Thank you for the excellent blueprint.
In addition to frigate, I also installed doubletake.
In the features i see : * Dynamically handle things like object type, zones and face detection from doubletake.
Is it possible to have notification for a recognized face in double take?
Regards
Renaatdb
The way it works now is it can replace the word Person with the name of the matched face.
You could use a custom filter to only notify on a specific match but it wouldnāt be totally reliable I wouldnāt think.
Whether I try to import the stable or the beta blueprint I keep getting an unknown error message.
Anybody knows the reason?
Please try again now
Could you possibly try with no base url set and see if it makes any difference to the atachment. I kow it might break other things, but itās the only difference i can see in the url.
I just re-tried to click the STABLE blueprint and now it went perfectly straight on.
Thanks mate!
Same like beforeā¦ mmmm Curious
Are you using the pull request 12.0.4h version?
Tested too , made no difference ā¦
Does reviews topic work on 0.12.0.4a? I just switched to review topics and blueprint seems to stop working. Iām troubleshooting whether it is my setup or is it yet to be support? Tracing the automation, the last step is on
`alias: Notifications enabled for object label
condition: template
value_template: ā{{ not labels|length or object in labels }}ā`
No, you need the version from the 0.14 pull request on github
All good. Thank you. I will probably wait for HACS.
Bluepeint has nothing to do with HACS!!!
one more questionā¦ loop clips - like in frigate, does not work on iOS, right?
Is it possible to define loiter_time in seconds instead of minutes ?
alias: "redacted"
description: >-
redacted
use_blueprint:
path: SgtBatten/Stable.yaml
input:
camera: camera.garage_2
notify_device: 7ebed67d640b24ff8f3a9789d9b22094
attachment: snapshot.jpg?bbox=1
update_thumbnail: true
tv: false
base_url: https://hass.redacted.com
tap_action: >-
{{base_url}}/local/player/index.html#share={{trigger.payload_json['after']['camera']
| lower |
replace('-','_')}}_sub&pwd=redacted&media=video+audio
alert_once: true
zone_filter: true
zones:
- bal
labels:
- bicycle
- car
- motorcycle
- person
loiter_timer: 1
Reason for such a need is : I need an later when someone is interacting with the mailbox. That would be about 7 seconds loitering time. Mailbox is close to a road where people/pedestrians cross the required_zone within less than 3 seconds. More info/pictures here : [Config Support]: Help setting masks/zones Ā· blakeblackshear/frigate Ā· Discussion #13254 Ā· GitHub
I found this : HA_blueprints/Frigate_Camera_Notifications/Stable.yaml at c6d8661405d13a127b83035c5891a0849c456141 Ā· SgtBatten/HA_blueprints Ā· GitHub
I set it to loiter_timer: 0.1
hoping the step: 1.0
only applies to the slider gui.
Yeah it probably should be seconds shouldnāt it
Definitely. More granular control.
Sorry for asking but what is the url to use the 0.14 version? If I copy the link from github I get this:
HA_blueprints/Frigate Camera Notifications/Stable at 29a89abc1da0ad0fc185fab3f7324dd835b8831c Ā· SgtBatten/HA_blueprints Ā· GitHub
I tried to add .yaml at the end without success
So, thumbnail comes as soon as Iām in the mobile network, when Iām connected to WLAN, it leaves the small picture outā¦
