I will check and see. Something I just discovered on the iPad. If HA companion app “confirm before opening url” is ticked on, the clip will work after you tell it is okay to open. If it is unticked, it doesn’t work. Also when asked whether you want to open the url, the option to always allow will untick the option and cause failure.
Update, snapshot behaves in the same manner. Works if you “allow” it each time.
Sounds like we might need to do a bug report on the IOS companion app. At the very least they might give advice as to why the url is not working in that scenario
I have now moved the blueprints over to a github repository from the github gist it was previously. This allows for better issue tracking and gives people the ability to contribute ideas and solutions through pull requests.
I will continue to monitor and provide support here, but all are welcome to visit the github repository linked in the first post to get help and report bugs also.
Sometimes I get notifications that don’t have a image with them. When I click on them, I can still view the snapshot or video. What am I doing wrong? I’m on Android, if that matters.
You are not the first person to mention it. I’ve certainly seen my fair share when i’m troubleshooting and changing code, but generally on my stable cams i’m not seeing this really ever.
If you observe one and can grab all the details from the trace i’d appreciate you throwing it on github for me to look at.
Hi All, I have just recently joined the Frigate bandwagon… I have Frigate working and the Integration + Card. Just tried this notification blueprint which looks awesome but cant get it to work.
I am running Hassio latest ver
Frigate Full Access ver 0.12.0
Integration Ver 4.0.0
Blueprint tried latest stable and the beta.
Configured the automation but it just never triggers, I can see the logbook showing the camera detection and mqtt explorer showing events under frigate/events but the automation just never triggers and shows last triggered as never.
unauthenticated notification event proxy is enabled.
Can anyone help troubleshoot this for me please I’m pulling my hair out!
I assume in your frigate config the camera is just back not back_2?
If you only have one camera entity called camera.back then it could have been caused when reinstalling the integration. You can edit the entity id manually or alternatively uninstall the integration and restart HA which should also clear them out, allowing you to reinstall it.
If you have some other integration with that entity id you might want to rename one of them.
