Is it possible to add a + / - to the initial thermostat card? If possible also an option in the thermostat properties to set what the step is of the + / - (so if +/- should change the setting with 1 degree of .5 degree etc.)
Reason:
Thermostat is one of the most essential devices in a home and is used by many in the house. Now you have to click first , that brings up a slider (that is relative small on high resolution devices) and is not that easy to operate.
p.s. maybe there is already a way to do this, but then I could not find it.
