitchMultiLevel report: level=99
2019-05-31 18:29:21.760 Detail, Node006, Refreshed Value: old value=99, new value=99, type=byte
2019-05-31 18:29:21.760 Detail, Node006, Changes to this value are not verified
2019-05-31 18:29:21.760 Detail, Node006, Expected reply and command class was received
2019-05-31 18:29:21.760 Detail, Node006, Message transaction complete
2019-05-31 18:29:21.760 Detail, Node006, Removing current message
2019-05-31 18:29:21.761 Detail, Node006, Notification: ValueChanged
