Hi! I have strings of panels in two directions. No problmen setting up two integrations in forecast.solar. I also found example of template combining both integrations to one value for forecast (working fine if you produce less then the max of the inverter). BUT I only have one inverter, so it will not give correct forecast as I have a max in the inverter any given time. Any proposal on how to get a setup working with 2+ forecast.solar integrations but with combined max capacity in the inverter? Splitting the inverter max each integration wont work.
Hi Mathias, did you figure this out? I have the same problem.
I also asked here:
Same problem here. I have one converter connected to east/west panels and another one panel/converter combo pointing south. So I created three services and added them together in sensors.yaml like this:
total_solar_next_hour:
friendly_name: "Total Solar Energy Next Hour"
unit_of_measurement: "kWh"
value_template: >
{{ states('sensor.energy_next_hour')|float(0) +
states('sensor.energy_next_hour_2')|float(0) +
states('sensor.energy_next_hour_3')|float(0) }}
Unfortunately, this is a known issue, and it seems it won’t be addressed until YOU do it.
