Fresh Hass.io Installation does not work correctly!?
I made a fresh Hassbian installation on a Raspberry Zero.
But it is indicated to me that following components could not be loaded:
  • eq3btsmart.climate
  • fritz.device_tracker
  • openhome.media_player
Before the last update I didn’t have such problems.
And on Hassio everything is going well too.
What is wrong!??
I have also installed the suites:
  • custom-component-store
  • manager
But when i try to install some custom components, i get a Server Error 500!?
Hassbian or hassio?
I opened the topic because it doesn’t work with Hassbian anymore. Since the current update it doesn’t work with both Hassio and Hasbian anymore.
Everything was great before.
I suspect that the required script is no longer available after the update.
About Hassio:
Updating device list from legacy took longer than the scheduled scan interval 0:00:12
12:59 components/device_tracker/setup.py (WARNING) - message first occured at 12:49 and shows up 32 times
Failed communicating with LMS: <class ‘concurrent.futures.base.TimeoutError’>
12:50 components/squeezebox/media_player.py (ERROR)
Setup of platform squeezebox is taking over 10 seconds.
12:50 main.py (WARNING)
Update of sensor.bxhamnas_memory_usage is taking over 10 seconds
Updating tuya switch took longer than the scheduled update interval 0:00:30
12:50 helpers/entity_platform.py (WARNING) - message first occured at 12:49 and shows up 3 times
Updating fritzdect switch took longer than the scheduled update interval 0:00:30
12:50 helpers/entity_platform.py (WARNING) - message first occured at 12:50 and shows up 2 times
Update of switch.043563403c71bf3d9579_1 is taking over 10 seconds
Updating qnap sensor took longer than the scheduled update interval 0:00:30
12:50 helpers/entity_platform.py (WARNING) - message first occured at 12:49 and shows up 2 times
Update of switch.fritz_dect_200_1 is taking over 10 seconds
12:49 main.py (WARNING)
Update of switch.05200020bcddc202ddc9 is taking over 10 seconds
Update of sensor.bxhamnas_smart_status_drive_0_1 is taking over 10 seconds
Setup of hassio is taking over 10 seconds.
12:48 main.py (WARNING)
Setup of platform yr is taking over 10 seconds.
Setup of platform qnap is taking over 10 seconds.
Setup of platform dht is taking over 10 seconds.
Setup of platform fritzdect is taking over 10 seconds.
dht: Error on device update!
12:48 components/dht/sensor.py (ERROR) - message first occured at 12:48 and shows up 2 times
Unable to prepare setup for platform eq3btsmart.climate: Could not install all requirements.
12:47 setup.py (ERROR)
Not initializing eq3btsmart because could not install requirement python-eq3bt==0.1.9
12:47 requirements.py (ERROR)
Unable to install package python-eq3bt==0.1.9: ERROR: Complete output from command /usr/local/bin/python3 -u -c ‘import setuptools, tokenize;file=’“'”‘/tmp/pip-install-2xgsu1nm/bluepy/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ bdist_wheel -d /tmp/pip-wheel-c052u0s
--python-tag cp37: ERROR: running bdist_wheel running build running build_py Working dir is /tmp/pip-install-2xgsu1nm/bluepy execute make -C ./bluepy clean error: [Errno 2] No such file or directory: ‘make’: ‘make’ ---------------------------------------- ERROR: Failed building wheel for bluepy ERROR: Complete output from command /usr/local/bin/python3 -u -c ‘import setuptools, tokenize;file=’"’“‘/tmp/pip-install-2xgsu1nm/bluepy/setup.py’”‘"’;f=getattr(tokenize, ‘"’“‘open’”‘"’, open)(file);code=f.read().replace(‘"’“‘\r\n’”‘"’, ‘"’“‘\n’”‘"’);f.close();exec(compile(code, file, ‘"’“‘exec’”‘"’))’ install --record /tmp/pip-record-3hn2k0ks/install-record.txt --single-version-externally-managed --compile: ERROR: running install running build running build_py Working dir is /tmp/pip-install-2xgsu1nm/bluepy execute make -C ./bluepy clean error: [Errno 2] No such file or directory: ‘make’: ‘make’ ---------------------------------------- ERROR: Command “/usr/local/bin/python3 -u -c ‘import setuptools, tokenize;file=’”‘"’/tmp/pip-install-2xgsu1nm/bluepy/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’“‘))’ install --record /tmp/pip-record-3hn2k0ks/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-install-2xgsu1nm/bluepy/
12:47 util/package.py (ERROR)
Setup of person is taking over 10 seconds.
12:40 main.py (WARNING)
Setup of tuya is taking over 10 seconds.
Systemlog Hassio:
19-06-08 10:38:51 INFO (MainThread) [main] Initialize Hass.io setup
19-06-08 10:38:51 INFO (MainThread) [main] Setup HassIO
19-06-08 10:38:52 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 166
19-06-08 10:38:52 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-06-08 10:38:52 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-06-08 10:38:52 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-06-08 10:38:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-06-08 10:38:53 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-06-08 10:38:53 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: de.pengutronix.rauc - /
19-06-08 10:38:53 INFO (MainThread) [hassio.host.info] Update local host information
19-06-08 10:38:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-06-08 10:38:53 INFO (MainThread) [hassio.host.services] Update service information
19-06-08 10:38:53 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-06-08 10:38:54 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {‘hassio-supervisor’}
19-06-08 10:38:54 INFO (MainThread) [hassio.host.services] Reload local service hassos-apparmor.service
19-06-08 10:38:54 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-06-08 10:38:55 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi-homeassistant with version 0.94.0
19-06-08 10:38:55 INFO (MainThread) [hassio.hassos] Detect HassOS 2.12 on host system
19-06-08 10:38:55 INFO (SyncWorker_0) [hassio.docker.hassos_cli] Found HassOS CLI homeassistant/armhf-hassio-cli with version 9
19-06-08 10:38:57 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-06-08 10:38:57 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-06-08 10:38:58 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-06-08 10:38:58 INFO (MainThread) [hassio.addons] Found 5 installed add-ons
19-06-08 10:38:59 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/armhf-addon-samba with version 8.1
19-06-08 10:38:59 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/armhf-addon-check_config with version 2.1
19-06-08 10:38:59 INFO (SyncWorker_2) [hassio.docker.interface] Attach to homeassistant/armhf-addon-ssh with version 5.6
19-06-08 10:38:59 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/armhf-addon-configurator with version 3.4
19-06-08 10:38:59 INFO (SyncWorker_4) [hassio.docker.interface] Attach to hassioaddons/node-red-armhf with version v3.1.4
19-06-08 10:38:59 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-06-08 10:39:01 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-06-08 10:39:01 INFO (MainThread) [hassio.discovery] Load 0 messages
19-06-08 10:39:01 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-06-08 10:39:01 INFO (MainThread) [main] Run Hass.io
19-06-08 10:39:01 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-06-08 10:39:01 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-06-08 10:39:01 INFO (MainThread) [hassio.addons] Phase ‘initialize’ start 0 add-ons
19-06-08 10:39:01 INFO (MainThread) [hassio.addons] Phase ‘system’ start 0 add-ons
19-06-08 10:39:01 INFO (MainThread) [hassio.addons] Phase ‘services’ start 2 add-ons
19-06-08 10:39:10 INFO (SyncWorker_1) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-samba with version 8.1
19-06-08 10:39:17 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-ssh with version 5.6
19-06-08 10:39:23 INFO (SyncWorker_2) [hassio.docker.interface] Start homeassistant/raspberrypi-homeassistant
19-06-08 10:40:54 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-06-08 10:47:55 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-06-08 10:49:06 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-06-08 10:49:06 INFO (MainThread) [hassio.addons] Phase ‘application’ start 2 add-ons
19-06-08 10:49:07 WARNING (SyncWorker_0) [hassio.docker.addon] Node-RED run with disabled protected mode!
19-06-08 10:49:20 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on hassioaddons/node-red-armhf with version v3.1.4
19-06-08 10:49:27 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-configurator with version 3.4
19-06-08 10:49:32 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-06-08 10:49:32 INFO (MainThread) [hassio.core] Hass.io is up and running
19-06-08 10:49:53 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_nodered
19-06-08 10:54:44 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-06-08 10:54:44 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-06-08 10:54:45 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-06-08 10:54:45 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
Your dependency failed to install/compile.
Given that you’re using Hass.io, as based on your logs, I’ve changed the title and moved it to the Hass.io section.
Dear Admin,
That’s not right!
This problem first occurred with a Hassbian update on Hassbian then I completely reinstalled Hassbian (See in Post #1). Then further problems occurred like:
Also, the suites are not running correctly!
That’s the only reason why I switched to Hass.io, because it still worked. But with the update to version 0.94.0 the day before yesterday this doesn’t work anymore.
And actually I want to use Hassbian, but I have the impression that it is no longer supported?
I’ve seen it, but you can’t do anything with Hass.io. Or do I see it wrong?
The component says they need a version of that module from Feb 2018. Perhaps it is not compatible with newer Python versions.
I think Hassio now uses python 3.7. I know Hassbian now uses Python 3.7
I’m back at 0.93.2, let’s see if the skirpts will be adjusted at some point or support will be discontinued.
Well we know Python 3.5 support will be removed the first HA update after August 1.
It’s one of the three recommended options for installing Home Assistant. Not sure why you think it’s no longer supported.
If you want assistance getting these resolved on the latest Hassbian, I recommend just trying to add them one at a time and resolving any issues.
If you choose that path, the forum is here to assist in troubleshooting assuming you provide configuration & log information…
Running a venv environment and python 3.6.7,
pip3 install python-eq3bt
Fails on building bluepy
OK, that’s a start.
What exactly are the error messages? If you copy & paste here we have help you sort through the verbosity.
EDIT I just tried it and was missing an installed library but your issue may be different.
I get the impression because:
  1. there is an extra category for Hass.io here but none explicitly for Hassbian.
  2. the page https://home-assistant.github.io/hassbian-scripts/ is not maintained, some broken links for a test click “Suites” and you get a 404 because the link is not right. It must read as follows: https://home-assistant.github.io/hassbian-scripts/suites/
  3. currently unusual problems with Fresh Installation on Raspberry Zero W and I haven’t found anything here. 1-2 months ago there were no problems Fresh Image, switch on about 20-30 minutes later start.
I just flashed a fresh Hassbian image on a Rpi Zero W. When it’s ready, I’ll add a thermostat and then we’ll go through it step by step.
That is new documentation (within the past 2 weeks) that appears to be a mess and is broken…
I think they mean to point to the doc files in this directory.
  1. Hass.io has a separate section because the add-ons etc made people think there was a need. Hassbian is just Raspbian, so nobody thought there was a need for it
  2. It was broken recently as the developer is re-working things, they know, and they’re on it. But… you know what, we’ve all got other lives too :wink:
  3. A Pi Zero is not recommended for anything other than testing. A 30 minute first start is within what’s expected.
We all still have a life next to our automated home :slight_smile: It shouldn’t be a reproach only to show why I got the impression.
I know the Rpi Zero is not recommended for productive systems. But this is the rule in any project and most of the time it works very well. And it needs less power than its big brother, which makes it very attractive to me.
I have here 3 Rpi Zero’s for Multiroom Audio 1 Zero for my old Smart Home (SHC / https://www.rpi-controlcenter.de/) and 2 Rpi 3 for Kodi media system.
And currently 2 Zeros to test HA.
