So I’m trying to configure the HassOS boot image, written to a zvol, and I’m having trouble getting it to fully boot. I realized I had to change it to UEFI boot, and after doing that I get similar, but not quite the same, output as when booting in VirtualBox direction with the VDI I used to extract the raw image.
After looking carefully, it looks like it may be an issue with it finding/mounting the partitions in the Zvol? Is that correct based on my reading of the below output?
barebox 2020.04.0 #1 Thu Aug 6 20:37:21 UTC 2020
Board: barebox EFI payload
EFI v2.40 by BHYVE v65536
EFI Event timer too slow freq = 100 Hz
acpi2: Found XSDT (OEM: BHYVE BV) with 5 entries
efi-fs handle-00000000bf055698: mounted on /boot
efi-block-io handle-00000000bf282418: Cannot read MBR/partition table
malloc space: 0x30000000 -> 0x3fffffff (size 256 MiB)
state: New state registered 'state'
state: Using bucket 0@0x00000000
description: EFI Hard Drive
path: pci_root(0)/Pci(0x4,0x0)/Sata(0x0,0x0,0x0)
description: EFI Network
path: pci_root(0)/Pci(0x5,0x0)/Mac(589cfc01b33f,1)
description: EFI Internal Shell
path: mem_map(11,0xbfc1c000,0xbffbbfff)/Path(132,6,0x83a5047c3e9e1c4fad65e05268d0b4d100000000ffff0800)
environment load /efivars/barebox-env-5b91f69c-8b88-4a2b-9269-5f1d802b5175: No such file or directory
Maybe you have to create the partition.
running /env/bin/init...
- Hit m for menu or wait for autoboot -
Booting entry 'bootchooser'
Booting entry 'system0'
ext4 ext40: EXT2 rev 1, inode_size 128, descriptor size 32
Loading MS-DOS executable '/mnt/system/bzImage'
