Okay, now we come back with a Fresh installtion of Hassbian with the same problems
Unable to prepare setup for platform eq3btsmart.climate: Could not install all requirements.
15:52 setup.py (ERROR)
Not initializing eq3btsmart because could not install requirement python-eq3bt==0.1.9
15:52 requirements.py (ERROR)
Unable to install package python-eq3bt==0.1.9: ERROR: Complete output from command /srv/homeassistant/bin/python -u -c ‘import setuptools, tokenize;file=’“'”‘/tmp/pip-install-smdpyhqy/bluepy/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’“‘))’ bdist_wheel -d /tmp/pip-wheel-vimpqn_v --python-tag cp37: ERROR: running bdist_wheel running build running build_py Working dir is /tmp/pip-install-smdpyhqy/bluepy execute make -C ./bluepy clean execute make -C bluepy -j1 Failed to compile bluepy-helper. Exiting install. Command was ‘make -C bluepy -j1’ in /tmp/pip-install-smdpyhqy/bluepy Return code was 2 Output was: b"make: Entering directory ‘/tmp/pip-install-smdpyhqy/bluepy/bluepy’\ntar xzf bluez-src.tgz\ntouch ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c\nPackage glib-2.0 was not found in the pkg-config search path.\nPerhaps you should add the directory containingglib-2.0.pc'\nto the PKG_CONFIG_PATH environment variable\nNo package 'glib-2.0' found\nPackage glib-2.0 was not found in the pkg-config search path.\nPerhaps you should add the directory containing
glib-2.0.pc’\nto the PKG_CONFIG_PATH environment variable\nNo package ‘glib-2.0’ found\ncc -L. -g -Wall -Os -DHAVE_CONFIG_H -I./bluez-5.47/attrib -I./bluez-5.47 -I./bluez-5.47/lib -I./bluez-5.47/src -I./bluez-5.47/gdbus -I./bluez-5.47/btio -I./bluez-5.47/sys -o bluepy-helper bluepy-helper.c ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c \nbluepy-helper.c:33:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~\ncompilation terminated.\n./bluez-5.47/attrib/gatt.c:32:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/att.c:33:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/utils.c:30:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/gattrib.c:34:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/src/log.c:38:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/btio/btio.c:37:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/src/shared/timeout-glib.c:22:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/src/shared/io-glib.c:30:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/att.c:33:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\nmake: *** [Makefile:30: bluepy-helper] Error 1\nmake: Leaving directory ‘/tmp/pip-install-smdpyhqy/bluepy/bluepy’\n" ---------------------------------------- ERROR: Failed building wheel for bluepy ERROR: Complete output from command /srv/homeassistant/bin/python -u -c ‘import setuptools, tokenize;file=’“'”‘/tmp/pip-install-smdpyhqy/bluepy/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ install --record /tmp/pip-record-7xh65cky/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.7/bluepy: ERROR: running install running build running build_py Working dir is /tmp/pip-install-smdpyhqy/bluepy execute make -C ./bluepy clean execute make -C bluepy -j1 Failed to compile bluepy-helper. Exiting install. Command was ‘make -C bluepy -j1’ in /tmp/pip-install-smdpyhqy/bluepy Return code was 2 Output was: b"make: Entering directory ‘/tmp/pip-install-smdpyhqy/bluepy/bluepy’\ntar xzf bluez-src.tgz\ntouch ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c\nPackage glib-2.0 was not found in the pkg-config search path.\nPerhaps you should add the directory containingglib-2.0.pc'\nto the PKG_CONFIG_PATH environment variable\nNo package 'glib-2.0' found\nPackage glib-2.0 was not found in the pkg-config search path.\nPerhaps you should add the directory containing
glib-2.0.pc’\nto the PKG_CONFIG_PATH environment variable\nNo package ‘glib-2.0’ found\ncc -L. -g -Wall -Os -DHAVE_CONFIG_H -I./bluez-5.47/attrib -I./bluez-5.47 -I./bluez-5.47/lib -I./bluez-5.47/src -I./bluez-5.47/gdbus -I./bluez-5.47/btio -I./bluez-5.47/sys -o bluepy-helper bluepy-helper.c ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c \nbluepy-helper.c:33:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/gattrib.c:34:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/gatt.c:32:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/btio/btio.c:37:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/utils.c:30:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/src/shared/io-glib.c:30:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/src/log.c:38:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\nmake: *** [Makefile:30: bluepy-helper] Error 1\nmake: Leaving directory ‘/tmp/pip-install-smdpyhqy/bluepy/bluepy’\n” ---------------------------------------- ERROR: Command “/srv/homeassistant/bin/python -u -c ‘import setuptools, tokenize;file=’”‘"’/tmp/pip-install-smdpyhqy/bluepy/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’“‘))’ install --record /tmp/pip-record-7xh65cky/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.7/bluepy” failed with error code 1 in /tmp/pip-install-smdpyhqy/bluepy/\ncompilation terminated.\n./bluez-5.47/src/shared/timeout-glib.c:22:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^
15:52 util/package.py (ERROR)
2019-06-09 14:52:41 ERROR (SyncWorker_2) [homeassistant.util.package] Unable to install package python-eq3bt==0.1.9: ERROR: Complete output from command /srv/homeassistant/bin/python -u -c ‘import setuptools, tokenize;file=’“'”‘/tmp/pip-install-smdpyhqy/bluepy/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’“‘))’ bdist_wheel -d /tmp/pip-wheel-vimpqn_v --python-tag cp37:
running build
running build_py
Return code was 2
Output was:
glib-2.0.pc’\nto the PKG_CONFIG_PATH environment variable\nNo package ‘glib-2.0’ found\ncc -L. -g -Wall -Os -DHAVE_CONFIG_H -I./bluez-5.47/attrib -I./bluez-5.47 -I./bluez-5.47/lib -I./bluez-5.47/src -I./bluez-5.47/gdbus -I./bluez-5.47/btio -I./bluez-5.47/sys -o bluepy-helper bluepy-helper.c ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c \nbluepy-helper.c:33:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~\ncompilation terminated.\n./bluez-5.47/attrib/gatt.c:32:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/att.c:33:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/utils.c:30:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/attrib/gattrib.c:34:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/src/log.c:38:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/btio/btio.c:37:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~\ncompilation terminated.\n./bluez-5.47/src/shared/timeout-glib.c:22:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^~~~~~~~\ncompilation terminated.\nmake: *** [Makefile:30: bluepy-helper] Error 1\nmake: Leaving directory ‘/tmp/pip-install-smdpyhqy/bluepy/bluepy’\n”\ncompilation terminated.\n./bluez-5.47/src/shared/io-glib.c:30:10: fatal error: glib.h: No such file or directory\n #include <glib.h>\n ^
ERROR: Complete output from command /srv/homeassistant/bin/python -u -c ‘import setuptools, tokenize;file=’“'”‘/tmp/pip-install-smdpyhqy/bluepy/setup.py’“'”‘;f=getattr(tokenize, ‘"’“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’“‘))’ install --record /tmp/pip-record-7xh65cky/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.7/bluepy:
running build
running build_py
Return code was 2
Output was:
b"make: Entering directory ‘/tmp/pip-install-smdpyhqy/bluepy/bluepy’\ntar xzf bluez-src.tgz\ntouch ./bluez-5.47/lib/bluetooth.c ./bluez-5.47/lib/hci.c ./bluez-5.47/lib/sdp.c ./bluez-5.47/lib/uuid.c ./bluez-5.47/attrib/att.c ./bluez-5.47/attrib/gatt.c ./bluez-5.47/attrib/gattrib.c ./bluez-5.47/attrib/utils.c ./bluez-5.47/btio/btio.c ./bluez-5.47/src/log.c ./bluez-5.47/src/shared/mgmt.c ./bluez-5.47/src/shared/crypto.c ./bluez-5.47/src/shared/att.c ./bluez-5.47/src/shared/queue.c ./bluez-5.47/src/shared/util.c ./bluez-5.47/src/shared/io-glib.c ./bluez-5.47/src/shared/timeout-glib.c\nPackage glib-2.0 was not found in the pkg-config search path.\nPerhaps you should add the directory containing glib-2.0.pc'\nto the PKG_CONFIG_PATH environment variable\nNo package 'glib-2.0' found\nPackage glib-2.0 was not found in the pkg-config search path.\nPerhaps you should add the directory containing
2019-06-09 14:52:41 ERROR (MainThread) [homeassistant.requirements] Not initializing eq3btsmart because could not install requirement python-eq3bt==0.1.9
2019-06-09 14:52:41 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform eq3btsmart.climate: Could not install all requirements.
