@SgtBatten I think i’m having the same issue, but my HA image is 2024.05 installed via CasaOs. I’m running MQTT, HA and Frigate as containers and i’m able to configure the basic notification from Frigate docs but cannot import this blueprint.
I’m confident its a noob issue but i’ll appreciate any assitance.
My Environment:
Debian 12
Docker CE 27.2.0
HASS 2024.5.5
Frigate Stable
HASS Frigate integration 5.4.0
HASS HACS 2.0.1
MQTT 2.0.18
error:
Import a blueprint
Invalid blueprint: extra keys not allowed @ data[‘blueprint’][‘input’][‘actions’][‘collapsed’]. Got True extra keys not allowed @ data[‘blueprint’][‘input’][‘actions’][‘icon’]. Got ‘mdi:gesture-double-tap’ extra keys not allowed @ data[‘blueprint’][‘input’][‘actions’][‘input’]. Got {‘tap_action’: {‘name’: ‘Tap Action URL’, ‘description’: ‘The URL to open when tapping on the notification. Some presets are provided, you can also set your own by typing in the box.\nThese options define the text and URLs associated with the three action buttons at the bottom of the notification.’, ‘default’: ‘{{base_url}}/api/frigate{{client_id}}/notifications/{{id}}/{{camera}}/clip.mp4’, ‘selector’: {‘select’: {‘options’: [{‘label’: ‘View Clip’, ‘value’: '{{base_url}}/api/frigate{{client_i… extra keys not allowed @ data[‘blueprint’][‘input’][‘debug’][‘collapsed’]. Got True extra keys not allowed @ data[‘blueprint’][‘input’][‘debug’][‘icon’]. Got ‘mdi:bug’ extra keys not allowed @ data[‘blueprint’][‘input’][‘debug’][‘input’]. Got {‘debug’: {‘name’: ‘Debug’, ‘description’: ‘# DEBUG\n\nEnable to send debug messages to the home assistant logbook.\n’, ‘default’: False, ‘selector’: {‘boolean’: None}}} extra keys not allowed @ data[‘blueprint’][‘input’][‘filters’][‘collapsed’]. Got True extra keys not allowed @ data[‘blueprint’][‘input’][‘filters’][‘icon’]. Got ‘mdi:filter’ extra keys not allowed @ data[‘blueprint’][‘input’][‘filters’][‘input’]. Got {‘zone_filter’: {‘name’: ‘Zone Filter on/off (Optional)’, ‘description’: ‘Enable to only notify if an object has entered a zone listed below.’, ‘default’: False, ‘selector’: {‘boolean’: None}}, ‘zones’: {‘name’: ‘Required Zones (Optional - Enabled Above)’, ‘description’: 'Enter the name of one zone at a time. It must be lowercase and include underscores as per your Frigate config.\nBy default any zone is acceptable. If you desire ALL listed zones to be entered before getting a notification, e… extra keys not allowed @ data[‘blueprint’][‘input’][‘notification_customisations’][‘collapsed’]. Got True extra keys not allowed @ data[‘blueprint’][‘input’][‘notification_customisations’][‘icon’]. Got ‘mdi:bell’ extra keys not allowed @ data[‘blueprint’][‘input’][‘notification_customisations’][‘input’]. Got {‘title’: {‘name’: ‘Notification Title (Optional)’, ‘description’: ‘The title of the notification.’, ‘default’: ‘’}, ‘message’: {‘name’: ‘Notification Message’, ‘description’: “The message of the notification.\nYou can use variables such as {{camera_name}} and {{label}}\ne.g., A {{ label }} {{ ‘is loitering’ if loitering else ‘was detected’ }} on the {{ camera_name }} camera.\n”, ‘default’: “A {{ label }} {{ ‘is loitering’ if loitering else ‘was detected’ }} on the {{ camera_name }} camera.”,… extra keys not allowed @ data[‘blueprint’][‘input’][‘tv_notifications’][‘collapsed’]. Got True extra keys not allowed @ data[‘blueprint’][‘input’][‘tv_notifications’][‘icon’]. Got ‘mdi:television’ extra keys not allowed @ data[‘blueprint’][‘input’][‘tv_notifications’][‘input’]. Got {‘tv’: {‘name’: ‘TV Notification (Optional)’, ‘description’: ‘Set to true if you are notifying an Android/Fire TV Can also be used to prioritise snapshots on the TV over Android mobile apps when notifying a mixed device group. Base URL must be set\nThe below settings are for TV notifications only’, ‘default’: False, ‘selector’: {‘boolean’: None}}, ‘tv_position’: {‘name’: ‘TV Notification Position (Optional)’, ‘description’: ‘Set the position of the notification on your TV’, ‘default’: 'center…
