I am able to change color and set effect. Once I try change brightness I see that it shows previous state on UI but, in fact it changes. Other worst thing that if stripe powered off then it will not turn on. After, led controller stucks, then it needs to be reboot.
Hi Ybarigou. I put this file in âŚ/config/custom_components/flux_led/light.py amd I supposed to do more here than just that? json or init? Iâm new to HA so not very clear atm.
Hi ybarigou - thanks for the fix; seems Iâm back up in running. Do you think the main dev will merge this code into main branch at some point? like the additional UI updates for the lovelace controls.
Maybe someone has problem with turning on and delay of updating state. I am not able turn on device and donât see any log. Is there any way to debug what the problem?
ybarigou could you give me some advice about it?
Hey, yes can confirm, at least I am still having issues with my Flux LED lights. If i turn them on or off using a switch on the Lovelace UI, it seems to break them, so that the next time they are called to be turned on, they donât light up, whatsoever. However, in my automation, I notice that I can switch on a light so long as I add brightness or color temp data along with the request:
"color_temp": 250,
"brightness": 125
So now, If I need to manually control the lights, I do so by google home/assistant. And home assistant only interacts with the lights via automation where I can send the color temp and brightness.
I updated the code with a dirty fix should work now without the need to select RGBW for White only bulbs/led controllers; therefore, the mode can just be âwâ for monochromatic lights.
Also, RGBW bulbs are now directly considered RGB to fix the problem. In conclusion, with using the code I provided here, just keep every bulbâs mode in the configuration.yaml as is, i.e.:
âŚ
hi , thank you for trying to solve this , i have applied your instruction but i get the following.
Logger: homeassistant
Source: custom_components/flux_led/light.py:285
First occurred: 10:11:04 PM (4 occurrences)
Last logged: 10:12:34 PM
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 561, in _update_entity_states
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 277, in async_update_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 316, in _async_write_ha_state
attr.update(self.state_attributes or {})
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 434, in state_attributes
data[ATTR_EFFECT] = self.effect
File "/config/custom_components/flux_led/light.py", line 285, in effect
current_mode = self._bulb.raw_state[3]
TypeError: 'NoneType' object is not subscriptable
Thank you so much for this fix man, it fixed pretty much all my problems. One question though, is there a way to get the lights to turn to warm white instead of cool white when using the switch from the lovelace ui?
This seems to be working for my v8 and v6 ledenet led controllers, but not for the v4. Any advice on how I can make sure to keep those working as well as I have a mix of those around the house.
You can ask the company for a firmware update so the v4 updates to v8, do this through Support in the MagicHome app. I just ran into this problem trying to troubleshoot one of my controllers randomly dropping from the network and asked if I could update the firmware. (mistake!!) They responded saying the âreleasedâ the firmware update to all my devices and when I managed each device I could see they had an update available. Had I known that would spark an entirely new issue with ALL my LED lights, I would never have done it, but regardless they are all v8 now. I am about to try this fix and hope I can get control back on them.
Also having the issue. Manipulate Magic Home RGB Controller (v8) from Home Assistant and the light turns off. Change color and turn on/off/on in the mobile app âwakesâ the light again.
I noticed that if I restart Home Assistant and only change brightness and color it works fine. However if I touch âcolor tempâ or âwhite valueâ the lights stop working. Also turning off the light will break it.
Thanks for the step by step guide.
I followed it, but I donât have any change.
I should have done thing right. I see in the log the message
You are using a custom integration for flux_led which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
But I see this other message:
Setup of light platform flux_led is taking over 10 seconds.
Any hint?
Is there a method to raise this 10 second timeout?
Thanks.
EDIT: I SOLVED
I write two lines to help who could be with problems after following the guide.
The guide is perfect, but it still didnât work to me. There were two problems yet.
I had to disable the autodiscover of the devices. I had to write in the configuration the their IPs.
Second the name of the entities changed after this operation, so I had to update the configuration where they were used. Now it looks to work. Thanks a lot for your posts, they are really useful.
