Flux Led/MagicLight don't work since few updated
Hi Team,
I have the same issue with the V8. It works good with my V6 controllers.
In order to solve it I am following your workaround. In my custom_components folder where I have other custom components that work fine, I have created a flux_led folder, I have copied the init.py and light.py files (the modified light.py) but when bootin I can see in the log that other custom components are loading and the flux_led one no. It is still taking the original one, not the custom one. Am I missing something??
I just now started with HA so technically it has never worked for me. I have tried both with and without ledenet.
Here is my configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
frontend:
  themes: !include themes.yaml
#ring:
#  username: !secret ring_username
#  password: !secret ring_password
device_tracker:
   - platform: unifi_direct
     host: 192.168.75.2
     username: !secret unifi_username
     password: !secret unifi_password
     host: 192.168.75.3
tuya:
  username: !secret tuya_username
  password: !secret tuya_password
  country_code: "1"
light:
  - platform: flux_led
    automatic_add: false
    devices:
      192.168.100.40:
        mode: "rgbw"
      192.168.100.41:
        mode: "rgbw"
      192.168.100.42:
        mode: "rgb"
      192.168.100.43:
        mode: "rgb"
      192.168.100.44:
        mode: "rgb"
      192.168.100.45:
        mode: "rgb"
      192.168.100.46:
        mode: "w"
      192.168.100.49:
        mode: "rgb"
Try removing the speech marks, its the only difference I can see between yours and mine.
mode: rgb
To be honest I am just going to flash my MagicHome devices with Tasmota when I get chance, my Smart Life devices perform noticeably better with this firmware. Perhaps it may be the next option for you to consider if you cannot get flux_led to work.
I will probably end up flashing mine too. I have to figure out how to get them open so I can get to the board. I think these are glued together.
I flashed my first MagicHome device this evening, I am really pleased with the performance and it’s good to have Tasmota across the whole setup, just a shame you can’t do the MagicHome stuff OTA. They are pretty easy to open, no glue, just gently pried them open with a small flat screwdriver.
I ended up writing a detailed tutorial on how to flash Tasmota to MagicHome devices using ESPTool and a Raspberry Pi. The same process would work with any ESP device where you can access the TXD, RXD and GND :smiley:
Seems like this is still a problem. I’ve had a v4 controller running fine and able to be controlled as expected for about a year. Bought another one last week, a v8, and it didn’t work. I have to power cycle the controller, then it appears as on in HA. Once on, I can change the color and brightness, but if I turn it off then I lose control. I can try to turn it on again but it only goes to the dimmest red setting, then I can’t turn it off unless I quickly click it like three times. No real control after that, never goes to what I had it set to, only that dim red color after playing with the button. Weird part is if I quickly hit the toggle then it briefly flashes the set color/brightness before turning off. If I power cycle the controller it boots up to what I had it set to initially then, and I can then control the color/brightness again until I turn it off.
I thought it might be just the one controller, so I returned it for a different brand but it’s the same behavior. I do have to try John32’s fix, but I’d love to see a native fix.
Any word on a possible fix from within the component/integration in HA?
I have this same issue, but I have 2 v8 controllers. One works great, every time perfect. The other doesn’t ever turn on. When I try to turn it on or off, I need to go to the magic home app and cycle it 2 times to get the control restored. I’m trying to remove IFTTT from my house, but without this fixed, I can’t.
My goal, remove as many of the internet based items and move towards a self-controlled environment, Home Assistant.
How confident are you with a soldering iron?
I’m pretty good. I came across https://quinled.info/ and had considered doing this with some of the LED strips. Not sure at this point, but was thinking of moving to individual addressable LEDs lights and make one of these controllers.
i have tried your fix, any time i adjust the brightness i get "nonetype object is not subscriptable " as an error.
the brigtness changes, but it keeps popping up, theres also no option to change the RGB colors.
is there anything else you could suggest please?
Just flash your MagicHome controller with the Tasmota firmware, it will work much better than flux_led. You just need to open up the MagicHome controller and solder a couple of wires to the bottom of the board, there are already labelled test points that are very easy to solder to (you don’t have to solder wires to the legs of ICs etc)
You can use Ras Pi or Arduino to flash it if you don’t have a serial programmer. I ended up giving up on flux_led and just flashed all of my devices.
I was able to use @john32’s initial code fix with some more files/instructions to get it to actually load into my HomeAssistant as a custom component, I added a github here for others that may find it useful.
This fix works here as well [FIXED] Flux_led does not set brightness or color correctly when device is initially off
The issue is due to the slight delay that is necessary between turning the light on and reading the brightness as the guy explains; which resolves both issues in this thread and the thread in the link at the same time!
When I use in automations or in UI HA turn on led lights - I have delay, sometimes 5-10 sec. After push light in HA UI or run automation and light turn ON. If I do same in Magic Home app - LED turn ON very fast. Anybody have same problem? How fix it? Please help!
This should resolve your issue [FIXED] Flux_led does not set brightness or color correctly when device is initially off
Hello, I have the same problem. I have created a new custom component inside the custom_components folder and added the @CorneliousJD lux-led folder. When I turn on HA, I see in my log that if my custom component is being loaded, the problem is that I still cannot turn on the led strip from HA. Any other solution? My configuration is as follows:
light:
  • platform: flux_led
    devices:
    192.168.1.41:
    name: Led televisión
    protocol: ā€˜ledenet’
Just wanted to chime in on this - I was only focused on getting my RGB LEDs working - they aren’t ā€œledenetā€ protocol so you may be experiencing issues w/ the custom component I uploaded because of that, sorry :frowning:
I just made some modifications that should resolve all these issues. If you have a single color controller (white only), please set the mode to rgbw. Also, at first it will not work properly as it has to register the old brightness, but once you turn off/on a bulb once or set brightness, you are good to go:
"""Support for Flux lights."""
import logging
import random
# Added for MagicLight hack
import time
from flux_led import BulbScanner, WifiLedBulb
import voluptuous as vol
from homeassistant.components.light import (
    ATTR_BRIGHTNESS,
    ATTR_COLOR_TEMP,
    ATTR_EFFECT,
    ATTR_HS_COLOR,
    ATTR_WHITE_VALUE,
    EFFECT_COLORLOOP,
    EFFECT_RANDOM,
    PLATFORM_SCHEMA,
    SUPPORT_BRIGHTNESS,
    SUPPORT_COLOR,
    SUPPORT_COLOR_TEMP,
    SUPPORT_EFFECT,
    SUPPORT_WHITE_VALUE,
    LightEntity,
from homeassistant.const import ATTR_MODE, CONF_DEVICES, CONF_NAME, CONF_PROTOCOL
import homeassistant.helpers.config_validation as cv
import homeassistant.util.color as color_util
_LOGGER = logging.getLogger(__name__)
CONF_AUTOMATIC_ADD = "automatic_add"
CONF_CUSTOM_EFFECT = "custom_effect"
CONF_COLORS = "colors"
CONF_SPEED_PCT = "speed_pct"
CONF_TRANSITION = "transition"
DOMAIN = "flux_led"
SUPPORT_FLUX_LED = SUPPORT_BRIGHTNESS | SUPPORT_EFFECT | SUPPORT_COLOR
MODE_RGB = "rgb"
MODE_RGBW = "rgbw"
# This mode enables white value to be controlled by brightness.
# RGB value is ignored when this mode is specified.
MODE_WHITE = "w"
# Constant color temp values for 2 flux_led special modes
# Warm-white and Cool-white modes
COLOR_TEMP_WARM_VS_COLD_WHITE_CUT_OFF = 285
# List of supported effects which aren't already declared in LIGHT
EFFECT_RED_FADE = "red_fade"
EFFECT_GREEN_FADE = "green_fade"
EFFECT_BLUE_FADE = "blue_fade"
EFFECT_YELLOW_FADE = "yellow_fade"
EFFECT_CYAN_FADE = "cyan_fade"
EFFECT_PURPLE_FADE = "purple_fade"
EFFECT_WHITE_FADE = "white_fade"
EFFECT_RED_GREEN_CROSS_FADE = "rg_cross_fade"
EFFECT_RED_BLUE_CROSS_FADE = "rb_cross_fade"
EFFECT_GREEN_BLUE_CROSS_FADE = "gb_cross_fade"
EFFECT_COLORSTROBE = "colorstrobe"
EFFECT_RED_STROBE = "red_strobe"
EFFECT_GREEN_STROBE = "green_strobe"
EFFECT_BLUE_STROBE = "blue_strobe"
EFFECT_YELLOW_STROBE = "yellow_strobe"
EFFECT_CYAN_STROBE = "cyan_strobe"
EFFECT_PURPLE_STROBE = "purple_strobe"
EFFECT_WHITE_STROBE = "white_strobe"
EFFECT_COLORJUMP = "colorjump"
EFFECT_CUSTOM = "custom"
EFFECT_MAP = {
    EFFECT_COLORLOOP: 0x25,
    EFFECT_RED_FADE: 0x26,
    EFFECT_GREEN_FADE: 0x27,
    EFFECT_BLUE_FADE: 0x28,
    EFFECT_YELLOW_FADE: 0x29,
    EFFECT_CYAN_FADE: 0x2A,
    EFFECT_PURPLE_FADE: 0x2B,
    EFFECT_WHITE_FADE: 0x2C,
    EFFECT_RED_GREEN_CROSS_FADE: 0x2D,
    EFFECT_RED_BLUE_CROSS_FADE: 0x2E,
    EFFECT_GREEN_BLUE_CROSS_FADE: 0x2F,
    EFFECT_COLORSTROBE: 0x30,
    EFFECT_RED_STROBE: 0x31,
    EFFECT_GREEN_STROBE: 0x32,
    EFFECT_BLUE_STROBE: 0x33,
    EFFECT_YELLOW_STROBE: 0x34,
    EFFECT_CYAN_STROBE: 0x35,
    EFFECT_PURPLE_STROBE: 0x36,
    EFFECT_WHITE_STROBE: 0x37,
    EFFECT_COLORJUMP: 0x38,
EFFECT_CUSTOM_CODE = 0x60
TRANSITION_GRADUAL = "gradual"
TRANSITION_JUMP = "jump"
TRANSITION_STROBE = "strobe"
FLUX_EFFECT_LIST = sorted(list(EFFECT_MAP)) + [EFFECT_RANDOM]
CUSTOM_EFFECT_SCHEMA = vol.Schema(
        vol.Required(CONF_COLORS): vol.All(
            cv.ensure_list,
            vol.Length(min=1, max=16),
                vol.All(
                    vol.ExactSequence((cv.byte, cv.byte, cv.byte)), vol.Coerce(tuple)
        vol.Optional(CONF_SPEED_PCT, default=50): vol.All(
            vol.Range(min=0, max=100), vol.Coerce(int)
        vol.Optional(CONF_TRANSITION, default=TRANSITION_GRADUAL): vol.All(
            cv.string, vol.In([TRANSITION_GRADUAL, TRANSITION_JUMP, TRANSITION_STROBE])
DEVICE_SCHEMA = vol.Schema(
        vol.Optional(CONF_NAME): cv.string,
        vol.Optional(ATTR_MODE, default=MODE_RGBW): vol.All(
            cv.string, vol.In([MODE_RGBW, MODE_RGB, MODE_WHITE])
        vol.Optional(CONF_PROTOCOL): vol.All(cv.string, vol.In(["ledenet"])),
        vol.Optional(CONF_CUSTOM_EFFECT): CUSTOM_EFFECT_SCHEMA,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
        vol.Optional(CONF_DEVICES, default={}): {cv.string: DEVICE_SCHEMA},
        vol.Optional(CONF_AUTOMATIC_ADD, default=False): cv.boolean,
def setup_platform(hass, config, add_entities, discovery_info=None):
    """Set up the Flux lights."""
    lights = []
    light_ips = []
    for ipaddr, device_config in config.get(CONF_DEVICES, {}).items():
        device = {}
        device["name"] = device_config[CONF_NAME]
        device["ipaddr"] = ipaddr
        device[CONF_PROTOCOL] = device_config.get(CONF_PROTOCOL)
        device[ATTR_MODE] = device_config[ATTR_MODE]
        device[CONF_CUSTOM_EFFECT] = device_config.get(CONF_CUSTOM_EFFECT)
        light = FluxLight(device)
        lights.append(light)
        light_ips.append(ipaddr)
    if not config.get(CONF_AUTOMATIC_ADD, False):
        add_entities(lights, True)
        return
    # Find the bulbs on the LAN
    scanner = BulbScanner()
    scanner.scan(timeout=10)
    for device in scanner.getBulbInfo():
        ipaddr = device["ipaddr"]
        if ipaddr in light_ips:
            continue
        device["name"] = f"{device['id']} {ipaddr}"
        device[ATTR_MODE] = None
        device[CONF_PROTOCOL] = None
        device[CONF_CUSTOM_EFFECT] = None
class FluxLight(LightEntity):
    """Representation of a Flux light."""
    def __init__(self, device):
        """Initialize the light."""
        self._name = device["name"]
        self._ipaddr = device["ipaddr"]
        self._protocol = device[CONF_PROTOCOL]
        self._mode = device[ATTR_MODE]
        self._custom_effect = device[CONF_CUSTOM_EFFECT]
        self._bulb = None
        self._error_reported = False
        self._old_brightness = None
        self._is_on = None
    def _connect(self):
        """Connect to Flux light."""
        self._bulb = WifiLedBulb(self._ipaddr, timeout=5)
        if self._protocol:
            self._bulb.setProtocol(self._protocol)
        # After bulb object is created the status is updated. We can
        # now set the correct mode if it was not explicitly defined.
        if not self._mode:
            if self._bulb.rgbwcapable:
                self._mode = MODE_RGBW
            else:
    def _disconnect(self):
        """Disconnect from Flux light."""
        self._bulb = None
    @property
    def available(self) -> bool:
        """Return True if entity is available."""
        return self._bulb is not None
    @property
    def name(self):
        """Return the name of the device if any."""
        return self._name
    @property
    def is_on(self):
        """Return true if device is on."""
        return self._is_on
    @property
    def brightness(self):
        """Return the brightness of this light between 0..255."""
        if self._mode == MODE_WHITE:
            return self.white_value
        return self._bulb.brightness
    @property
    def hs_color(self):
        """Return the color property."""
        return color_util.color_RGB_to_hs(*self._bulb.getRgb())
    @property
    def supported_features(self):
        """Flag supported features."""
        if self._mode == MODE_RGBW:
            return SUPPORT_FLUX_LED | SUPPORT_WHITE_VALUE | SUPPORT_COLOR_TEMP
            return SUPPORT_BRIGHTNESS
    @property
    def white_value(self):
        """Return the white value of this light between 0..255."""
        return self._bulb.getRgbw()[3]
    @property
    def effect_list(self):
        """Return the list of supported effects."""
        if self._custom_effect:
            return FLUX_EFFECT_LIST + [EFFECT_CUSTOM]
    @property
    def effect(self):
        """Return the current effect."""
        current_mode = self._bulb.raw_state[3]
        if current_mode == EFFECT_CUSTOM_CODE:
            return EFFECT_CUSTOM
        for effect, code in EFFECT_MAP.items():
            if current_mode == code:
                return effect
        return None
    def turn_on(self, **kwargs):
        hs_color = kwargs.get(ATTR_HS_COLOR)
        if hs_color:
            rgb = color_util.color_hs_to_RGB(*hs_color)
        else:
            rgb = None
        brightness = kwargs.get(ATTR_BRIGHTNESS)
        effect = kwargs.get(ATTR_EFFECT)
        white = kwargs.get(ATTR_WHITE_VALUE)
        color_temp = kwargs.get(ATTR_COLOR_TEMP)
        # handle special modes
        if color_temp is not None:
            if brightness is None:
                brightness = self.brightness
            if color_temp > COLOR_TEMP_WARM_VS_COLD_WHITE_CUT_OFF:
                self._bulb.setRgbw(w=brightness)
            else:
                self._bulb.setRgbw(w2=brightness)
            return
        # Show warning if effect set with rgb, brightness, or white level
        if effect and (brightness or white or rgb):
            _LOGGER.warning(
                "RGB, brightness and white level are ignored when"
                " an effect is specified for a flux bulb"
        # Random color effect
        if effect == EFFECT_RANDOM:
            self._bulb.setRgb(
                random.randint(0, 255), random.randint(0, 255), random.randint(0, 255)
            return
        if effect == EFFECT_CUSTOM:
                self._bulb.setCustomPattern(
                    self._custom_effect[CONF_COLORS],
                    self._custom_effect[CONF_SPEED_PCT],
                    self._custom_effect[CONF_TRANSITION],
            return
        # Effect selection
        if effect in EFFECT_MAP:
            self._bulb.setPresetPattern(EFFECT_MAP[effect], 50)
            return
        # Preserve current brightness on color/white level change
            brightness = self._old_brightness
        if brightness is None or brightness == 0:
            brightness = 255
        self._old_brightness = brightness
        #_LOGGER.warning("BRIGHTNESS: %d", brightness)
        # Preserve color on brightness/white level change
        if rgb is None:
            rgb = self._bulb.getRgb()
        if white is None and self._mode == MODE_RGBW:
            white = self.white_value
        # handle W only mode (use brightness instead of white value)
            self._bulb.setRgbw(0, 0, 0, w=brightness)
        # handle RGBW mode
        elif self._mode == MODE_RGBW:
            self._bulb.setRgbw(*tuple(rgb), w=white, brightness=brightness)
        # handle RGB mode
        else:
            self._bulb.setRgb(*tuple(rgb), brightness=brightness)
        self._is_on = True
    def turn_off(self, **kwargs):
            self._bulb.setRgbw(0, 0, 0, w=0)
        # handle RGBW mode
            self._bulb.setRgbw(*tuple(rgb), w=0, brightness=0)
        # handle RGB mode
        else:
            self._bulb.setRgb(*tuple(rgb), brightness=0)
        self._is_on = False
    def update(self):
        """Synchronize state with bulb."""
        if not self.available:
            try:
                self._connect()
            except OSError:
                self._disconnect()
                if not self._error_reported:
                    _LOGGER.warning(
                        "Failed to connect to bulb %s, %s", self._ipaddr, self._name
                    self._error_reported = True
                return
        self._bulb.update_state(retry=2)
Here, final version: fixed other bugs that appear with when Google Home and Alexa also handle the same controllers, especially when controller state changes from on and off and so on when used as Automation triggers in Hassio: https://gist.github.com/ybarigou/52d42cd2e6b44bb70cbdb317a059e623
… and again, if your controller handles only one color (ā€˜W’), please set the mode to RGBW
